PWm ports bad?
Posted: Fri Dec 06, 2013 7:11 pm
OK so i am not the best at this but i tested my leds using a AA battery( to jump the dimming wires) and they come on just fine. I tested the ports for the daylight pwm using a voltmeter and got nothing, so did i turn it off some how in the code? Also dont know if it matters but ports 1 and 2 on the relay box are dead.
ReefAngel.LightsOnPorts = Port6Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
ReefAngel.MHLights( Port3,11,0,16,30,6 );
ReefAngel.MHLights( Port4,2,30,19,30,5 );
ReefAngel.StandardFan( Port5,771,781 );
ReefAngel.StandardLights( Port6,9,0,21,0 );
ReefAngel.StandardHeater( Port7,770,780 );
ReefAngel.StandardLights( Port8,20,30,9,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,21,30,20,100,20) );
