PWM BNC Stray voltage
Posted: Wed Nov 27, 2013 10:45 am
HI
Having an issue with stray voltage that I just cant figure out. I've got a std reef angel with a pwn addon unit. and standing barefoot on my tiles
Ive managed to track it down to something to do with the ELN drivers and the ph probe. If only the power to the drivers is connected. The pwm unit is not powered only the USB cable to the powerbox, and the ph probe is in the water. If i put my hand in the water i feel current. Even when i take the probe off the BNC connector and touch it without touching water i still feel current. And obv if there is no power on the ELN drivers the probe/BNC dont have that current on them
So some how power is traveling between the PWM unit through the USB cable to the plugbar then through to the Ph BNC/probe
Ive had this problem ever since I went LED with the PWM unit, so Ive been pulling my hair out trying to figure this out for over 6months now
Can anyone see what Im doing wrong as I doubt its the RA stuff otherwise this would have happened to many other ppl before
