Another PWM dimming question
Posted: Sat Oct 12, 2013 7:22 am
by Winschuc
This May be a very basic question, but I'm thinking about going with an LED system that utilizes a 5v dimming signal. Since the RA is 0-10v will I have to use some sort of resistor or will I be able to compensate for the voltage difference in code? Or will it even matter?
Re: Another PWM dimming question
Posted: Sat Oct 12, 2013 9:09 am
I can make the signals at 0-5V when you order it too
If you already have it, you can send it back and I'll change it.
Or, you can get the dimming expansion module and I'll change it to 0-5V.
Posted: Sat Oct 12, 2013 11:27 am
Or you can get an expansion relay box and have those be changed
Posted: Sat Oct 12, 2013 7:56 pm
by Winschuc
Awesome, thanks!
