Voltage specs for Cat 5e.
Posted: Sun Nov 24, 2013 7:34 pm
by Sacohen
I want to make a wiring snake for a bunch of 12v cables that I want to run from my RA+ controller to my garage, (probably about 35-40 feet).
Can Cat 5e handle 12v and will the twisted wiring cause any problems or interference?
Re: Voltage specs for Cat 5e.
Posted: Sun Nov 24, 2013 7:45 pm
I think it should be fine.
Power over Ethernet specification states max current of 600mA, so as long as you don't draw more than that, you should be fine.
Posted: Sun Nov 24, 2013 8:12 pm
The twisting is to eliminate interference. No worried there. Its the amperage you need to worry about.
Posted: Mon Nov 25, 2013 1:36 am
by Sacohen
Thanks. I'm just going to be using 2 of the ATO or dosing pumps that are in the store.
1 more question. The description says that it can push or pull 10 or 8 feet, is that total or height.
It's going to go about 8' up then over 13' and 8' down.
Posted: Mon Nov 25, 2013 9:03 am
Everything will come down naturally here on Earth :)
It's inevitable unless you go for plastic surgery... lol
Just kidding... :twisted:
The pump will only have to push up and the horizontal/down part has virtually no resistance.
Posted: Mon Nov 25, 2013 9:40 am
by KRavEN
CAT5 can carry a pretty large current over short distances. Just make sure you're using the solid core wire and not the stranded. I'm using it for 1.5 amp LED strings over about a 3 meter distance with no problems. Cables don't get hot and I'm not loosing any throughput due to cable resistance.
Posted: Mon Nov 25, 2013 10:43 am
by Sacohen
Thanks everyone.
Pretty much what I thought about the head pressure, but I was just double checking.
I have one of the ATO pumps already so I may give it a try when I have some time, but I'm sure it will be fine.
