Problems with reef crest mode
Posted: Thu Nov 28, 2013 10:51 am
by anderzon_
I have a problem with the reef crest mode. It works for a while then it's just like the pump stops at the lowest speed even though it says for example 95%. I've tried to reload the program, but it's the same thing. Anybody have a clue what it could be? I use jebao wp-25
If I pull the cord from the dimming port and put it back, so it works again.
Re: Problems with reef crest mode
Posted: Thu Nov 28, 2013 5:11 pm
by anderzon_
my code.
ReefAngel.SetTemperatureUnit( Celsius ); // set to Celsius
Temperature
ReefAngel.FeedingModePorts = Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit |
Port4Bit | Port6Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 270 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,250,254 );
ReefAngel.StandardLights( Port7,17,0,20,0 );
ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
ReefAngel.Portal( "anderzon_" );
should I delete this line:
Posted: Thu Nov 28, 2013 9:30 pm
by Sacohen
The Jebao pump have a problem going below a certain %. My WP-40 will not go below 20% (If I remember) without it stopping, while my WP-25 will not go below 30% without it stopping.
No I can't say these percentages are the same for everyone because I have seen other people have the same problem, but at different speeds.
Posted: Fri Nov 29, 2013 7:10 am
by cosmith71
My WP-25 shuts off at around 30% and won't come back on without pulling the plug.
Posted: Fri Nov 29, 2013 10:16 am
by anderzon_
thanks for your replies. It does not stop but it goes on very low speed even though it says 100%, it's only half maybe. If I pull the plug and put it back on again so is it as usual. Is it the pump that's wrong then? I removed the line of text I wrote before, I thought about it crashed in the code but it's the same problem though.
Posted: Sat Nov 30, 2013 5:16 am
by anderzon_
Must be something wrong with my dimming ports. Now the pump
Slow down even in constant mode. Is there any way to reset the relay box?
