Adding Expansion HUb and Salinity Expansion
Posted: Mon Jan 27, 2014 9:06 am
by ganjero
I'm getting the expansion hub and the salinity expansion. How do I add this to my code to function properly? I currently have two relay boxes; I'm assuming I would have to plug the expansion hub first and the second box to the hub along with the salinity expansion, is this correct?
Re: Adding Expansion HUb and Salinity Expansion
Posted: Fri Jan 31, 2014 9:46 am
by Sacohen
The hub plugs into the relay and then all of your modules plug into the hub.
Here is a link to the installation manual...
http://www.reefangel.com/files/Salinity ... _1.4.2.pdf
Make sure that this is in the beginning part of your code with all the other includes.
That should be all you need to get it to work,
Posted: Sat Feb 01, 2014 3:57 pm
by ganjero
Sacohen wrote:The hub plugs into the relay and then all of your modules plug into the hub.
Thanks, that is in my code and I installed everything as directed.
I installed these today and cant get them to work, the expansion relay doesnt respond to manual commands (turning off ports) and the salinity calibration shows 0, and my salinity shows 6 in the portal.
any help is appreciated, thanks.
Posted: Sat Feb 01, 2014 4:38 pm
Did you upload new code referencing any of the ports in the expansion? You need to set at least one port somewhere to do something for the relay expansion to be enabled.
Posted: Sat Feb 01, 2014 5:09 pm
by ganjero
this is my code
ReefAngel.FeedingModePorts = Port7Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
InternalMemory.OverheatTemp_write( 851 );
//Feeedin mode length
ReefAngel.Timer[FEEDING_TIMER].SetInterval(300);
ReefAngel.Relay.On( Box1_Port1);
ReefAngel.StandardLights( Port1,13,0,19,0 );
ReefAngel.StandardLights( Port2,14,0,20,0 );
ReefAngel.StandardLights( Port3,19,55,22,0 );
ReefAngel.StandardLights( Port4,13,0,20,15 );
ReefAngel.StandardHeater( Port5,780,785 );
ReefAngel.StandardFan( Port6,780,800 );
pinMode(lowATOPin,OUTPUT);
////disable ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30%
static time_t StartFeeding=0;
StartFeeding=now(); // if we entered feeding mode, register what time it was.
if (now()-StartFeeding > 1800 && now()-StartFeeding < 9900) // if feeding run then Nutrient Transport mode between 1800 and 9900 seconds
{ ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,80,700,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(40,80,700,false) ); // Nutrient Transport on anti-sync mode
else if (now()%SECS_PER_DAY>=64800 && now()%SECS_PER_DAY<66600)
ReefAngel.PWM.SetDaylight( 100 );
ReefAngel.PWM.SetActinic( 100 );
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,true) ); // ReefCrest at 80% +/- 20% on sync mode
//sump flow pump reefcrest, after feeding nutrient export, at 6pm 100% for 30min
if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds
{ analogWrite(lowATOPin,100*2.55);
analogWrite(lowATOPin, ReefCrestMode(70,30,true)*2.55);
//sump pump flow constant 70%, 100% between 8pm and 9pm
////disable if (hour()==8)
////disable analogWrite(lowATOPin,100*2.55);
////disable else
////disable analogWrite(lowATOPin,70*2.55);
//DT flow pumps in constant speed at 40% during waterchange mode
ReefAngel.PWM.SetDaylight( 40 );
ReefAngel.PWM.SetActinic( 40 );
//// Control display heater based on display temp sensor
if (ReefAngel.Params.Temp[T1_PROBE]<780) ReefAngel.Relay.On(Box1_Port6);
if (ReefAngel.Params.Temp[T1_PROBE]>785) ReefAngel.Relay.Off(Box1_Port6);
///// Delay Start Turn off on Booting - Start
static unsigned long startTime=now();
if (startTime==LastStart) {
ReefAngel.Relay.On(Port7);
} else {
ReefAngel.Relay.DelayedOn(Port7);
///// Delay Start Turn off on Booting - End
ReefAngel.Portal( "ganjero" );
//// Jebao Else Mode - Start
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
//// Jebao Else Mode - End
Posted: Sat Feb 01, 2014 5:16 pm
by ganjero
I also just noticed that the main relay is keeping all the programmed ports on even though they show off in portal and the phone app.
Posted: Sat Feb 01, 2014 7:33 pm
Does the LED of the side of hub light up when you connect it to the main relay box?
Do you get any readings from the salinity module if you connect it straight to the main relay box and not use the hub?
Posted: Sun Feb 02, 2014 9:50 am
by ganjero
Yes to both.
Posted: Sun Feb 02, 2014 10:53 am
If I'm following this correctly, your salinity module seems to be working fine since it works when connected straight into the relay box and your relay expansion module also works fine since it was originally working connected straight into the relay box, correct?
But, when you connect the hub, neither one works, correct?
Before we RMA the hub, can you try swapping around usb cables?
Posted: Sun Feb 02, 2014 11:43 am
by ganjero
Yes Roberto.
The salinity expansion works if I plug it straight to the relay box, and also the expansion relay box works correctly if a plug it direrctly to the main relay box. If I use the expansion hub that I just bought this week all the expansion (salinity and expansion relay box) don't respond/work correctly.
I will try swapping ables. Are the RA different from a common mini USB cable? I have other equipment in my house that use similar cables, maybe I can try with one of those.
Does it matter with usb ports I use in the expansion hub? Does the hub need a power adapter like the salinity expansion?
Thanks for your help.
Posted: Sun Feb 02, 2014 11:50 am
Same USB cable. No need for power on the hub
Sent from my Galaxy S3 using Tapatalk
Posted: Sun Feb 02, 2014 11:52 am
by Sacohen
The expansion hub does not need a power supply, mine does not have one.
Also it can use a similar USB cable.
I needed a longer one today for something I was testing and used one from a USB drive I had and it worked.
Posted: Sun Feb 02, 2014 6:59 pm
by ganjero
Swapped some cables with some from my other equipment and it seems to be working now.
Now Im having issues calibrating the probe. Do I need to rinse it and let it dry before calibration? I put it in a cup with water at 35ppm, calibrated it but it shows my tank at 44 when my tank is actually 32. Does water temp matter?
Posted: Sun Feb 02, 2014 7:00 pm
by Sacohen
Looks like you have a bad cable. Glad it was resolved.
Posted: Mon Feb 03, 2014 7:55 am
by ganjero
Well now that the probe seems to be not working correctly.
Looking at the salinity chart this morning it shows the salinity at ~44 it goes down to ~22 and jumps back up to 44.
There a not bubbles in the area, the temp is steady...not sure how correct this.
Posted: Mon Feb 03, 2014 11:14 am
Shake the probe to make sure there is no bubble trapped in the tip.
What happens if you place the probe in a cup with tank water?
Posted: Mon Feb 03, 2014 11:15 am
by Sacohen
Ouch. I hate when a bubble get trapped on the tip.
Posted: Tue Feb 04, 2014 7:46 am
by ganjero
I shook it but I don't think it was air trapped as it kept going up and down. Around 8pm last night I put it in a cup of saltwater and it has been showing stable salinity. See the chart below.
Do you know what could be the issue when I sue it in my sump?
Posted: Tue Feb 04, 2014 9:46 am
Something else that is connected to your setup is doing that.
Posted: Tue Feb 04, 2014 9:59 am
by Sacohen
I've been watching this for a bit and just want to though in my 2¢.
Do you have an ATO that is feeding fresh water into the sump, possibly close to the Salinity Probe?
Posted: Tue Feb 04, 2014 10:06 am
by ganjero
rimai wrote:Something else that is connected to your setup is doing that.
When you say setup, do you mean the reefangel controller? or my entire reef system?
Sacohen wrote:I've been watching this for a bit and just want to though in my 2¢.
Good point, and believe it was somehow close. I will try setting them on opposite sides and see how that works, but if that is the case shouldn't it just go down and then back to 32-34 instead of 44?
Posted: Tue Feb 04, 2014 10:26 am
by Sacohen
Thanks[/quote]
That is true it should go back to normal and not 44ppt.
Is your ATO dosing Kalkwasser too?
I had my Salinity probe get covered with calcium deposits and it gave me crazy reading.
Posted: Wed Feb 05, 2014 8:44 am
by ganjero
Placed in a different area in the sump and still have the same issues.
Does anyone know what equipment commonly cause issues with this probe?
Posted: Tue Feb 11, 2014 1:55 pm
by Albe
Have you checked for stray voltage?
Posted: Sun Feb 16, 2014 10:48 am
by ganjero
Measured for Stray voltage. I have a ground probe installed so I removed it, my multimeter shows a reading of 14. I turned everything off and almost every piece of equipment added a point.
When I put the ground probe back in the reading goes back to zero, but I found that if I leave it out the salinity reading stays constant, 5 points off but constant.
Any thoughts?
Posted: Sun Feb 16, 2014 1:14 pm
Do you have another 12VDC power supply to try connecting to the salinity module?
Posted: Sun Feb 16, 2014 5:09 pm
by heatdissipation
Is this the same salinity expansion I bought off of you today?
