Hi,
as stated above, port 1 & 3 are not supplying power.
Its a standard system, analogue dimming.
Everything else is working, and if I swop my plug from port 1 (return) into port 2(Tunze) It works. same for port 3.
Code is generated from the wizard.
Relay box 1&3 not giving power
Naptalene
Naptalene
Re: Relay box 1&3 not giving power
I can hear the relays clicking if I switch them, and I know there's a delay on port 3
Naptalene
PLEASE DELETE!!!!!
So the skimmer kicks in suddenly........ at my heater on temp....... Apparently I had the labelling on my relay box backwards ie 1 was 8, 2 was 7 etc. I must have turned the box around before I started.......
Sorry
Sorry
