Lunar hub dimming
Posted: Mon Oct 21, 2013 3:22 pm
by Dctrojan
I am running the lunar dimmable hub with 2 moonlights they are plugged into the high ato port . I was windering if there was a way to manually dim them.
Re: Lunar hub dimming
Posted: Mon Oct 21, 2013 3:39 pm
You mean, with a potentiometer?
Posted: Mon Oct 21, 2013 4:58 pm
by Dctrojan
Sorry didnt mean manually. Wasnt sure what I was thinking. I mean is there a way I can dim them with my phone not just have them dim according to the moon?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Posted: Mon Oct 21, 2013 5:40 pm
Have you used the android app and are you comfortable with using internal memory settings yet?
We can code it to do that, but you need a way to tell the controller what the % of dimming that you want, instead of moonphase.
Easiest way is to use the internal memory.
Posted: Mon Oct 21, 2013 5:51 pm
by Dctrojan
Yes I think im getting alot better at this and starting to understand . The android app im using allows me to monitor and change the relays but I cant change the dimmer. Ive looked at the internal memory writing feature on the app but im completely clueless to write it without the wizard especially to the lowato port im using. Ive been reading about adding custom menus . Would this be possible to add a custom menu so I can change the dimmer effect with the menu on the app?
Posted: Mon Oct 21, 2013 5:52 pm
by Dctrojan
Plus I would like to compliment you and the forum for all the support. Not many other companies have this kind of support.
Posted: Mon Oct 21, 2013 6:01 pm
So, let's use one memory location.
Use this instead:
  pinMode(lowATOPin,OUTPUT);
  if (InternalMemory.LEDPWMActinic_read()<=100)
    analogWrite(lowATOPin,InternalMemory.LEDPWMActinic_read()*2.55);
    analogWrite(lowATOPin,MoonPhase()*2.55);
Then, using the android app, go to internal memory and look for LEDPWMActinic in the list.
If you write a value from 0-100, it will override the port to whatever you choose. Any value from 101-255 will place the port on moonphase cycle.
Posted: Mon Oct 21, 2013 6:02 pm
by Dctrojan
Thats what I like to see . Thank yoj so much as soon as I get out of class im going to add this.
Posted: Mon Oct 21, 2013 6:07 pm
by Dctrojan
Could a custom menu be added in the future to control this function later on?
Posted: Mon Oct 21, 2013 6:08 pm
Although you can, it requires a lot of code to do this in the controller itself.
We can easily do a preset %, so you can choose the menu choice and it would go to that % and choose the menu again to put back into moonphase.
Posted: Mon Oct 21, 2013 6:11 pm
by Dctrojan
Hmm sounds like a plan in the future. as im learning more about this coding stuff. Is there any resource you would recommend that has a list of all the code functions ?
Posted: Mon Oct 21, 2013 7:35 pm
by Dctrojan
ok heres what I coded:
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.MoonLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.ActinicLights( Port4 );
    ReefAngel.WavemakerRandom1( Port5,10,60 );
    ReefAngel.WavemakerRandom2( Port6,5,10 );
    ReefAngel.SingleATOHigh( Port7 );
    ReefAngel.StandardHeater( Port8 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.Portal( "Dctrojan" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,76, "PHE:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,76, 100 );
}/code]
However, I cant change the setting back to moonlight dimmer using internal memory on my controller. I can control the brightness of the lunar module from 0-100 but when i type in 101 it tells me only values 0-100 available.
Posted: Tue Oct 22, 2013 6:04 pm
by Dctrojan
Posted: Tue Oct 22, 2013 6:11 pm
Whenever you pick a memory location, it shows the position right underneath it.
You can use that location number and pick custom to change it for more than 100.
Posted: Sun Jan 19, 2014 6:53 pm
by dapg8gt
So what would I replace in the above code if I was using the Actinic channel on the relay box to be able to control it thru the Android app? And does it go into the custom code lines?
I am not sure I even have it right the way I hooked it up today didn't see a reference to the lunar hub in the wizard so I guessed by hitting moon phase in the Actinic dimming type it will automatically do it. Is that right?
Posted: Sun Jan 19, 2014 9:15 pm
Yeap. It will adjust the channel according to the moon cycle for that day.
