Temperature not showing up.
Im not sure whats going on . last night i dripped a small drop of tank water in my controller. the lcd screen went blank, so i immediately opened up the unit and removed the LCD screen and used a cool blow dryer to dry up any moisture that may have gotten on the unit. well now today my temperature isnt showing up on my controller or my phone via wifi. The controller works perfectly still and the screen works too. is there anyway to test or run a diagnostic on the controller so maybe i can get the temp probe working again.
Re: Temperature not showing up.
Is it showing error on the LCD screen?
Check if there is no salt creep around the temp probe connectors in the pcb.
Yes it says error. Ill take it apart and take a look. Whats the best thing to clean it with ? By the way im thoroughly happy with the controller thus far. Its a great product.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Ok I got it working. It was the temp prob connection. I used a very small flathead screw driver and scraped the connections a couple of time and "poof" its working.
