Hi
I am planning to buy a reef angel
I want to make sure I get the wright stuff
I have the following item in my tank
Vortech MP40WES X2
Ecotech Marine ReefLink
Ecotech Marine Radion XR30w Pro x3
I want to measure PH,Salinity and temperature
Setup auto top off
detect leaks from my sump
would the follow items do what I want or can you suggest other items I need
Reef Angel Plus Controller
Salinity Expansion Module
Salinity Probe
RF Expansion Module
Water Level Expansion Module
Float Switch
Buzzer
ATO Pump
Dosing pump
Wifi Attachment
Expansion Hub
Rope Leak Detector Expansion
thanks
Matthew
Help what parts to I need
- lnevo
Re: Help what parts to I need
The float switches are included and I'm 99% sure the salinity probe comes with the salinity expansion. Otherwise your list looks good. I see you're getting the water level expansion... you may want to consider the multiple level model. You can use either in lieu of the float switches.
