So it has been about a year since I have uploaded code and I recently moved my tank. I went through the wizard (first time using this instead of RA gen) and I keep getting an error when I try to upload code. The output is as follows:
Watchdog Timer
Version Menu
Wifi Attachment
Custom Main Screen
pH Expansion Module
Simple Menu
Binary sketch size: 30,932 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM8 -b115200 -D -V -Uflash:w:C:\Users\rk016069\AppData\Local\Temp\build4831348988593648627.tmp\RA_121613_2210.cpp.hex:i
Using Port : \\.\COM8
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
I also do not see the correct status of my ports on my iphone app either. Any suggestions would be greatly appreciated!! Thanks!
Ryan
Error uploading new code
knapp870
Re: Error uploading new code
Is it an RA or RA+?
Make sure you have the correct board under Tools->Board.
knapp870
It is the RA. And of course I look and the wrong board is selected. I will try tonight and update the group. Thanks so much! Can't believe I overlooked that. You can tell I was pretty rusty.
