Need help with controller
Posted: Tue Nov 19, 2013 9:39 pm
by lucho
Hi. I have had a Reef Angel for a couple of years now. It has mostly worked correctly, but I am having a lot of problem lately.
I have recently added a second relay, and maybe that is creating the problem. After a couple of hours I find that the controller will not work any more (e.g., lights will not turn on). It would basically keep the settings fixed. When I check the controller, I find the Status light blinking constantly, and the time and date be very far in the future (e.g., 11/29/2039). When I unplug and replug the controller, this gets fixed (correct time and date, normal functioning) for some hours and then eventually it stops working again.
Below is the code. Please help! What is happening? How do I fix this? Thanks!
// Define Relay Ports by Name
#define MainLights 1
#define Actinics 2
#define LightFans 4
#define Unused1 3
#define Unused2 5
#define ATOPump 6
#define Skimmer 7
#define Return 8
#define MP401 Box1_Port1
#define MP402 Box1_Port2
#define Sump Box1_Port3
#define MP10 Box1_Port4
#define DPump1 Box1_Port5
#define DPump2 Box1_Port6
#define Reactor Box1_Port7
#define Unused3 Box1_Port8
ReefAngel.FeedingModePorts = Port7Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit;
ReefAngel.Relay.On( Skimmer );
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( MP401 );
ReefAngel.Relay.On( MP402 );
ReefAngel.Relay.On( MP10 );
ReefAngel.Relay.On( Sump );
ReefAngel.DayLights( MainLights );
ReefAngel.ActinicLights( Actinics );
ReefAngel.ActinicLights( LightFans );
ReefAngel.WaterLevelATO( ATOPump );
ReefAngel.DosingPump1( DPump1 );
ReefAngel.DosingPump2( DPump2 );
//ReefAngel.DosingPumpRepeat3( Reactor);
//ReefAngel.StandardHeater( Heater );
// Pumps for night mode, start with lagoon, short pulse most of the day
if (ReefAngel.DisplayedMenu!=FEEDING_MODE || ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
if (hour()>=21 && hour()<=22)
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(LongWave,60,3);
else if (hour()>=23 || hour()<9)
ReefAngel.RF.SetMode(ReefCrest,40,0);
else if (hour()>=9 && hour()<=10)
ReefAngel.RF.UseMemory=true;
//Start feedmode when the feeder will kick in
//if ( (now()%86400==39480) || (now()%86400==50280) || (now()%86400==61080) )
// ReefAngel.FeedingModeStart();
ReefAngel.Portal( "lucho" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
Re: Need help with controller
Posted: Wed Nov 20, 2013 9:40 am
Are you using the latest libraries?
Posted: Wed Nov 20, 2013 3:03 pm
by lucho
I thought I was. What is the best way to check or update them?
Posted: Wed Nov 20, 2013 3:09 pm
It should update by itself.
You can go to menu Tools->Reef Angel Libraries Version to see what's installed in your computer.
Hit the joystick and go to Version in the controller to see what's installed in the controller.
Posted: Wed Nov 20, 2013 3:50 pm
by lucho
I have version 1.0.9 in the computer. I will check the controller tonight when I get home, but since I uploaded a code last month, I would think I have the same in the controller.
Posted: Wed Nov 20, 2013 4:57 pm
Your controller would not have a higher version than your computer :)
Posted: Wed Nov 20, 2013 5:10 pm
by lucho
Just checked and I have 1.0.9 in the controller. Is this the latest? If not, could you point me to where to read on how to update? I tries in the arduino software but could not find it. Thanks!
Posted: Wed Nov 20, 2013 8:13 pm
by lucho
Ok, upgraded to 1.1.0
Let's see what happens tomorrow.
Posted: Thu Nov 21, 2013 7:15 am
by lucho
Ok, so far so good. Checked this morning and seems to be working well for now
