Power outage alert
- jsclownfish
Power outage alert
Can the system be configured to alert me of a power outage?
- jsclownfish
Re: Power outage alert
I suppose as soon as it happens. I guess I'd need to both have the system alarm and notify me by wifi (web, iPhone, email, etc.) I've had a couple bad experiences with power failures and my reef tank. I'd imagine I'd notice a problem just by seeing the parameters change, but it would be good to know if I needed to get home and put a generator on the tank to keep the system from crashing.
-Jon
-Jon
Do you have your router and controller operatinal with a power backup unit when the power goes out?
I wonder if the RA is capable for tracking when the power was out (like length of time and when it was restored).
A very complicated way could be done to achieve this, but more research would need to be done.alexwbush wrote:I wonder if the RA is capable for tracking when the power was out (like length of time and when it was restored).
The theory of this is measure for brownout and save the time to memory right before voltage drops below 4.7V for example. Saving to memory is fast enough to happen before the controller looses it's power completely.
- jsclownfish
Good point, I do have a battery back-up for my phone VOIP phone service and I suppose the router could be plugged into it as well.
One way of doing it would be to have a power backup unit on the RA system and use a modified wall wart to tell RA that there is power or not on the house.
You can use one of of the ATO ports as input for this modified wall wart.
- jsclownfish
Could a simple battery pack be used as a power back-up on the controller along with the a modified wall wart to power the controller long enough to send a notice that the main power has gone out?
-Jon
-Jon
- jsclownfish
So would I have to make a junction between the serial connection or can the master controller feed off the slave if there was a battery set connected to the 5v/gnd lines?
The master could feed off of the slave, but it is really not designed for that.
The best option I see is to use a small UPC. It will maintain RA long enough for your email alert.
- jsclownfish
Makes sense. I'll just get something like this....http://www.amazon.com/CyberPower-CP425S ... 60&sr=1-17. I was just thinking about the options and a small battery pack is really inexpensive.
-Jon
-Jon
Any suggestions on how to hook up to a APC battery back up system? I currently have one on both my PC, router and another on the tank. There are 4 outlets (out of 8) on the UPS that are battery backed up. Here is what I am thinking...
-use one of the non-battery backed outlets with the suggested wall wart to indicate loss of power.
-use one battery backed outlet for the RA
-use one battery backed outlet to plug the relay box into
-program the ATO port used to indicate the loss of power, to shut down everything except the return and skimmer (for oxygenation).
Yes, that would work great!!
Just make sure not to feed more than 5VDC into the ATO port.
What kind of wall wart would you suggest? I tried looking a few up but have no idea which one to get or how I would connect it to the pwm port. I would like to integrate this into my controller as well. Do you think this kind of thing might be useful to provide on your guys' online store?
You can use any regulated 5VDC walwart. The best ones are the ones made for cell phones and have a USB plug in it. USB uses 5VDC as standard.
Get a good quality one or you will end up frying the controller. I've seen them output more than 5VDC.
What about a 3vdc supply? You said not more than 5vdc, so what is the LO threshold that indicates loss of power?
You are very right about the 5Vdc wall warts, I checked several and they were all off. Most were in the 7vdc range. One of my 12vdc supplies was actually at 17vdc!
Found a usb charger like you described for an old blackberry. Says 5V output @ 700mA, I'll verify the 5V with a multimeter but assuming its accurate this should work? If both my ATO ports are in use can I use any of the ports on the relay box?
Okay, tested out the adapter and it seems to put out around 4.95-5.17 VDC. I'm assuming this will be okay to hookup using my ATO High switch port? That said, could you give an example of code I test if power did fail? For example, I would like it to deactivate port 1 and 2 on the main relay box along with port 3 and 4 on the relay expansion box. Once power is restored I would then like to enable the disabled relays. Thanks in advance!
Try this.
On setup():
Your loop() need to look like this:
ShowInterface() has to be the last line and the check has to be right above it.
On setup():
digitalWrite(highATOPin,LOW);
// Your code goes above here
if (!digitalRead(highATOPin))
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.Off(Port2);
ReefAngel.Relay.Off(Box1_Port3);
ReefAngel.Relay.Off(Box1_Port4);
So it looks like I shorted the ATO high port out.
I made sure to connect up the adapter with the correct +/- sides using indications on the existing ATO switch cables. When I hooked up the adapter to the ATO high port my tank lights flashed on and the red status light started blinking. I shut off the adapter (I had it plugged into a surge strip for easy on/off).
Now the ATO high port indicates there's no power going to it, even though the float switch is all the way down. Just to make sure it wasn't the actual float switch, I hooked up the other one and got the same indication. I went ahead and modified my ATO code so that it will at least top the tank off, as I was using the ATO high as a safety in case the pump or something malfunctioned. But I had to take that out, since it registers as open instead of closed keeping the ATO pump from engaging.
Thought I was doing everything right...![Sad :(](./images/smilies/icon_e_sad.gif)
Do you still have this on the setup()?
If so, you are disabling the port for use as ATO as it is actually using pull-down instead of pull-up.
No, I reverted back to my old code to make sure it wasn't something that I had done since. Also the RA Client shows the ATO Hi as red, normally it's green since the switch is all the way down making contact.
Here's my code just in case:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Daylight 1
#define AutoTopOff 2
#define Heater 3
#define Return 4
#define WavemakerL 5
#define WavemakerR 6
#define LEDs 7
#define Refugium 8
#define AlkDoser 13
#define CaDoser 14
#define AclHeater 17
#define GFO 18
randomSeed(analogRead(0)); //wm stuff
ReefAngel.FeedingModePorts = B00111000;
// ReefAngel.WaterChangePorts = B00000000;
// ReefAngel.OverheatShutoffPorts = B00000101;
// ReefAngel.LightsOnPorts = B00000001;
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(GFO);
//WaveMaker stuff
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(WavemakerL);
// ReefAngel.StandardFan(Chiller,775,783); Removed for ATO function
// ReefAngel.StandardHeater(Heater,785,79);
ReefAngel.StandardLights(Daylight,10,0,21,00); //Daylight schedule 10:00am - 9:00pm
ReefAngel.StandardLights(Refugium,21,0,10,0); //Refugium schedule 9:00pm - 10:00am
ReefAngel.StandardLights(LEDs,9,00,22,00); //LED schedule 9:00am - 10:00pm
ATOFailSafe(AutoTopOff); //ATO Stuff
//Heater Temp Settings
// Turn on Heaters when the temp < 78.8 degrees
if ( ReefAngel.Params.Temp1 < 788 ) ReefAngel.Relay.DelayedOn(Heater, 1);
// Turn off Heaters when the temp > 78.6 degrees
if ( ReefAngel.Params.Temp1 >= 791 ) ReefAngel.Relay.Off(Heater);
//Acclimation Heater Temp 2 settings
// Turn on AclHeater when the temp < 78.8 degrees
if ( ReefAngel.Params.Temp2 < 788 ) ReefAngel.Relay.DelayedOn(AclHeater, 1);
// Turn off AclHeater when the temp > 79.1 degrees
if ( ReefAngel.Params.Temp2 >= 791 ) ReefAngel.Relay.Off(AclHeater);
//Wavemaker
ReefAngel.Timer[1].SetInterval(random(15,30));
ReefAngel.Relay.Toggle(WavemakerL); //port 5
ReefAngel.Relay.Toggle(WavemakerR); //port 6
//Dose Ca
if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Ca Doser - Only works if Main screen is showing
/* && = and || = or
Hours between 12am and 8am
minute must be 0 (top of the hour)
seconds less than 2 (up to 2 seconds)
if ( ((hour() >= 0) && (hour() <= 8)) && (minute() == 0) && //dose time
(second() < 2) ) //dose duration
ReefAngel.Relay.On(CaDoser);
ReefAngel.Relay.Off(CaDoser);
//Dose Alk
if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Alk Doser - Only works if Main screen is showing
/* && = and || = or
Hours between 12:05am and 8:05am
if ( ((hour() >= 0) && (hour() <= 8)) && (minute() == 5) && //dose time
ReefAngel.Relay.On(AlkDoser);
ReefAngel.Relay.Off(AlkDoser);
void ATOFailSafe(byte ATO) //changed port to fATO
// Check for the low switch
If the Low switch is active, meaning the float is opposite the end with the two wires,
we are empty so we should turn on the pump. Otherwise, we are full, so turn off the port.
if ( ReefAngel.LowATO.IsActive() )
ReefAngel.LowATO.StartTopping();
ReefAngel.Relay.On(ATO);
ReefAngel.LowATO.StopTopping();
ReefAngel.Relay.Off(ATO);
PM me if you want to replace.
I went back and read what you wrote and I think the confusion was on the part where you followed the markings on the ATO cable.
The ATO float switches use the same pinout as the PWM output ports.
You can find the pinout in the user manual.
How about a 5v supply that outputs 30v...
My poor ReefAngel... she didn't deserve that. She didn't do anything to anyone.
![Confused :?](./images/smilies/icon_e_confused.gif)
Shout out to the creator of our angels... he takes good care of them. Roberto, this next drink is for you.
![Cool 8-)](./images/smilies/icon_cool.gif)
PM Sentrimai wrote:PM me if you want to replace.
