Dissolved Oxygen Module.
Posted: Sat Jan 18, 2014 12:15 pm
by abhi_123
any chances of getting them in near future?
Re: Dissolved Oxygen Module.
Posted: Sat Jan 18, 2014 12:27 pm
There are no plans for such module.
Would you still be interested if you knew the probe alone costs more than $200?
Posted: Sat Jan 18, 2014 12:35 pm
by abhi_123
rimai wrote:There are no plans for such module.
hmmmm... cant we have something like this
https://www.atlas-scientific.com/produc ... .html#!/~/
Posted: Sat Jan 18, 2014 12:39 pm
Check the price and look at my first reply.
Posted: Sat Jan 18, 2014 12:52 pm
by abhi_123
Probe itself is for 160. considering this as a one time investment & the cost of expensive livestock we keep its seems ok for me.
Posted: Sun Jan 19, 2014 8:20 am
by jsclownfish
Does that probe report in the same mV range as the salinity, ORP, or pH probes? In other words, if someone really wanted to make the investment in the probe, could they use one of the other modules to report DO levels?
just curious.....
Posted: Sun Jan 19, 2014 8:35 am
by Pny
The Atlas scientific sensor board (ie kit) has a serial port... Not very expensive or difficult to add some hardware to interface it as an expansion from the Reef Angel, or if not in use already; use the serial port directly...
Posted: Sun Jan 19, 2014 11:00 am
Something similar, but with much lower voltage ranges.
It's in the micro volts instead of mili volts.
Here is a good article:
http://www.gatewaycoalition.org/files/H ... 2_1_1f.htm
Posted: Sun Jan 19, 2014 11:02 am
by abhi_123
Pny wrote:The Atlas scientific sensor board (ie kit) has a serial port... Not very expensive or difficult to add some hardware to interface it as an expansion from the Reef Angel, or if not in use already; use the serial port directly...
So you mean that if i want i can do with atlas scientific kit only & some how connect it with my reef angel controller. if that is the case what we addition i have to do in the libraries & code
Posted: Sun Jan 19, 2014 12:10 pm
by jsclownfish
It should be possible to connect the kit from Atlas to the RA. I've done similar things with DIY modules through the Arduino. You could update the libraries or just add some custom code to the Atlas (arduino) board and the RA to communicate over I2C. I just thought it might be easier to fool the ORP, salinity, or pH meter modules into reporting DO.
I hadn't thought about DO readings, but it seems this RA has made me a bit of a data junkie on my tank and I'm always interested in monitoring other aspects of the aquarium.
-Jon
Posted: Sun Jan 19, 2014 5:16 pm
by ReEfnWrX
Or hope mindstream monitor releases soon and spend an extra 400$ and get live monitoring of DO and everything else??
Posted: Mon Jan 20, 2014 12:07 pm
by jsclownfish
Not sure I understand what you are saying. Would this Atlas probe for example work in the range of one of the other modules, or use the RA board pH BNC? Not that I really want to spend $200, but if I come across a cheap probe, it might be worth a try. I got a cheap Ca probe on ebay, but since it isn't designed to stay submerged, it was kind of pointless.
Jon
Posted: Mon Jan 20, 2014 12:20 pm
It would read, but the scale would be too low to be any useful.
The module would have to be modded to change the gain by 1000 times.
Posted: Mon Jan 20, 2014 1:05 pm
by jsclownfish
ahh. I guess that is what the BNC board in the kit must do. I suppose I could hook it up to an arduino board and send the reading through I2C like another module. Assuming I had time, extra money, and three other projects that get completed...
