WaveMaker not functioning
Posted: Wed Nov 02, 2011 6:31 am
by jemw
I generated code using RAGen and added my moonlights and a 2 minute delay on port 3. Ports 5 and 6 are for Wavemaker1 and Wavemaker 2. I fired up ReefAngel Client (v2.2) and changed wavemaker 1 & 2 from 0 to 10, but ports 5 & 6 are still always on.
Re: WaveMaker not functioning
Posted: Wed Nov 02, 2011 8:17 am
What does your PDE file look like?
Posted: Wed Nov 02, 2011 11:09 am
by jemw
My pde:
// Autogenerated file by RAGen (v1.1.0.126), (10/29/2011 06:54)
// RA_102911_Final.pde
// 02 Nov 2011: Incorporated my manual changes into the generated version
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Authentication does not work with ReefAngel Client at the moment
// WifiAuthentication("xxx:YYYYYY");
ReefAngel.FeedingModePorts = B11111100;
ReefAngel.WaterChangePorts = B11111111;
ReefAngel.OverheatShutoffPorts = B00000011;
ReefAngel.LightsOnPorts = B00000011;
// Set Actinic and Daylight (moonlight ports) off by default
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.MHLights(Port1);
ReefAngel.Relay.DelayedOn(Port3, 2); // Tunze here - wait 2 min before pwr on
ReefAngel.StandardFan(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
if ( hour() <= 5 || hour () >= 20 ) // Moonlights on from 8PM to 6AM
Posted: Wed Nov 02, 2011 7:16 pm
I just loaded the code and it works fine for me...
I had to reboot the controller after I made the changes with Client though.
Posted: Thu Nov 03, 2011 4:27 am
by jemw
rimai wrote:I just loaded the code and it works fine for me...
After power cycling the controller, it also works for me. Does this mean that all changes made to memory using ReafAngel Client require a power cycle of the controller?
Posted: Thu Nov 03, 2011 4:42 am
jemw wrote:rimai wrote:I just loaded the code and it works fine for me...
no they shouldn't. they get loaded immediately however with your cases of them being 0 to start with may have required a reboot. i'm not exactly sure though without testing it or looking more at the code.
Posted: Thu Nov 03, 2011 6:41 am
by jemw
binder wrote:jemw wrote:rimai wrote:I just loaded the code and it works fine for me...
After setting to 10 seconds and testing for timing, I went back and adjusted to 20 seconds. Allowed two minutes after making the change to observe the change did not happen. Again for the change to take place required a power cycle.
Posted: Thu Nov 03, 2011 7:28 pm
What version of the libraries are you running?
Posted: Fri Nov 04, 2011 5:58 am
by jemw
binder wrote:What version of the libraries are you running?
Dev Lib Version: 0.8.5.19
