RA status log
- Rodasphoto
- Contact:
- lnevo
Re: RA status log
Your banner which you have wrong in your signature shows that your ph is 8.04
You need to add [ img ] tags around it [ /img ] (take away the spaces between the brackets. )
- Rodasphoto
- Contact:
Re: RA status log
Thanks for the heads up on how to fix my signature. I have been meaning to fix that. On my phone it logs temp but not pH using the RA Status app.
- lnevo
- Rodasphoto
- Contact:
ReEfnWrX
Re: RA status log
That is strange, everything on the Android App has been working wonderfully for me...
Is it displaying the pH level on your RA display itself?
- Contact:
Re: RA status log
the value should show on the Android screen unless you have turned off (hidden the visibility) of the ph. check the controller settings and then visibility and make sure ph is checked.
if you view the history, it only shows the temperature values in the list but if you tap on the entry it brings up a window that shows all the values except the relays.
hopefully that helps a little.
Sent from my Nexus 7
- Rodasphoto
- Contact:
Re: RA status log
The pH is set to display. I can see the pH when I click on each individual time parameters are recorded. I would like to see how it changes over time.binder wrote:the value should show on the Android screen unless you have turned off (hidden the visibility) of the ph. check the controller settings and then visibility and make sure ph is checked.
