Aquastyle led light Fixture AF-4060 High Power 10W LED 60W
Posted: Sun Dec 15, 2013 8:08 pm
Hi Guys,
I am about to purchase the following Aquastyle Online Fixture:
AF-4060 High Power 10W LED 60W dimmable Fixture
It has the following specifications:
6 LEDs
2 x Bridgelux white 10000K
2 x Bridgelux Royal blue
1 x Epiled Actinic violet 420nm
1 x Epiled RGB Mix-white
Each LED is 10W high power
Blue and white light dimmable
(one channel is 2 royal blue and 1 violet, another channel is 2 white and 1 RGB white)
Black anodized surface heatsink with Acrylic splah guard
High efficient Meanwell LPF-40D-42 dimmable drivers
100 degree reflector gives perfect coverage
Royal blue, red, green and violet spectrum benefit reef growth
12cm fan good cooling system
Fixture dimension: 16.5cm(W) x 9cm(H) x 41cm(L) (6.5"x3.5"x16")
Input voltage 100-240V
EU/UK/AU/US plug supplied as required
Can somebody please tell me if this is compatible with my RA+ (PWM) ?
Thanks in advance
Leslie
6 LEDs
Thanks in advance
Leslie
