Values passed to Relay.DelayedOn
jemw
In addition to setting a 1 minute delay to:
ReefAngel.Relay.DelayedOn(Port1, 1);
I would also like to set a schedule for on/off times.
Is this possible? What are the values the function accepts? OR Where can I find them in the code?
Thanks!!
Jim
Thanks!!
Jim
_____
Jim
Jim
jemw
Re: Values passed to Relay.DelayedOn
The ReefAngel.Relay.DelayedOn function accepts the port as the first argument and the time of the delay as the second argument. Will it accept additional arguments such as time on/time off?rimai wrote:Can you explain a little more?
_____
Jim
Jim
Oh, no it won't.
So, you would like have the port work on time schedule, but if it is stopped by feeding/water change mode or power cycle, it should delay start, is that it?
alexwbush
couldn't you just enclose this in an if statement based on the hour?
jemw
Correct!rimai wrote:Oh, no it won't.
_____
Jim
Jim
One easy way to do this would be leaving the function the way it is and use another one to turn it off when it is within the timeframe for turn off.
So, use this:
Try this out and see if it works for you.
So, use this:
if (NumMins(hour(),minute()) <= NumMins(8,0)) ReefAngel.Relay.Off(Port1) // Turn off Port1 before 8am
if (NumMins(hour(),minute()) >= NumMins(22,0)) ReefAngel.Relay.Off(Port1) // Turn off Port1 after 10pm
jemw
rimai wrote:One easy way to do this would be leaving the function the way it is and use another one to turn it off when it is within the timeframe for turn off.
So, use this:Try this out and see if it works for you.Code: Select all
ReefAngel.Relay.DelayedOn(Port1, 1); if (NumMins(hour(),minute()) <= NumMins(8,0)) ReefAngel.Relay.Off(Port1) // Turn off Port1 before 8am if (NumMins(hour(),minute()) >= NumMins(22,0)) ReefAngel.Relay.Off(Port1) // Turn off Port1 after 10pm
Thanks!!
_____
Jim
Jim
jemw
Don't we need code to turn it on?rimai wrote:One easy way to do this would be leaving the function the way it is and use another one to turn it off when it is within the timeframe for turn off.
_____
Jim
Jim
Hum.. you are right, but that would also disable the DelayedOn() function.
So I guess we scratch this code.
Try this one instead:
if (NumMins(hour(),minute()) >= NumMins(8,0) && NumMins(hour(),minute()) <= NumMins(22,0)) ReefAngel.Relay.DelayedOn(Port1, 1); else ReefAngel.Relay.Off(Port1);
