[Help] How to update wifi firmware
Posted: Sun Oct 20, 2013 11:01 am
by Rodasphoto
I downloaded Cool Term and Tera Term. I can not figure out how to use these programs to update my Wifi Module to see if it fixes my system (PWM not dimming, system locking up, wifi not responding). My problems started when I added a 2nd relay box and I have not been able to get the whole system to work properly. :evil:
Re: [Help] How to update wifi firmware
Posted: Sun Oct 20, 2013 2:34 pm
by Piper
Check all of your cable connections. It's usually a USB connection or cable thta causes that.
Posted: Sun Oct 20, 2013 2:52 pm
by Rodasphoto
I had the issue at first but do not know what to do next. The wifi utility does not work since the company was bought out and the ftp addresses have changed.
Posted: Sun Oct 20, 2013 3:28 pm
You must connect to the module using the same com port you use to upload codes to RA.
Try baud rate 57600. If you do a factory reset, the baud rate changes to 9600.
Once you are connected, you must type $$$ to enter command mode.
The manual has more instructions too.
Posted: Mon Oct 21, 2013 4:42 pm
by Rodasphoto
I missed that. I got it updated.
