I know I have read on the forum some where about reset a ATO alarm while away from home.
I have not been able to find this info again thou.
What is the best way to set up to be able to do this remotely?
thanks
riggeek
ATO alarm remote reset
- lnevo
- Contact:
Re: ATO alarm remote reset
that depends on what you use while away from home. the android app makes it really easy as there is a button on the Commands page that clears it for you. otherwise, I don't recall if this capability is in the portal. I would think that it is but I don't use the portal so I can't confirm. the last choice is to use the direct command from a web browser to clear it.riggeek wrote:I know I have read on the forum some where about reset a ATO alarm while away from home.
thanks
riggeek
http://YOURIP:2000/mt
that's the direct command to clear it.
Sent from my Nexus 7
riggeek
thanks for the info everyone.
I will work on this when I get home in about 1.5 weeks
riggeek
