Web chart is blanck
Posted: Mon Dec 16, 2013 3:02 am
by JHP
When I look on the web chart it is blank why?
Jan
Re: Web chart is blanck
Posted: Mon Dec 16, 2013 9:28 am
Your controller never sent data to the Portal.
Do you have the wifi attachment configured correctly?
Posted: Mon Dec 16, 2013 11:25 am
by JHP
Hmm I think it is
I can see temp ph etc.
Is ther a guide on the to used when setting up wifi ?
Posted: Mon Dec 16, 2013 11:27 am
Can I see your code?
Posted: Mon Dec 16, 2013 11:57 am
by JHP
I have just loaded standard code
dont know how to read code loaded in the reefangel
Posted: Mon Dec 16, 2013 12:03 pm
The standard code doesn't send data to the portal.
You will need to generate one with the wizard.
Posted: Mon Dec 16, 2013 12:09 pm
by JHP
is it on the download page ?
Posted: Mon Dec 16, 2013 12:14 pm
Go to menu Tools->Reef Angel Wizard
Posted: Mon Dec 16, 2013 12:27 pm
by JHP
thanks i found it :P
Posted: Mon Dec 16, 2013 12:43 pm
by JHP
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 320 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,9,0,23,0 );
ReefAngel.StandardLights( Port2,11,0,22,30 );
ReefAngel.StandardLights( Port3,11,0,23,0 );
ReefAngel.StandardLights( Port4,11,0,23,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(11,0,23,0,15,100,15) );
ReefAngel.PWM.SetActinic( PWMParabola(11,0,23,0,15,100,15) );
ReefAngel.Portal( "jhp" );
Posted: Mon Dec 16, 2013 12:56 pm
Ok, upload it and it should start sending data to the server
Posted: Mon Dec 16, 2013 1:12 pm
by JHP
How often is the data send to the server it is still blank :shock:
Posted: Mon Dec 16, 2013 1:16 pm
by JHP
the dash board is ok
Posted: Wed Dec 18, 2013 8:56 am
by JHP
Still not working :oops:
you can see if I send data
Posted: Wed Dec 18, 2013 9:21 am
No, I don't see any data.
Can you send me the dump from the "get e" command?
You will need to use tera term or putty to access the command mode on the module.
Check the manual for instructions.
Posted: Wed Dec 18, 2013 9:26 am
by JHP
ok I will do it the next days ;-)
Posted: Tue Sep 16, 2014 9:43 pm
by acabano
Hi Roberto,
I think i have the same issue.
my web banner is also blank, here's my wifi info, thanks.
<4.00> get e
wifly-GSX Ver 4.00, Mar 27 2013 13:52:34 on 131C11
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=0.0.0.0
Name=name.no-ip.biz
Backup=rn.microchip.com
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=xxxxxxxxxx
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Posted: Wed Sep 17, 2014 8:16 am
This is supposed to be www.reefangel.com:
Name=name.no-ip.biz
Posted: Wed Sep 17, 2014 9:05 pm
by acabano
Hi Roberto,
I have change the dns name to http://www.reefangel.com but that did not help.
looks like i am sending data.
<RA><ID>acabano</ID><T1>800</T1><T2>1211</T2><T3>800</T3><PH>754</PH><R>18</R><RON>64</RON><ROFF>223</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>70</PWMA><PWMD>70</PWMD></RA>
<4.00> get e
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=0.0.0.0
Name=www.reefangel.com
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=xxxxxxxx
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Posted: Wed Sep 17, 2014 10:02 pm
You are setting the ip manually, right?
These are the differences I noticed:
FLAGS=0x6
DNS is not setup. It must be setup. Ask your ISP which DNS server they use.
I think when you set the DNS, you should be able to connect.
Posted: Fri Sep 19, 2014 9:47 pm
by acabano
Yes, ip is static. i have found the primary dns on my router "u verse" 3801HGV
<4.00> get e
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=x8.9x.1x6.x
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=xxxxxx
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Posted: Sat Sep 20, 2014 8:46 am
I kind of feel that you are using the wrong ip address.
Are you able to connect to your controller?
Did you try letting the wifi attachment just get the ip from DHCP?
Posted: Sat Sep 20, 2014 10:27 am
by acabano
I was able to control/see update on my iPhone 5s, but the graph does not work, same with portal web chart.
I can ping my controller, port 2000 is open. I'm not sure the DNS ip i have tried both the dns ip from my router GUI
Thanks for looking.
Posted: Mon Sep 22, 2014 8:41 am
Does it work if you simply let it work with DHCP?
Posted: Mon Sep 22, 2014 9:36 pm
by acabano
Hey Roberto,
Thanks a bunch, once DHCP is enabled web chart works.
