Programming cable
Posted: Thu Nov 14, 2013 2:44 am
by sabo
One wire has come loose on my cable, and im looking to either get a new plug for it if the local electronics store has it, or find a new cable. Ebay shows usb to serial cables for arduino. They are called RS232 cables. Is this the correct part?
This is the one I am looking at.
http://www.ebay.com/itm/6pin-FTDI-FT232 ... 1288360608
Programming cable
Posted: Thu Nov 14, 2013 6:10 am
Yes you could probably rma the one you have pm roberto
Re: Programming cable
Posted: Thu Nov 14, 2013 6:41 am
by sabo
It takes two weeks to get stuff from roberto. This cable should be quicker postage.
Posted: Thu Nov 14, 2013 11:47 pm
by sabo
Roberto, should that cable work? I have a new plug which should be ok to programme the wifi module, but it wont fit in the controller slot, so I need a new cable to programme the controller.
Posted: Fri Nov 15, 2013 5:43 am
It should work. It looks right.
Posted: Fri Nov 15, 2013 9:10 am
I think it is the same cable
Posted: Fri Nov 15, 2013 6:16 pm
by sabo
awesome, thanks.
Posted: Tue Dec 10, 2013 8:17 pm
by sabo
And it doesnt work. This wifi module is doing my head in
Posted: Tue Dec 10, 2013 8:53 pm
by KRavEN
You probably need to switch some of the wires around. Look at the schematic to make sure CTS, TX, RX, VCC, and GND are in the correct place.
Posted: Tue Dec 10, 2013 9:01 pm
Are you able to upload codes with this cable?
Is the driver installed correctly?
