PWM fried
Posted: Wed Nov 13, 2013 7:09 am
Hi,
I have been trying to get the PWM expansion module to work for my led lighting setup for some time now and I can't seem to get one to work. I have purchased 2 by this point, the first one had a burn spot on the board.
Let me give you a little background on my setup:
I have a 250 watt 48v power supply from ledgroupbuy
250w 48v 5.2a dc power supply
I have 2 meanwell ldd-500hw led drivers from ledgroupbuy
I have 4 meanwell ldd - 1000hw led drivers from ledgroupbuy
There are 72 leds total in 5 different color arrays hooked up to the different drivers. I used the white wires (which are marked dimming) on the drivers to hook up to the PWM. The first PWM worked for about 4 days then started smoking (which also killed the drivers). I repurchased the drivers, the power supply and the PWM (figuring something in the wiring was bad, I had bought the light array and power supply used). I rewired everything and the lighting works fine with no dimmer hooked up (its been running non-dimming for 3 weeks now), but dimmer when hooked up does nothing. I can add pictures if need be, I just would like to get the dimming feature working properly. I had no problem with the 2nd PWM module burning out, it just did nothing fresh out of the box. Let me know if I can send things back to see if there was a problem in the PWM, or what my readings should be from a voltmeter on the different channels.
