White screen with Reef Angel Wizard Code
Posted: Sat Jan 04, 2014 10:36 am
by jegillis
Just got my RA, attempted to use the Wizard and using the code LCD screen goes white with occasional flickers If I restore the original code the screen works again. Below is the code the Wizard generated. Any help is appreciated I know nothing about what any of this code means.
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.SingleATO( true,Port1,360,0 );
    ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port3 ) );
    ReefAngel.StandardLights( Port3,13,0,23,0 );
    ReefAngel.StandardLights( Port4,13,15,22,15 );
    ReefAngel.PWM.SetDaylight( PWMParabola(13,15,22,15,15,23,15) );
    ReefAngel.PWM.SetActinic( PWMParabola(13,0,23,0,15,28,15) );
Re: White screen with Reef Angel Wizard Code
Posted: Sat Jan 04, 2014 11:10 am
Weird.
They all share the same underlying code.
Did you try any of the example codes?
Posted: Sat Jan 04, 2014 1:30 pm
by jegillis
Just tried the controller tester example code, same thing no screen came right back when I restored original code. Looks like it is still controlling the relays though
Posted: Sat Jan 04, 2014 1:51 pm
by jegillis
Well just used a windows machine instead and its was fine, went back to the Mac afterwords and it worked also. No idea what just happened but I will keep an eye on it.
