APPLE
Posted: Wed Oct 26, 2011 12:04 am
by simog
Good morning, I apologize for my bad English.
I wanted to know if there is a management program for Apple REEF ANGEL.
I have seen that there is' only Arduino.
But there is no program like Windows?
If someone can 'help?
Thanks for your patience.
Re: APPLE
Posted: Wed Oct 26, 2011 5:47 am
by binder
simog wrote:Good morning, I apologize for my bad English.
What type of management program are you referring to? Are you talking about the Client Suite or about ReefAngel Generator?
Re: APPLE
Posted: Wed Oct 26, 2011 6:26 am
by simog
I'm talking about but Reef Generator Client Suite.
And I ask 'if there is a program to deal with Apple that allows me to turn on and off pomp, skimmer, adjust the LED sunrise and sunset etc. ..
All this knowing that I do not know the Arduino.
Simon.
Re: APPLE
Posted: Wed Oct 26, 2011 6:36 am
by wolfador
if you have the wifi adapter you can use the web interface or the iPhone app.
You can also run a virtual machine on your Mac to run the Client Suite.
Re: APPLE
Posted: Wed Oct 26, 2011 7:05 am
by binder
simog wrote:[
Ok.
Yes, arduino does upload to the controller. If you do not use ReefAngel Generator to create the code to run on the controller, you have to manually create it yourself. There are samples to help you create the code for your controller to turn on & off the pump, adjust the LED sunrise, etc.
If you have problems getting certain tasks accomplished, then we all can help on here.
My public Sketchbook (sketches are the programs that run on the arduino controller) is available here: https://github.com/curtbinder/SketchBook
You can look at that for examples of how to accomplish the tasks that you want. These files are opened inside Arduino and then uploaded to your ReefAngel by Arduino.
Re: APPLE
Posted: Wed Oct 26, 2011 7:24 am
by simog
wolfador wrote:if you have the wifi adapter you can use the web interface or the iPhone app.
Ok, thanks.
I do not think to use a virtual machine on imac.
Simon.
Re: APPLE
Posted: Wed Oct 26, 2011 7:33 am
by simog
binder wrote:
simog wrote:[
Ok.
Ok, I will try to study your examples.
If this were to lead to good results will acquire Angel Reef.
At the moment it seems difficult to understand this system.
I've never seen the program the Arduino.
And as my Italian language and 'difficult for me.
It would be nice to develop an aid for those who use apple.
Thank you.
Simon.
Re: APPLE
Posted: Wed Oct 26, 2011 10:55 am
by binder
simog wrote: It would be nice to develop an aid for those who use apple.
I've been working on a way to convert my ReefAngel Generator application to work on apple but have not made a lot of progress with it. A new version is being worked on that will run on Apple, Windows and Linux but it is not very far along. There have been other projects that have required more time and work than this one.
Re: APPLE
Posted: Wed Oct 26, 2011 11:36 am
by simog
Thank you and good job.
Simon
Re: APPLE
Posted: Mon Dec 26, 2011 11:18 pm
by matt_longview
By running a "virtual machine" are you suggesting bootcamp to install and run a licensed version of windows, or an emulator that has (I'm assuming required) usb support? If the latter, do you have any suggestions?
Re: APPLE
Posted: Tue Dec 27, 2011 4:51 am
by wolfador
matt_longview wrote:By running a "virtual machine" are you suggesting bootcamp to install and run a licensed version of windows, or an emulator that has (I'm assuming required) usb support? If the latter, do you have any suggestions?
You can use Parallels, VirtualBox or VMWare to run a Virtual Windows machine.
