Dimming expansion
Posted: Mon Jan 13, 2014 11:05 pm
by chapboogie
I just setup my dimming expansion, and moved my lights over to it in channels 0&1. Now when I use the lights on command it won't work because of not knowing where to dim. How do I modify?
Sent from my SCH-I535 using Tapatalk
Re: Dimming expansion
Posted: Wed Jan 15, 2014 11:35 am
Which port is your drivers connected to?
Or what do you have for ReefAngel.LightsOnPorts ??
Posted: Wed Jan 15, 2014 3:08 pm
by chapboogie
My lights are now in channels 0&1 of the expansion. The sketch shows lights on ports= Port5bit and Port6bit
Posted: Wed Jan 15, 2014 3:57 pm
Try this:
  if (ReefAngel.Relay.isMaskOn(Port6))
    ReefAngel.PWM.SetChannel(0,50);
    ReefAngel.PWM.SetChannel(1,50);
Posted: Wed Jan 15, 2014 10:58 pm
by chapboogie
I don't know where to put this. This is my first edit from something that was made in the wizard.
Posted: Wed Jan 15, 2014 11:07 pm
by chapboogie
This is my sketch
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.LightsOnPorts = Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit;
    InternalMemory.OverheatTemp_write( 843 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.Relay.DelayedOn( Port2,10 );
    ReefAngel.SingleATO( true,Port3,2000,0 );
    ReefAngel.StandardHeater( Port4,796,814 );
    ReefAngel.StandardLights( Port5,13,0,23,0 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(13,0,23,0,9,75,9) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(13,30,22,30,9,54,9) );
    ReefAngel.PWM.SetChannel( 2, MoonPhase() );
    ReefAngel.DCPump.SetMode( ReefCrest,90,10 );
    ReefAngel.DCPump.DaylightChannel = AntiSync;
    ReefAngel.Portal( "chapboogie" );
Posted: Thu Jan 16, 2014 5:41 am
See the comments where it says place your custom code above and below here? Thats where it goes.
Posted: Fri Jan 17, 2014 7:17 pm
by chapboogie
It works now. Thanks a bunch. So much I want to tackle soon.
