Main unit problems, exposed to water
Posted: Mon Oct 14, 2013 7:33 am
Ugh, I think I killed my brand new reef angel.
While setting it up I had it mounted inside my cabinet. I ran into a return problem where the top of my tank started to overflow. It looks like some water dripped down and got into my reef angel unit. First the red status light went on and the LCD failed to respond. I ended up opening it up an found a good bit if water inside. I've dried it out but it doesn't seem to be working now... The relay is responding strangely and the LCD still doesn't respond. Any suggestions, or am I screwed?
Thanks...
Thanks...
