Vortech On/Off
Posted: Tue Jan 28, 2014 5:26 am
I remember this was mentioned a while back and I see the modes defined to turn on/off the Vortech drivers. What I don't recall was whether or not this required a firmware update to support them or not.
Thanks in advance!
Re: Vortech On/Off
Posted: Tue Jan 28, 2014 8:51 am
Yes it does.
Re: Vortech On/Off
Posted: Tue Jan 28, 2014 9:04 am
I can run the same command in the bat file on Linux? Do I need the avrdude.exe and avrdude.conf or the one from my Arudino install will be ok?
Re: Vortech On/Off
Posted: Tue Jan 28, 2014 9:09 am
same command.
I think the one from arduino works. I can't remember.
Re: Vortech On/Off
Posted: Thu Jan 30, 2014 11:37 am
the one from arduino works just fine. you may have a slightly longer command due to the location not being in your PATH.
Re: Vortech On/Off
Posted: Thu Jan 30, 2014 3:59 pm
That part i knew (path-wise) just didnt know if anything specific i need in the conf file included...
