RA ATO Pump
Posted: Thu Oct 17, 2013 8:01 am
Thinking of getting the RA ATO pump to replace my 50ml/min BRS ATO pump because I would like something that pumps a bit faster. What are the specs on the RA pump as in how many ml/min? Is it AC or DC? If it's AC is the pump AC or is it a DC pump with an AC/DC converter in the box and if so what DC voltage does the pump take? Does it take a special pump tube like the BRS ATO pump or can you use any standard silicone tubing to replace the internal pump tubing?
