water level below % help
Posted: Fri Nov 01, 2013 2:39 pm
by Smotz
Can someone tell me why this isn't working?
// EMERGENCY SUMP WATER LEVEL BELOW 20%
if ( ReefAngel.WaterLevel.GetLevel(1) <= 20 ) {
ReefAngel.Relay.Off(Return);
ReefAngel.Relay.Off(Skimmer);
ReefAngel.Relay.Off(UVlight);
ReefAngel.Relay.On(Fugelight);
The return doesn't go on with this code. However, the skimmer does, and the Fugelight doesn't.
Re: water level below % help
Posted: Fri Nov 01, 2013 2:52 pm
You should put it as the last bit of custom code...otherwise other functions may override it..
Posted: Fri Nov 01, 2013 3:21 pm
by Smotz
doesn't it not even look at the statements if the 'if' statement isn't true?
Posted: Fri Nov 01, 2013 3:42 pm
If this if isnt true it wont execute any of the code in the {} but you were talking about the return not being on which isnt in any of that code...
Posted: Fri Nov 01, 2013 3:46 pm
by Smotz
lnevo wrote:If this if isnt true it wont execute any of the code in the {} but you were talking about the return not being on which isnt in any of that code...
with the code, the return doesn't go on. when i comment out the code, the return goes on as normal.
this is in the code..
Posted: Fri Nov 01, 2013 3:51 pm
Whats the water level at?
Posted: Fri Nov 01, 2013 3:53 pm
by Smotz
98%
Posted: Fri Nov 01, 2013 7:14 pm
by Smotz
here's the whole code
//// Port 1 Heater
//// Port 2 ATO pump
//// Port 3 NOT USED
//// Port 4 Protein Skimmer
//// Port 5 Return Pump
//// Port 6 Wavemaker
//// Port 7 UV Sterilizer
//// Port 8 Fan
//// BOX 1 PORT 8 Fuge Light
#define Heater Port1
#define Topoff Port2
// #define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define UVlight Port7
#define Fugelight Port8
#define Fan Box1_Port8
#define FugelightBit 1<<7
#define UVlightBit 1<<6
#define WaveBit 1<<5
#define ReturnBit 1<<4
#define SkimmerBit 1<<3
// #define ReactorBit 1<<2
#define TopoffBit 1<<1
#define HeaterBit 1<<0
static byte wpMode;
static byte wpWavStr;
static byte wpWavOff;
ReefAngel.FeedingModePorts = SkimmerBit | ReturnBit | TopoffBit;
ReefAngel.WaterChangePorts = HeaterBit | SkimmerBit | ReturnBit | TopoffBit | WaveBit;
ReefAngel.LightsOnPorts = FugelightBit;
ReefAngel.OverheatShutoffPorts = HeaterBit | TopoffBit | SkimmerBit | ReturnBit | WaveBit;
// Use T1 (SUMP) probe as temperature and overheat functions
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( Wave );
ReefAngel.StandardHeater( Heater );
ReefAngel.MoonLights( Fugelight );
ReefAngel.StandardFan( Fan );
ReefAngel.SalMax=InternalMemory.SalMax_read(); // this allows salinity internal memory changes made one the mobile app to be instant - no reboot needed.
ReefAngel.Relay.DelayedOn(Skimmer,3);
// Water Levels
// ReefAngel.WaterLevel.GetLevel
// Main Top Off
if ( ReefAngel.WaterLevel.GetLevel(2) >= 10 ) // Ensure there is 10% of water in the Top Off reservoir
if ( ReefAngel.WaterLevel.GetLevel(1) <= 78 ) ReefAngel.Relay.On(Topoff);
if ( ReefAngel.WaterLevel.GetLevel(1) >= 100 ) ReefAngel.Relay.Off(Topoff);
if ( ReefAngel.Params.PH>850) ReefAngel.Relay.Off(Topoff); // Turn off top off if PH is greater than 8.5
// if the hour is 6a and minute is 58 and seconds is 0 start the feeding mode
if ( ((hour() == 6)) &&
(minute() == 58) &&
(second() == 0) ) {
ReefAngel.FeedingModeStart(); }
// end feeding mode
// Custom Wave Routine
// set the wpMode based on what time it is
if ( (hour() >= 2) && (hour() < 5) ) wpMode=2; // from 2am - 5am
if ( (hour() >= 5) && (hour() < 8) ) wpMode=1; // from 5am - 8am
if ( (hour() >= 8) && (hour() < 11) ) wpMode=2; // from 8am - 11am
if ( (hour() >= 11) && (hour() < 14) ) wpMode=3; // from 11a - 2pm
if ( (hour() >= 14) && (hour() < 17) ) wpMode=2; // from 2pm - 5pm
if ( (hour() >= 17) && (hour() < 20) ) wpMode=1; // from 5pm - 8pm
if ( (hour() >= 20) && (hour() < 23) ) wpMode=2; // from 8pm - 11p
if (hour() >= 23) wpMode=3; // from 11pm - midnight
if (hour() < 2) wpMode=3; // from midnight - 2am
// set the Wave Strength based on wpMode
if (wpMode==1) wpWavStr=45;
if (wpMode==2) wpWavStr=50;
if (wpMode==3) wpWavStr=55;
//Set the Wave OffSet
wpWavOff=15;
ReefAngel.PWM.SetDaylight( ReefCrestMode(wpWavStr,wpWavOff,true) );
ReefAngel.PWM.SetActinic(wpWavStr);
// end Custom Wave Routine
ReefAngel.PWM.SetActinic(30);
ReefAngel.PWM.SetDaylight(30);
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
// DC Return Pump using internal memory
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,InternalMemory.LEDPWMActinic_read()*2.55);
// END DC Return Pump
// Only turn on UV Sterilizer between 11pm and 4am
if ( (hour() >= 4) && (hour() < 23) ) // from 4a - 11p
else ReefAngel.Relay.On(UVlight);
ReefAngel.Portal( "Smotz","148497" );
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 5, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 5, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,20,80, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,44,80, ReefAngel.Params.Salinity );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 105, TempRelay );
// Date and Time
//draw the mode on the screen
char buf[16];
char buf2[16];
char buf3[32];
sprintf(buf,"RC %d%% +/- %d%%",wpWavStr,wpWavOff);
sprintf(buf2,"Wave Mode = %d%",wpMode);
sprintf(buf3,"Return Power = %d%",InternalMemory.LEDPWMActinic_read());
ReefAngel.LCD.DrawText(0,255,10,40,buf3);
ReefAngel.LCD.DrawText(0,255,20,60,buf);
ReefAngel.LCD.DrawText(0,255,20,50,buf2);
Posted: Fri Nov 01, 2013 8:33 pm
You have nothing to turn the return port back on.
Your Relay.On is on setup().
Move it to loop and it should work.
Posted: Fri Nov 01, 2013 8:48 pm
by Smotz
That did it. Thanks Guys.
