Two controllers same network
ganjero
Post by ganjero »
Is it possible to have two controller running in the same network with WIFI? would you have to create a second id to use portal?
Piper
Re: Two controllers same network
Post by Piper »
Should be no problem. You will just need to give one of the adapters a different port to use other than the default 2000.
~Charlie
Piper
Post by Piper »
One thing I didn't think about was the portal. You would need to set up two profiles on the forum in order to get the portal to work for both RAs.
bfeik
Post by bfeik »
ganjero wrote:Is it possible to have two controller running in the same network with WIFI? would you have to create a second id to use portal?
How did this work out for you. Id like to do the same thing??
I have multiple ra's on the same network and it works just fine. I do know of at least 1 person on the forum that has 2 accounts so he can have 2 ra's displayed in the portal. his complaint was having to log out and back in with the different usernames to view the data in the portal.
Sent from my Moto X
