help with jebao code
Posted: Sat Dec 07, 2013 3:44 pm
by Paulweck
im trying to add my new wp-25 to my already running wp-40 for my 90 gallon tank. im currently running tidal swell mode on my wp40. i would like to have them both on tidal swell mode but have one ramp up while the other ramps down. i will be plugging the wp25 into my dimming expansion in the 1st channel. i would also like the pumps go into nutrient transport mode when lights go out at 9pm
if any of you code gurus give me a hand with this that would be great im not to good at writing code yet but im starting to understand..
heres my code as its set right now with just my wp40 thanks again
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.FeedingModePorts = Port3Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port6Bit | Port7Bit;
    ReefAngel.StandardLights( Port1,21,0,9,0 );
    ReefAngel.StandardLights( Port2,11,0,19,0 );
    ReefAngel.Relay.DelayedOn( Port3,30 );
    ReefAngel.SingleATO( true,Port4,120,0 );
    ReefAngel.StandardLights( Port6,9,0,21,0 );
    ReefAngel.StandardHeater( Port7,790,795 );
    ReefAngel.DCPump.SetMode( TidalSwell,100,20 );
    ReefAngel.DCPump.ExpansionChannel[0] = None;
    ReefAngel.DosingPumpRepeat(Box1_Port1,540,720,45); // Alk Dose every 720 minutes with 540 minutes offset for 45 seconds
    ReefAngel.DosingPumpRepeat(Box1_Port2,600,720,45); // Ca Dose every 720 minutes with 600 minutes offset for 45 seconds
    ReefAngel.Portal( "paulweck" );
Re: help with jebao code
Posted: Sun Dec 08, 2013 9:46 am
To put the 1st channel of the dimming in anti-sync mode, you need to change this:
To this:
ReefAngel.DCPump.ExpansionChannel[0] = AntiSync;
For NTM at 9pm, when does it come out of it?
Posted: Sun Dec 08, 2013 10:24 am
by Paulweck
i would guess it depends on how long the cycle last i would like to run the cycle twice. thanks for you help Roberto
Posted: Mon Dec 09, 2013 8:58 am
It takes 2.5 hrs each cycle.
Posted: Mon Dec 09, 2013 8:38 pm
by Paulweck
then i would say 5 hours starting at 9pm. again thanks for the help
Posted: Mon Dec 09, 2013 9:51 pm
Try this:
if (hour()>=21 || hour()<2)
    ReefAngel.DCPump.SetMode( NutrientTransport,100,20 );
Posted: Tue Dec 10, 2013 5:42 am
Doesn't he need to turn UseMemory=false?
Posted: Tue Dec 10, 2013 9:31 am
His code already has :)
Posted: Tue Dec 10, 2013 10:23 am
My bad... I missed it.. that's what happens trying to read it from my phone...
Posted: Thu Dec 12, 2013 2:35 pm
by Paulweck
ok so i uploaded the code and its working but not correctly. when i first loaded the code my wp40 was at 60% and the wp-25 started at 50% there now both going up. i would like to have one at 50% and 100% and have the 50% go up and the 100% go down. if that makes sense. heres my code i just uploded.
ReefAngel.DCPump.ExpansionChannel[1] = AntiSync;
Posted: Thu Dec 12, 2013 4:01 pm
Thats what it should be doing...you have one pump set sync and the other anti sync...should be fine.
Posted: Thu Dec 12, 2013 4:50 pm
by Paulweck
The portal is telling me that both pumps are at 92% and falling and i think one is moving faster then the other
thanks for all the help by the way
