Last night I noticed that my lights were off early for some reason. I didnt have time to check it out. I looked at the tank this morning and noticed that the lights did not come on. I have three sets of lights with different ballasts and none of them have come on. I will assume it's the dimming signal thats not present. I tried unplugging everything and restarting the reef angel hoping it would reset everything but no luck. I checked all the connections and everything seems to be ok. Any ideas on where to start? I dont know if it's the controller or the relay box.
Dimming feature inop
Re: Dimming feature inop
Use the controllertester code in the example codes folder to test the ports.
Does this test the ports on the controller or the relay box?
