Page 1 of 4
New User Questions
Posted: Tue Jan 28, 2014 11:33 am
by howaboutme
Hello all.
I just purchased a 2nd hand, but unused RA (not +) and have a few questions before I attempt to set things up.
I have 29G, sump-less set up at the moment. I run a HOB skimmer, 2 HK nano ph's (I have 1 wp-25 waiting to replace the 2 though), 1 D120, an Avast ATO and a heater. It's a very simple set up that I am using to learn the hobby. The tank has been set up for about 10/11 months. I have always planned on getting a RA for my next tank but a deal came up locally that I couldn't refuse. So here I am. I don't know the code but I am relatively tech savvy and have taught myself, through observation and trial and error, how to design websites. I'm hoping reading a few codes will bring me up to speed. So on to the questions:
How I will use it initially:
1. Control on/off skimmer during maintenance (but not feeding).
2. Control the on/off of the D120 lights (2 channels)
3. Control the on/off of the 2 phs (will ask a wp-25 question below) for maintenance and feeding
4. Control the on/off of the heater w/ the RA temp probe
5. Monitor PH w/ the RA probe
6. Control Avast ATO (more questions below)
- With the above, I assume there is no special code and I can just use the built in code on the head unit to set up?
- I plan to replace the 2 HK ph's w/ 1 wp-25. Do I need the RA + board if all other assumptions are the same? I understand I will need the Jebao cable. What else?
- Do I plug my D120 into port 3 and 4 only? There is not "moonlight" channel
- Re: Avast ATO. Avast has a RA cable but I am lost as to what it's used for? Does it do anything different from the original head unit?
- I want to eventually get the wifi attachment. Do I need the + board for that too? (I will eventually get the + board but want to only get what I need first).
- What's involved in switching to the RA+ board? Are all of the codes saved elsewhere so they are not lost or have to be backed up on the computer? Does the hardware just slip in and out in the head unit?
- I understand that in order for me to control the controller via the web, I will need the wifi attachment?
- The RA manual online gives instructions for setting up via the head unit. Is there a way to set up via a computer w/ the head unit plugged into the computer? I assume the computer has to be within reach of the head unit? I can't pull the head unit out and plug just that into the computer (if my desktop is a ways away from the tank)? I do have a laptop just in case. What is the wizard that I hear people talking about? I see the RA installer under "downloads", is that the wizard?
-I noticed the sticky regarding the LCD hardware change. The seller said the RA is just less than 2 years old. Is there a chance it would have the bad screen?
Sorry for the long winded post and I am sure I will have more once I start tinkering. Thanks in advance!
Re: New User Questions
Posted: Tue Jan 28, 2014 12:01 pm
If you are going to use Jebao pumps, I suggest you upgrade to RA+ when you get the pumps.
You are good for now.
The Avast ATO is stand alone ATO system. You don't need RA, but if you want to connect the pressure sensor from the Avast ATO into RA, you can grab the cable. It will function exactly the same as a float switch.
Upgrading is just a matter of swapping the board. Yes, make sure the code is always backed up in your computer.
You can't pull codes back from the controller to the PC.
Download the installer, install and open Arduino. Go to menu Tools->Reef Angel Wizard. You will be surprised on how easy it is to set up your controller
Only way to tell the screen is to open the head unit.
Posted: Tue Jan 28, 2014 12:44 pm
+1 on the wizard...everything you mentioned should be built in.
The avast ato can connect like a float switch and then you can override the pump. However since its standalone you can leave it the way it is and use one of the ra float switches as a backup override!
Posted: Tue Jan 28, 2014 1:00 pm
Posted: Tue Jan 28, 2014 1:06 pm
by howaboutme
Thanks guys for your responses! I have heard nothing but good things about the support of the RA community and Roberto. And Inevo, I recognize your screen name. Are you the same one that occasionally comes on WAMAS?
- I will open up the head unit and look at the screen. Am I assuming correct that RA will honor the switch even though I bought it 2nd hand?
- I'd like to hook the avast ato up to the RA because it will clean up the wiring. Though I do like the redundancy of another float switch as the pressure sensor has been a bit fussy for me lately. Since I dont have a sump, I'm not sure I want to muck up the DT anymore for now...I will contact avast and order the RA cable.
- I looked at the avast instructions, they don't say where to hook up the cable. Does it hook up to one of the ATO connections? The pump I know goes to outlet #1.
- I already have the wp-25 but have not hooked it up. I have read that hooking up the jebaos requires the + board because of the massive code used to get multiple pumps to sync. If I only want to control the power output, will it work w/ the standard board? If not, I may want to experiment a bit more since I have and LED dimmer. I will test to see if my tank can handle just 1 wp-25 powered down (but not less that 50%, or has that number changed?). If it works, I will invest in both the board and the cable.
- Regarding the wizard and hooking the head unit up to a computer. Will the head unit work being powered by just the USB? Or do I have to keep it hooked up to the relay box? This will determine if I can use my desktop or my laptop (at least until I get the wifi attachment).
Thanks again and I'm sure I'll have more to come!
Posted: Tue Jan 28, 2014 1:45 pm
You will always need a computer hooked up to upload code unless you get the bluetooth module. You would need a separate usb power cable if its not hooked up to the relay box. The outlets you'll get to define wherever you plug things in. The manual describes the preloaded code. You should use the wave maker ports though if you want to do stuff with the standard power heads. You can manually code the pwm ports you wont get all the modes in the tight space. You may be able to do more since you dont have wifi...honestly without wifi...well i couldnt imagine my ra without wifi.. I think to switch the avast ato you would have to replace the whole pressure switch or just cut the cable and splice on a RA dimming port. See what Avast says first of course. And finally yes, I'm the same lnevo on wamas..great people on that board...wamas is my getaway to sane reefers when I've had too many new yawkers
Posted: Tue Jan 28, 2014 6:42 pm
by howaboutme
lnevo wrote: You would need a separate usb power cable if its not hooked up to the relay box.
I'm currently downloading the installer now. While I am waiting, I plugged the USB-TTL cable from the head unit to my computer but it doesn't power up. So my question was if I am able to turn the unit on w/o attaching it to the relay box (therefore have it plugged in) and it looks like I am not able to...unless I need to run the installer/wizard in conjunction. I guess I will find that out soon.
On another note..I have the gen 1 screen so no need to replace.
More questions later. Thanks!
Posted: Tue Jan 28, 2014 6:55 pm
Theres a seperate usb power cable that plugs into a temperature port...if you need to power it without the relay box plugged in. It comes with the ra plus not the std
Posted: Tue Jan 28, 2014 7:18 pm
by howaboutme
Ah..that makes sense now. So I have things powered up and everything connected to test out. The head unit is on and is displaying "reef controller demo". That menu does not correspond to the RA manual I downloaded from the website. 1) I can't figure out a way to get back to the pre-loaded code. 2) I used the wizard and configured the controller based on what I talked about earlier and tried to upload the code and it's giving me an error. I have the TTL-USB plugged into the head unit and the computer while everything is powered up. Keep in mind that although the temp and ph probe's are plugged in, nothing is in water and not tank equipment is actually plugged into the relay box yet.
Just based on a few minutes work I think it is essential to have the wifi module..just have to figure out if i can get away w/o the + board for now...
Posted: Tue Jan 28, 2014 7:25 pm
by howaboutme
I just tried to upload the pre-loaded code from the wizard and it gives me an error again.
This is the text that comes up after the error:
Watchdog Timer
Version Menu
Dimming Signal
Date/Time Setup Menu
Standard Menu
Binary sketch size: 31,754 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM3 -b115200 -D -V -Uflash:w:C:\Users\Jack\AppData\Local\Temp\build2032032944864675382.tmp\RA_Preloaded.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
Posted: Tue Jan 28, 2014 7:29 pm
Make sure you have the right board selected, also sometimes the cable needs to be reseated, make sure its on the pins all the way to the righy
Posted: Tue Jan 28, 2014 7:45 pm
by howaboutme
Ok so apparently I had the board set as "reef angel controller w/ optiboot". I'm not sure what that is but I am pretty sure I should be at "reef angel controller".
Before I looked under "board", I did reset the connector and uploaded the pre-loaded code successfully. But then it gave me a "no internal memory found" error on the head unit. After more tinkering, I switched the board to the correct one and then tried to upload the "initialinternalmemory" code. It looks like the head unit restarts but the same "no internal memory found" error comes up. I tried to re-upload the pre-loaded code again but it's giving me the same upload error message again. I unplugged and plugged the connector to the computer a few times and get the same.
Thoughts?
Posted: Tue Jan 28, 2014 7:55 pm
by howaboutme
apparently my computer is now not recognizing the device on usb...i wonder if that's the real issue. I may try to restart my computer first.
Posted: Tue Jan 28, 2014 8:05 pm
It can happen especially plugging and unplugging cable. serial connections are annoying sometimes
Posted: Tue Jan 28, 2014 8:26 pm
If your board is really old, it may be that you need to set to Reef Angel Controller.
Posted: Tue Jan 28, 2014 8:27 pm
Sorry, just reread the post and if you did upload code with the /optiboot, then don't change it.
Posted: Wed Jan 29, 2014 6:19 am
by howaboutme
Ok, so Roberto I think made the connection that I didn't last night. The code uploading did work w/ optiboot but didn't when I switched to "reef angel controller" only. I will try that tonight and hopefully it works out.
So I need to upload:
1) initialinternalmemory
2) either upload the pre-loaded code
or
the code that I created for myself w/ the wizard.
Do I have that correct?
Roberto, when you say I have an old board. What does that mean in terms of functionality and/or options? Is it slower/faster than the newer boards, etc?
Thank you all!
EDIT: one more question...Does the wifi attachment need the + board to work considering what I will be using it for?
Posted: Wed Jan 29, 2014 9:00 am
Yes, you have it correct.
The very early boards had a different bootloader, which used a little more code space.
The newer ones have optiboot bootloader and uses a little less.
In terms of functionality, they are all the same, same speed, same number of ports, including the RA+. They can all do the exact same thing provided that you can fit in the amount of space you have to work with.
The older standard RA has about 30K, the newer standard RA has about 32K and the RA+ has about 256K.
The standard RA is good for basic stuff and when you add the wifi attachment, you are going to be pretty close to maxed out.
When you hit the compile/upload button, you can see how much memory it will take. In your example you posted earlier:
As you can see, you are pretty close to capacity already.
Posted: Wed Jan 29, 2014 10:00 am
by howaboutme
rimai wrote:Yes, you have it correct.
Ok, I think I got it.
That example code showing 31.7K was for the pre-loaded code. If I use the pre-loaded code, it doesn't look like I have room for the wifi module, correct?
I have developed a new code w/ the wizard that should be smaller (I have to check exact size when I get home) since I won't be using 2 or 3 of the plugs in the relay.
I'm just trying to determine what I need moving forward, whether it's only the wifi for a period of time or whether I need both the wifi and the + board at the same time.
Thank you!
Posted: Wed Jan 29, 2014 12:11 pm
by ReEfnWrX
As mentioned before, if you are even thinking of using Wave Modes with your Jebao pump, you should get the RA+ board...
Posted: Wed Jan 29, 2014 12:23 pm
The preloaded takes a lot cause there are a lot of menu screens that take up space. You should be fine for now. I would recommend getting + and wifi together..
Posted: Wed Jan 29, 2014 1:52 pm
by howaboutme
Thanks guys! I really appreciate it.
I will try to tinker w/ it more tonight. My main concern is just to get it to connect to my computer. Once that's solved, I will analyze how I will use it now and in the future. But it is looking more and more like I'll need both the +board and the wifi at the same time.
Posted: Wed Jan 29, 2014 6:50 pm
by howaboutme
Ok guys..I'm stumped.
So I switched the board to "reef angel controller w/ optiboot" and uploaded the "initialinternalmemory" code and a sketch that I generated with the wizard. After all of that, the head unit still says "No Internal Memory Found". I restarted the controller (by unplugging and plugging back in the relay box) and still the same.
Thoughts?
Edit: I am connecting the head unit to my computer via the TTL-USB cable. When I go under Tools-Serial Port, it says "COM3", not /dev/tty.usbserial as stated in the current manual. Is this the issue? If so, how do I correct it?
Posted: Wed Jan 29, 2014 6:53 pm
I don't think you uploaded it correctly.
Can you post the log of when it finished uploading the internal memory code?
Posted: Wed Jan 29, 2014 6:58 pm
by howaboutme
rimai wrote:I don't think you uploaded it correctly.
I just tried to post the log (it's the bottom part of the screen, right? It won't let me since it's 9000 characters long. Can you up my limit?
Also...please note of what I wrote under the "edit" in my previous post. It could be relevant. Thank you.
Posted: Wed Jan 29, 2014 7:06 pm
by howaboutme
Let try to break up the code into 2 posts:
avrdude: Send: d [64] . [00] . [80] F [46] . [88] . [7f] . [90] p [70] . [80] 6 [36] . [91] . [05] . [09] . [f4] . [c7] . [c0] . [81] 6 [36] . [91] . [05] . [cc] . [f5] . [88] 2 [32] . [91] . [05] . [09] . [f4] { [7b] . [c0] . [89] 2 [32] . [91] . [05] . [b4] . [f4] . [80] 1 [31] . [91] . [05] . [09] . [f4] o [6f] . [c0] . [81] 1 [31] . [91] . [05] < [3c] . [f4] . [00] . [97] . [09] . [f4] . [16] . [c1] . [08] . [97] . [09] . [f0] . [17] . [c1] e [65] . [c0] . [88] 1 [31] . [91] . [05] . [09] . [f4] f [66] . [c0] . [80] . [97] . [09] . [f0] . [0f] . [c1] v [76] . [c0] . [80] 4 [34] . [91] . [05] . [09] . [f4] . [88] . [c0] . [81] 4 [34] . [91] . [05] D [44] . [f4] . [80] 3 [33] . [91] . [05] . [09] . [f4] m [6d] . [c0] . [c8] . [97] . [09] . [f0] . [00] . [c1] m [6d] . [c0] . [80] 5 [35] . [91] . [05] . [09] . [f4] m [6d] . [c0] . [88] 5 [35] . [91] . [05] . [09] . [f4] z [7a] . [c0] . [88] 4 [34] . [91] . [05] . [09] . [f0] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
avrdude: Send: U [55] @ [40] . [06] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [f3] . [c0] . [f0] . [c0] . [88] 9 [39] . [91] . [05] . [09] . [f4] . [e0] . [c0] . [89] 9 [39] . [91] . [05] . [ec] . [f4] . [88] 7 [37] . [91] . [05] . [09] . [f4] . [80] . [c0] . [89] 7 [37] . [91] . [05] L [4c] . [f4] . [88] 6 [36] . [91] . [05] . [09] . [f4] y [79] . [c0] . [80] 7 [37] . [91] . [05] . [09] . [f0] . [dc] . [c0] t [74] . [c0] . [88] 8 [38] . [91] . [05] . [09] . [f4] . [c9] . [c0] . [80] 9 [39] . [91] . [05] . [09] . [f4] r [72] . [c0] . [80] 8 [38] . [91] . [05] . [09] . [f0] . [cf] . [c0] m [6d] . [c0] . [80] ; [3b] . [91] . [05] . [09] . [f4] . [94] . [c0] . [81] ; [3b] . [91] . [05] L [4c] . [f4] . [80] : [3a] . [91] . [05] . [09] . [f4] t [74] . [c0] . [88] : [3a] . [91] . [05] . [09] . [f0] . [bf] . [c0] . [88] . [c0] . [80] < [3c] . [91] . [05] . [09] . [f4] . [b0] . [c0] . [88] < [3c] . [91] . [05] . [09] . [f4] . [ac] . [c0] . [88] ; [3b] . [91] . [05] [20]
#avrdude: Send: U [55] . [80] . [06] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [09] . [f0] . [b2] . [c0] . [90] . [c0] . [80] . [91] . [cb] . [01] . [80] . [93] . [bb] . [00] . [12] . [c0] . [90] . [91] . [f2] . [01] . [80] . [91] . [f3] . [01] . [98] . [17] . [a8] . [f5] . [90] . [91] . [f2] . [01] . [e9] / [2f] . [f0] . [e0] . [ee] R [52] . [fe] O [4f] . [80] . [81] . [80] . [93] . [bb] . [00] . [9f] _ [5f] . [90] . [93] . [f2] . [01] . [85] . [ec] . [8b] . [c0] . [80] . [e2] . [01] . [c0] . [80] . [e3] . [80] . [93] 7 [37] . [02] . [90] . [c0] . [88] . [e3] . [80] . [93] 7 [37] . [02] . [84] . [c0] . [80] . [91] . [f2] . [01] . [90] . [91] . [bb] . [00] . [e8] / [2f] . [f0] . [e0] . [ee] R [52] . [fe] O [4f] . [90] . [83] . [8f] _ [5f] . [80] . [93] . [f2] . [01] . [90] . [91] . [f2] . [01] . [80] . [91] . [f3] . [01] l [6c] . [c0] . [80] . [91] . [f2] . [01] . [90] . [91] . [bb] . [00] . [e8] / [2f] . [f0] . [e0] . [ee] R [52] . [fe] O [4f] . [90] . [83] [20]
avrdude: Send: U [55] . [c0] . [06] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [8f] _ [5f] . [80] . [93] . [f2] . [01] . [80] . [91] . [cc] . [01] . [88] # [23] . [09] . [f0] j [6a] . [c0] . [81] . [e0] . [80] . [93] . [cd] . [01] . [84] . [ea] ^ [5e] . [c0] . [83] . [e0] . [80] . [93] . [ca] . [01] . [10] . [92] 6 [36] . [02] . [c7] . [cf] . [80] . [91] 6 [36] . [02] . [80] 2 [32] . [08] . [f0] N [4e] . [c0] . [80] . [91] 6 [36] . [02] . [90] . [91] . [bb] . [00] . [e8] / [2f] . [f0] . [e0] . [ea] ^ [5e] . [fd] O [4f] . [90] . [83] . [8f] _ [5f] . [80] . [93] 6 [36] . [02] . [b5] . [cf] . [80] . [91] 6 [36] . [02] . [80] 2 [32] 0 [30] . [f4] . [e0] . [91] 6 [36] . [02] . [f0] . [e0] . [ea] ^ [5e] . [fd] O [4f] . [10] . [82] . [0e] . [94] . [d2] . [05] ` [60] . [91] 6 [36] . [02] . [e0] . [91] . [d0] . [01] . [f0] . [91] . [d1] . [01] . [86] . [e1] . [92] . [e0] p [70] . [e0] . [09] . [95] . [10] . [92] 6 [36] . [02] , [2c] . [c0] . [84] . [e0] . [80] . [93] [20]
#avrdude: Send: U [55] . [00] . [07] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [ca] . [01] . [10] . [92] . [14] . [02] . [10] . [92] . [15] . [02] . [e0] . [91] . [ce] . [01] . [f0] . [91] . [cf] . [01] . [09] . [95] . [80] . [91] . [15] . [02] . [88] # [23] ) [29] . [f4] . [81] . [e0] . [80] . [93] . [15] . [02] . [10] . [92] . [f4] . [01] . [90] . [91] . [14] . [02] . [e9] / [2f] . [f0] . [e0] . [ec] P [50] . [fe] O [4f] . [80] . [81] . [80] . [93] . [bb] . [00] . [9f] _ [5f] . [90] . [93] . [14] . [02] . [90] . [91] . [14] . [02] . [80] . [91] . [15] . [02] . [98] . [17] . [08] . [f4] t [74] . [cf] . [85] . [e8] . [80] . [93] . [bc] . [00] . [0a] . [c0] . [85] . [ec] . [80] . [93] . [bc] . [00] . [10] . [92] . [ca] . [01] . [04] . [c0] . [10] . [92] 7 [37] . [02] . [0e] . [94] . [d2] . [05] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [7f] . [91] o [6f] . [91] _ [5f] . [91] O [4f] . [91] ? [3f] . [91] / [2f] . [91] [20]
avrdude: Send: U [55] @ [40] . [07] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [bf] . [92] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [e8] . [2e] . [d6] . [2e] . [c7] . [2e] . [f4] . [2e] . [b2] . [2e] . [80] . [e2] . [84] . [17] . [10] . [f4] . [81] . [e0] j [6a] . [c0] . [10] . [e0] . [04] . [c0] . [84] . [e6] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [80] . [91] . [ca] . [01] . [88] # [23] . [19] . [f4] . [15] 6 [36] ( [28] . [f0] F [46] . [c0] . [1f] _ [5f] . [15] 6 [36] . [91] . [f7] B [42] . [c0] . [82] . [e0] . [80] . [93] . [ca] . [01] . [00] . [93] . [cc] . [01] . [8f] . [ef] . [80] . [93] 7 [37] . [02] . [10] . [92] . [f2] . [01] . [f0] . [92] . [f3] . [01] . [a2] . [ed] . [b1] . [e0] - [2d] - [2d] < [3c] - [2d] . [c9] . [01] . [fc] . [01] . [02] . [c0] . [81] . [91] . [8d] . [93] . [8e] / [2f] . [8d] . [19] . [8f] . [15] . [d0] . [f3] [20]
avrdude: Send: U [55] . [80] . [07] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [10] . [92] . [cb] . [01] . [80] . [91] . [cb] . [01] . [ee] . [0c] . [8e] ) [29] . [80] . [93] . [cb] . [01] . [80] . [91] . [cd] . [01] . [81] 0 [30] A [41] . [f4] . [10] . [92] . [cd] . [01] . [80] . [91] . [cb] . [01] . [80] . [93] . [bb] . [00] . [85] . [ec] . [01] . [c0] . [85] . [ee] . [80] . [93] . [bc] . [00] . [bb] [20] ) [29] . [f4] . [13] . [c0] . [84] . [e6] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [80] . [91] . [ca] . [01] . [82] 0 [30] ) [29] . [f4] . [1f] _ [5f] . [81] / [2f] . [81] P [50] . [84] 6 [36] . [98] . [f3] . [15] 6 [36] [20] . [f0] . [0e] . [94] . [b2] . [05] . [85] . [e0] . [13] . [c0] . [80] . [91] 7 [37] . [02] . [8f] ? [3f] . [11] . [f4] . [80] . [e0] . [0d] . [c0] . [80] . [91] 7 [37] . [02] . [80] 2 [32] . [11] . [f4] . [82] . [e0] . [07] . [c0] . [80] . [91] 7 [37] . [02] . [80] 3 [33] . [11] . [f0] . [84] . [e0] . [01] . [c0] . [83] . [e0] [20]
#avrdude: Send: U [55] . [c0] . [07] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [cf] . [90] . [bf] . [90] . [08] . [95] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [cf] . [93] . [df] . [93] . [f8] . [2e] . [eb] . [01] . [14] / [2f] . [e2] . [2e] A [41] 2 [32] . [90] . [f4] . [00] . [e0] . [04] . [c0] . [84] . [e6] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [80] . [91] . [ca] . [01] . [88] # [23] . [19] . [f4] . [05] 6 [36] @ [40] . [f0] . [03] . [c0] . [0f] _ [5f] . [05] 6 [36] . [91] . [f7] . [0e] . [94] . [b2] . [05] . [10] . [e0] J [4a] . [c0] . [91] . [e0] . [90] . [93] . [ca] . [01] . [e0] . [92] . [cc] . [01] . [8f] . [ef] . [80] . [93] 7 [37] . [02] . [10] . [92] . [f2] . [01] . [11] P [50] . [10] . [93] . [f3] . [01] . [1f] _ [5f] . [90] . [93] . [cb] . [01] . [80] . [91] . [cb] . [01] . [ff] . [0c] . [8f] ) [29] . [80] . [93] . [cb] . [01] . [80] . [91] . [cd] . [01] [20]
avrdude: Send: U [55] . [00] . [08] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [81] 0 [30] A [41] . [f4] . [10] . [92] . [cd] . [01] . [80] . [91] . [cb] . [01] . [80] . [93] . [bb] . [00] . [85] . [ec] . [01] . [c0] . [85] . [ee] . [80] . [93] . [bc] . [00] . [04] . [c0] . [84] . [e6] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [80] . [91] . [ca] . [01] . [81] 0 [30] ) [29] . [f4] . [0f] _ [5f] . [80] / [2f] . [81] P [50] . [84] 6 [36] . [98] . [f3] . [05] 6 [36] 8 [38] . [f6] . [80] . [91] . [f2] . [01] . [81] . [17] . [10] . [f4] . [10] . [91] . [f2] . [01] [20] . [e0] 0 [30] . [e0] . [0a] . [c0] . [fe] . [01] . [e2] . [0f] . [f3] . [1f] . [d9] . [01] . [ae] R [52] . [be] O [4f] . [8c] . [91] . [80] . [83] / [2f] _ [5f] ? [3f] O [4f] ! [21] . [17] . [a0] . [f3] . [81] / [2f] . [df] . [91] . [cf] . [91] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [08] . [95] . [fc] . [01] . [13] . [86] . [15] . [86] . [14] . [86] . [87] . [e0] . [90] . [e0] [20]
#avrdude: Send: U [55] @ [40] . [08] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [12] . [86] 1 [31] . [97] . [00] . [97] . [11] . [f0] . [01] . [97] . [fa] . [cf] . [08] . [95] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [fc] . [01] . [e0] . [80] . [01] . [81] . [12] . [81] . [f8] . [94] . [f8] . [01] . [81] . [81] . [8e] ) [29] . [81] . [83] . [82] . [81] . [de] , [2c] . [d0] . [94] . [8d] ! [21] . [82] . [83] . [83] . [e0] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [f8] . [01] . [81] . [81] . [8d] ! [21] . [81] . [83] . [8a] . [e0] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [f8] . [01] . [00] . [81] x [78] . [94] . [85] . [e3] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [80] . [e0] . [10] . [e0] . [ff] $ [24] . [0e] ! [21] . [1f] ! [21] . [01] + [2b] . [09] . [f0] . [81] . [e0] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [08] . [95] . [1f] . [93] . [cf] . [93] . [df] . [93] . [fc] . [01] . [10] . [81] [20]
avrdude: Send: U [55] . [80] . [08] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [c1] . [81] . [d2] . [81] . [91] / [2f] . [90] . [95] ` [60] . [ff] . [12] . [c0] . [f8] . [94] . [8a] . [81] . [89] # [23] . [8a] . [83] . [89] . [81] . [81] + [2b] . [89] . [83] . [8a] . [e0] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [8a] . [81] . [81] + [2b] . [8a] . [83] x [78] . [94] . [87] . [e3] . [90] . [e0] . [11] . [c0] . [f8] . [94] . [8a] . [81] . [89] # [23] . [8a] . [83] . [89] . [81] . [81] + [2b] . [89] . [83] . [81] . [e4] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [8a] . [81] . [81] + [2b] . [8a] . [83] x [78] . [94] . [85] . [e0] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [df] . [91] . [cf] . [91] . [1f] . [91] . [08] . [95] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [cf] . [93] . [df] . [93] . [8c] . [01] . [e4] . [2e] . [ff] $ [24] . [f3] . [94] . [c0] . [e0] . [d0] . [e0] . [c6] . [2e] . [dd] $ [24] ` [60] . [e0] [20]
#avrdude: Send: U [55] . [c0] . [08] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [8f] - [2d] . [90] . [e0] . [8c] ! [21] . [9d] ! [21] . [89] + [2b] . [09] . [f0] a [61] . [e0] . [c8] . [01] . [0e] . [94] { [7b] . [08] . [ff] . [0c] ! [21] . [96] . [c8] 0 [30] . [d1] . [05] . [81] . [f7] . [ee] [20] . [a9] . [f4] . [f8] . [94] . [d8] . [01] . [11] . [96] . [ed] . [91] . [fc] . [91] . [12] . [97] . [91] . [81] . [8c] . [91] . [80] . [95] . [98] # [23] . [91] . [83] . [11] . [96] . [ed] . [91] . [fc] . [91] . [12] . [97] . [92] . [81] . [8c] . [91] . [80] . [95] . [98] # [23] . [92] . [83] x [78] . [94] . [df] . [91] . [cf] . [91] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [cf] . [90] . [08] . [95] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [cf] . [93] . [df] . [93] . [fc] . [01] . [00] . [81] . [c1] . [81] . [d2] . [81] . [f8] . [94] . [89] . [81] . [d0] . [2e] . [d0] . [94] . [8d] ! [21] . [89] . [83] [20]
avrdude: Send: U [55] . [00] . [09] [20]
avrdude: Send: d [64] . [00] . [80] F [46] x [78] . [94] . [1d] . [e7] . [e0] . [2e] . [ff] $ [24] . [11] P [50] Y [59] . [f1] . [82] . [e0] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [88] . [81] . [90] . [e0] . [8e] ! [21] . [9f] ! [21] . [89] + [2b] . [a1] . [f3] . [f8] . [94] . [8a] . [81] . [8d] ! [21] . [8a] . [83] . [89] . [81] . [80] + [2b] . [89] . [83] x [78] . [94] . [80] . [ee] . [91] . [e0] . [0e] . [94] . [b4] . [18] . [f8] . [94] . [89] . [81] . [8d] ! [21] . [89] . [83] . [86] . [e4] . [90] . [e0] . [0e] . [94] . [b4] . [18] . [88] . [81] . [10] . [e0] . [90] . [e0] . [e8] " [22] . [f9] " [22] . [ef] ( [28] . [09] . [f4] . [11] . [e0] x [78] . [94] . [8a] . [e9] . [91] . [e0] . [0e] . [94] . [b4] . [18] . [81] / [2f] . [df] . [91] . [cf] . [91] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [08] . [95] . [af] . [92] . [bf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] [20]
#avrdude: Send: U [55] @ [40] . [09] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [1f] . [93] . [cf] . [93] . [df] . [93] . [ec] . [01] [ [5b] . [01] . [8d] . [85] . [88] # [23] . [09] . [f0] a [61] . [c0] . [ce] . [01] . [0e] . [94] . [ef] . [08] . [88] # [23] ) [29] . [f4] . [1b] . [86] . [1d] . [86] . [1c] . [86] . [90] . [e0] k [6b] . [c0] . [ce] . [01] ` [60] . [ef] @ [40] . [e0] . [0e] . [94] . [af] . [08] . [01] . [e0] . [dd] $ [24] . [ee] $ [24] . [ff] $ [24] . [f3] . [94] . [ce] . [01] . [0e] . [94] G [47] . [08] . [18] / [2f] . [ce] . [01] . [0e] . [94] G [47] . [08] . [11] 0 [30] . [19] . [f4] . [81] 0 [30] . [e1] . [f4] 9 [39] . [c0] . [18] . [17] . [09] . [f5] . [8b] . [85] . [08] . [17] p [70] . [f4] ` [60] . [e0] . [fe] . [01] . [ee] . [0d] . [f1] . [1d] . [83] . [81] . [90] . [e0] / [2f] - [2d] 0 [30] . [e0] . [82] # [23] . [93] # [23] . [18] . [16] . [19] . [06] L [4c] . [f0] . [03] . [c0] ` [60] . [e0] . [08] . [17] ) [29] . [f0] . [09] 0 [30] [20]
avrdude: Send: U [55] . [80] . [09] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [08] . [f0] L [4c] . [c0] . [0c] . [87] J [4a] . [c0] . [fe] . [01] . [ee] . [0d] . [f1] . [1d] . [83] . [81] . [8f] ) [29] . [83] . [83] a [61] . [e0] . [09] . [c0] a [61] / [2f] . [fe] . [01] . [ee] . [0d] . [f1] . [1d] . [9f] - [2d] . [90] . [95] . [83] . [81] . [89] # [23] . [83] . [83] . [ce] . [01] . [0e] . [94] { [7b] . [08] . [0f] _ [5f] . [ff] . [0c] . [19] . [f4] . [e3] . [94] . [ff] $ [24] . [f3] . [94] . [87] . [e0] . [8e] . [15] . [08] . [f0] . [bb] . [cf] . [01] 4 [34] 0 [30] . [f0] . [db] . [86] . [dd] [20] . [11] . [f5] . [81] . [e0] . [8d] . [87] . [1f] . [c0] . [1b] . [86] . [1d] . [86] . [1c] . [86] . [90] . [e0] . [de] . [01] [20] . [e0] 0 [30] . [e0] . [f5] . [01] . [e2] . [0f] . [f3] . [1f] . [13] . [96] . [8c] . [91] . [13] . [97] . [80] . [83] / [2f] _ [5f] ? [3f] O [4f] . [11] . [96] ( [28] 0 [30] 1 [31] . [05] . [99] . [f7] . [89] / [2f] . [df] . [91] [20]
avrdude: Send: U [55] . [c0] . [09] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [cf] . [91] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [bf] . [90] . [af] . [90] . [08] . [95] . [8b] . [81] . [88] # [23] . [f1] . [f2] . [91] . [e0] . [e0] . [cf] . [d0] . [2e] . [bd] . [cf] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [8c] . [01] . [f6] . [2e] . [86] / [2f] ` [60] . [e0] . [0e] . [94] . [1b] . [19] . [8f] - [2d] . [90] . [e0] . [fc] . [01] . [ec] \ [5c] . [fc] O [4f] . [e4] . [91] . [d8] . [01] . [ec] . [93] . [80] ^ [5e] . [9c] O [4f] . [fc] . [01] d [64] . [91] . [e6] / [2f] . [f0] . [e0] . [ee] . [0f] . [ff] . [1f] . [ea] ^ [5e] . [fc] O [4f] . [85] . [91] . [94] . [91] . [12] . [96] . [9c] . [93] . [8e] . [93] . [11] . [97] . [1b] . [96] . [1c] . [92] . [1b] . [97] . [1d] . [96] . [1c] . [92] . [1d] . [97] . [1c] . [96] . [1c] . [92] . [f8] . [01] . [87] . [e0] . [90] . [e0] . [12] . [86] 1 [31] . [97] . [00] . [97] . [11] . [f0] [20]
#avrdude: Send: U [55] . [00] . [0a] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [01] . [97] . [fa] . [cf] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [08] . [95] O [4f] . [92] _ [5f] . [92] o [6f] . [92] . [7f] . [92] . [8f] . [92] . [9f] . [92] . [af] . [92] . [bf] . [92] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [cf] . [93] . [df] . [93] L [4c] . [01] . [dc] . [01] . [16] . [96] . [1c] . [91] a [61] / [2f] p [70] . [e0] . [80] . [e0] . [90] . [e0] [20] . [e8] 3 [33] . [e3] A [41] . [ee] Q [51] . [e0] . [0e] . [94] 9 [39] . [1c] [ [5b] . [01] l [6c] . [01] " [22] . [eb] 7 [37] . [e0] . [e1] / [2f] . [f0] . [e0] . [ee] T [54] . [f8] O [4f] . [1d] . [c0] . [c9] . [01] . [83] p [70] . [90] p [70] . [89] + [2b] . [b1] . [f4] . [c9] . [01] d [64] . [e6] p [70] . [e0] . [0e] . [94] l [6c] . [1c] . [89] + [2b] 9 [39] . [f4] . [c9] . [01] ` [60] . [e9] q [71] . [e0] . [0e] . [94] l [6c] . [1c] . [89] + [2b] A [41] . [f4] [20]
avrdude: Send: U [55] @ [40] . [0a] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [80] . [e8] . [91] . [e5] . [a1] . [e0] . [b0] . [e0] . [a8] . [0e] . [b9] . [1e] . [ca] . [1e] . [db] . [1e] / [2f] _ [5f] ? [3f] O [4f] . [2e] . [17] ? [3f] . [07] . [01] . [f7] . [d4] . [01] . [15] . [96] . [8c] . [91] H [48] . [2e] U [55] $ [24] . [c9] . [01] d [64] . [e6] p [70] . [e0] . [0e] . [94] l [6c] . [1c] | [7c] . [01] . [c9] . [01] ` [60] . [e9] q [71] . [e0] . [0e] . [94] l [6c] . [1c] . [8c] . [01] . [c1] . [e0] . [d0] . [e0] . [93] . [e0] i [69] . [2e] q [71] , [2c] b [62] " [22] s [73] " [22] ' [27] . [c0] . [c2] 0 [30] . [d1] . [05] . [91] . [f4] a [61] . [14] q [71] . [04] y [79] . [f4] . [e1] . [14] . [f1] . [04] . [19] . [f4] . [01] . [15] . [11] . [05] I [49] . [f4] . [80] . [e8] . [9b] . [e3] . [a6] . [e2] . [b0] . [e0] . [a8] . [0e] . [b9] . [1e] . [ca] . [1e] . [db] . [1e] . [11] . [c0] . [fe] . [01] . [ec] [ [5b] . [fe] O [4f] ` [60] . [81] p [70] . [e0] [20]
#avrdude: Send: U [55] . [80] . [0a] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [80] . [e0] . [90] . [e0] [20] . [e8] 1 [31] . [e5] A [41] . [e0] P [50] . [e0] . [0e] . [94] 9 [39] . [1c] . [a6] . [0e] . [b7] . [1e] . [c8] . [1e] . [d9] . [1e] ! [21] . [96] . [c4] . [15] . [d5] . [05] . [b4] . [f2] . [d4] . [01] . [12] . [96] l [6c] . [91] p [70] . [e0] . [80] . [e0] . [90] . [e0] [20] . [e1] > [3e] . [e0] @ [40] . [e0] P [50] . [e0] . [0e] . [94] 9 [39] . [1c] { [7b] . [01] . [8c] . [01] . [f4] . [01] a [61] . [81] p [70] . [e0] . [80] . [e0] . [90] . [e0] , [2c] . [e3] 0 [30] . [e0] @ [40] . [e0] P [50] . [e0] . [0e] . [94] 9 [39] . [1c] . [e6] . [0e] . [f7] . [1e] . [08] . [1f] . [19] . [1f] . [d4] . [01] . [8c] . [91] . [e8] . [0e] . [f1] . [1c] . [01] . [1d] . [11] . [1d] . [14] . [96] l [6c] . [91] p [70] . [e0] a [61] P [50] p [70] @ [40] . [88] ' [27] w [77] . [fd] . [80] . [95] . [98] / [2f] [20] . [e8] 1 [31] . [e5] A [41] . [e0] P [50] . [e0] [20]
avrdude: Send: U [55] . [c0] . [0a] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0e] . [94] 9 [39] . [1c] . [e6] . [0e] . [f7] . [1e] . [08] . [1f] . [19] . [1f] . [ea] . [0c] . [fb] . [1c] . [0c] . [1d] . [1d] . [1d] . [b7] . [01] . [c8] . [01] . [df] . [91] . [cf] . [91] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [cf] . [90] . [bf] . [90] . [af] . [90] . [9f] . [90] . [8f] . [90] . [7f] . [90] o [6f] . [90] _ [5f] . [90] O [4f] . [90] . [08] . [95] ` [60] . [93] 0 [30] . [01] p [70] . [93] 1 [31] . [01] . [80] . [93] 2 [32] . [01] . [90] . [93] 3 [33] . [01] [20] . [91] : [3a] . [02] 0 [30] . [91] ; [3b] . [02] @ [40] . [91] < [3c] . [02] P [50] . [91] = [3d] . [02] & [26] . [0f] 7 [37] . [1f] H [48] . [1f] Y [59] . [1f] [20] . [93] > [3e] . [02] 0 [30] . [93] ? [3f] . [02] @ [40] . [93] @ [40] . [02] P [50] . [93] A [41] . [02] . [08] . [95] ` [60] . [93] : [3a] . [02] p [70] . [93] ; [3b] . [02] . [80] . [93] < [3c] . [02] [20]
#avrdude: Send: U [55] . [00] . [0b] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [90] . [93] = [3d] . [02] [20] . [91] 0 [30] . [01] 0 [30] . [91] 1 [31] . [01] @ [40] . [91] 2 [32] . [01] P [50] . [91] 3 [33] . [01] & [26] . [0f] 7 [37] . [1f] H [48] . [1f] Y [59] . [1f] [20] . [93] > [3e] . [02] 0 [30] . [93] ? [3f] . [02] @ [40] . [93] @ [40] . [02] P [50] . [93] A [41] . [02] . [82] . [e0] . [90] . [e0] . [90] . [93] C [43] . [02] . [80] . [93] B [42] . [02] . [0e] . [94] M [4d] . [18] ` [60] . [93] D [44] . [02] p [70] . [93] E [45] . [02] . [80] . [93] F [46] . [02] . [90] . [93] G [47] . [02] . [08] . [95] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [1c] . [c0] / [2f] _ [5f] ? [3f] O [4f] O [4f] O [4f] _ [5f] O [4f] [20] . [93] : [3a] . [02] 0 [30] . [93] ; [3b] . [02] @ [40] . [93] < [3c] . [02] P [50] . [93] = [3d] . [02] . [88] . [ee] . [93] . [e0] . [a0] . [e0] . [b0] . [e0] . [e8] . [0e] . [f9] . [1e] . [0a] . [1f] . [1b] . [1f] [20]
avrdude: Send: U [55] @ [40] . [0b] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [e0] . [92] D [44] . [02] . [f0] . [92] E [45] . [02] . [00] . [93] F [46] . [02] . [10] . [93] G [47] . [02] . [0e] . [94] M [4d] . [18] . [e0] . [90] D [44] . [02] . [f0] . [90] E [45] . [02] . [00] . [91] F [46] . [02] . [10] . [91] G [47] . [02] n [6e] . [19] . [7f] . [09] . [80] . [0b] . [91] . [0b] [20] . [91] : [3a] . [02] 0 [30] . [91] ; [3b] . [02] @ [40] . [91] < [3c] . [02] P [50] . [91] = [3d] . [02] h [68] ^ [5e] s [73] @ [40] . [80] @ [40] . [90] @ [40] H [48] . [f6] . [80] . [91] > [3e] . [02] . [90] . [91] ? [3f] . [02] . [a0] . [91] @ [40] . [02] . [b0] . [91] A [41] . [02] ( [28] . [17] 9 [39] . [07] J [4a] . [07] [ [5b] . [07] . [c8] . [f1] . [e0] . [91] 8 [38] . [02] . [f0] . [91] 9 [39] . [02] 0 [30] . [97] . [99] . [f1] . [09] . [95] a [61] . [15] q [71] . [05] . [81] . [05] . [91] . [05] . [19] . [f0] . [0e] . [94] . [fa] . [0a] * [2a] . [c0] . [80] . [91] [20]
avrdude: Send: U [55] . [80] . [0b] [20]
avrdude: Send: d [64] . [00] . [80] F [46] 0 [30] . [01] . [90] . [91] 1 [31] . [01] . [a0] . [91] 2 [32] . [01] . [b0] . [91] 3 [33] . [01] [20] . [91] : [3a] . [02] 0 [30] . [91] ; [3b] . [02] @ [40] . [91] < [3c] . [02] P [50] . [91] = [3d] . [02] . [82] . [0f] . [93] . [1f] . [a4] . [1f] . [b5] . [1f] . [80] . [93] > [3e] . [02] . [90] . [93] ? [3f] . [02] . [a0] . [93] @ [40] . [02] . [b0] . [93] A [41] . [02] [20] . [e0] 0 [30] . [e0] . [80] . [91] B [42] . [02] . [90] . [91] C [43] . [02] . [89] + [2b] . [11] . [f0] ! [21] . [e0] 0 [30] . [e0] 0 [30] . [93] C [43] . [02] [20] . [93] B [42] . [02] ` [60] . [91] : [3a] . [02] p [70] . [91] ; [3b] . [02] . [80] . [91] < [3c] . [02] . [90] . [91] = [3d] . [02] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [08] . [95] . [90] . [93] 9 [39] . [02] . [80] . [93] 8 [38] . [02] . [80] . [91] : [3a] . [02] . [90] . [91] ; [3b] . [02] . [a0] . [91] < [3c] . [02] [20]
#avrdude: Send: U [55] . [c0] . [0b] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [b0] . [91] = [3d] . [02] . [80] . [93] > [3e] . [02] . [90] . [93] ? [3f] . [02] . [a0] . [93] @ [40] . [02] . [b0] . [93] A [41] . [02] . [0e] . [94] ' [27] . [0b] . [08] . [95] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] | [7c] . [01] . [0e] . [eb] . [11] . [e0] . [c8] . [01] h [68] . [e6] p [70] . [e0] . [0e] . [94] . [a8] . [04] . [c8] . [01] ` [60] . [e0] . [0e] . [94] 4 [34] . [05] . [c8] . [01] . [0e] . [94] w [77] . [05] . [c8] . [01] h [68] . [e6] p [70] . [e0] G [47] . [e0] P [50] . [e0] . [0e] . [94] . [88] . [05] . [c8] . [01] . [0e] . [94] . [bb] . [04] ( [28] / [2f] / [2f] w [77] " [22] . [95] / [2f] p [70] . [9a] . [e0] . [d9] . [2e] - [2d] . [9d] . [90] . [01] . [11] $ [24] . [8f] p [70] . [82] . [0f] . [f7] . [01] . [80] . [83] . [c8] . [01] . [0e] . [94] . [bb] . [04] ( [28] / [2f] " [22] . [95] / [2f] p [70] - [2d] . [9d] . [90] . [01] [20]
avrdude: Send: U [55] . [00] . [0c] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [11] $ [24] . [8f] p [70] . [82] . [0f] . [f7] . [01] . [81] . [83] . [c8] . [01] . [0e] . [94] . [bb] . [04] ( [28] / [2f] / [2f] s [73] " [22] . [95] / [2f] p [70] - [2d] . [9d] . [90] . [01] . [11] $ [24] . [8f] p [70] . [82] . [0f] . [f7] . [01] . [82] . [83] . [c8] . [01] . [0e] . [94] . [bb] . [04] ( [28] / [2f] " [22] . [95] / [2f] p [70] - [2d] . [9d] . [90] . [01] . [11] $ [24] . [8f] p [70] . [82] . [0f] . [f7] . [01] . [83] . [83] . [c8] . [01] . [0e] . [94] . [bb] . [04] ( [28] / [2f] " [22] . [95] / [2f] p [70] - [2d] . [9d] . [90] . [01] . [11] $ [24] . [8f] p [70] . [82] . [0f] . [f7] . [01] . [84] . [83] . [c8] . [01] . [0e] . [94] . [bb] . [04] ( [28] / [2f] " [22] . [95] / [2f] p [70] - [2d] . [9d] . [90] . [01] . [11] $ [24] . [8f] p [70] . [82] . [0f] . [f7] . [01] . [85] . [83] . [c8] . [01] . [0e] . [94] . [bb] . [04] ( [28] / [2f] / [2f] p [70] " [22] ^ [5e] [20]
#avrdude: Send: U [55] @ [40] . [0c] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [82] . [95] . [8f] p [70] . [8d] . [9d] . [c0] . [01] . [11] $ [24] ( [28] . [0f] . [f7] . [01] & [26] . [83] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [08] . [95] . [0f] . [93] . [1f] . [93] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] ' [27] . [97] . [0f] . [b6] . [f8] . [94] . [de] . [bf] . [0f] . [be] . [cd] . [bf] . [8e] . [01] . [0f] _ [5f] . [1f] O [4f] . [c8] . [01] . [0e] . [94] . [cd] . [0b] . [c8] . [01] . [0e] . [94] . [06] . [0a] ' [27] . [96] . [0f] . [b6] . [f8] . [94] . [de] . [bf] . [0f] . [be] . [cd] . [bf] . [cf] . [91] . [df] . [91] . [1f] . [91] . [0f] . [91] . [08] . [95] . [8e] . [eb] . [91] . [e0] . [0e] . [94] . [8c] . [05] . [08] . [95] . [8e] . [eb] . [91] . [e0] . [0e] . [94] . [8c] . [05] . [08] . [95] . [9c] . [01] . [f9] . [99] . [fe] . [cf] 2 [32] . [bd] ! [21] . [bd] . [f8] . [9a] . [80] . [b5] . [08] . [95] [20]
avrdude: Send: U [55] . [80] . [0c] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [9c] . [01] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] 2 [32] . [bd] ! [21] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [88] . [ec] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [89] . [ec] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8a] . [ec] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8b] . [ec] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] [20]
#avrdude: Send: U [55] . [c0] . [0c] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8c] . [ec] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8d] . [ec] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8e] . [ec] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8f] . [ec] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] [20]
avrdude: Send: U [55] . [00] . [0d] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [84] . [ed] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [85] . [ed] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8c] . [ed] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8d] . [ed] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [80] . [ef] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] [20]
avrdude: Send: U [55] @ [40] . [0d] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8b] . [ee] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8c] . [ee] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8d] . [ee] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8e] . [ee] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8f] . [ee] . [90] . [e0] [20]
#avrdude: Send: U [55] . [80] . [0d] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [89] . [eb] . [93] . [e0] . [92] . [bd] . [81] . [bd] . [f8] . [9a] . [80] . [b5] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [89] . [eb] . [93] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [89] . [ef] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8a] . [ef] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8b] . [ef] [20]
avrdude: Send: U [55] . [c0] . [0d] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8c] . [ef] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8d] . [ef] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8e] . [ef] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8f] . [ef] . [90] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] [20]
#avrdude: Send: U [55] . [00] . [0e] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [80] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [81] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [82] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [83] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [84] . [e0] . [91] . [e0] . [92] . [bd] [20]
avrdude: Send: U [55] @ [40] . [0e] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [85] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [86] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [87] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [88] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] [20]
#avrdude: Send: U [55] . [80] . [0e] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [89] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8a] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8b] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8c] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8d] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] [20]
avrdude: Send: U [55] . [c0] . [0e] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8e] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8f] . [e0] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [80] . [e1] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [81] . [e1] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] [20]
avrdude: Send: U [55] . [00] . [0f] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [1f] . [ba] . [82] . [e1] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [83] . [e1] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8c] . [e1] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [85] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [86] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] [20]
#avrdude: Send: U [55] @ [40] . [0f] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [87] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [88] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [89] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8a] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8b] . [e2] [20]
avrdude: Send: U [55] . [80] . [0f] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8c] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8d] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8e] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8f] . [e2] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] [20]
#avrdude: Send: U [55] . [c0] . [0f] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [80] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [81] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [82] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [83] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [84] . [e3] . [91] . [e0] . [92] . [bd] [20]
avrdude: Send: U [55] . [00] . [10] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [85] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [86] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [87] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [88] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] [20]
#avrdude: Send: U [55] @ [40] . [10] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [89] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8a] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8b] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8c] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8d] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] [20]
by howaboutme
and:
avrdude: Send: U [55] . [80] . [10] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8e] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8f] . [e3] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [80] . [e4] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8b] . [e4] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] [20]
avrdude: Send: U [55] . [c0] . [10] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [1f] . [ba] . [8c] . [e4] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [8d] . [e4] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [80] . [e5] . [91] . [e0] . [92] . [bd] . [81] . [bd] . [f8] . [9a] . [80] . [b5] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [81] . [e5] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] . [fe] . [cf] . [1f] . [ba] . [82] . [e5] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [f9] . [99] [20]
#avrdude: Send: U [55] . [00] . [11] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [fe] . [cf] . [1f] . [ba] . [83] . [e5] . [91] . [e0] . [92] . [bd] . [81] . [bd] ` [60] . [bd] . [0f] . [b6] . [f8] . [94] . [fa] . [9a] . [f9] . [9a] . [0f] . [be] . [08] . [95] . [8a] . [eb] . [93] . [e0] [20] . [e8] < [3c] . [e0] . [0e] . [94] ! [21] . [02] . [08] . [95] . [8a] . [eb] . [93] . [e0] h [68] . [e7] | [7c] . [e0] . [0e] . [94] . [e5] . [01] . [08] . [95] . [80] . [e6] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [82] . [e6] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [8c] . [e5] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [8e] . [e5] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [88] . [e5] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [8a] . [e5] . [91] . [e0] [20]
avrdude: Send: U [55] @ [40] . [11] [20]
avrdude: Send: d [64] . [00] . [80] F [46] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [84] . [e5] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [86] . [e5] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [8e] . [e4] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [89] . [e4] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [85] . [e4] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [87] . [e4] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [81] . [e4] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [83] . [e4] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [83] . [e2] . [91] . [e0] @ [40] . [e8] [20]
#avrdude: Send: U [55] . [80] . [11] [20]
avrdude: Send: d [64] . [00] . [80] F [46] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [81] . [e2] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [8f] . [e1] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [8d] . [e1] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [8a] . [e1] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [88] . [e1] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [84] . [e1] . [91] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [87] . [ef] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [85] . [ef] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [83] . [ef] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] [20]
avrdude: Send: U [55] . [c0] . [11] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0e] . [94] G [47] . [02] . [08] . [95] . [89] . [ee] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [87] . [ee] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [84] . [ee] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [82] . [ee] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [80] . [ee] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [8e] . [ed] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [8a] . [ed] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [88] . [ed] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [86] . [ed] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] [20]
#avrdude: Send: U [55] . [00] . [12] [20]
avrdude: Send: d [64] . [00] . [80] F [46] G [47] . [02] . [08] . [95] . [82] . [ed] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [80] . [ed] . [90] . [e0] @ [40] . [e8] \ [5c] . [e0] . [0e] . [94] G [47] . [02] . [08] . [95] . [89] . [ee] . [90] . [e0] h [68] . [e7] | [7c] . [e0] . [0e] . [94] . [0b] . [02] . [08] . [95] . [87] . [ee] . [90] . [e0] h [68] . [e7] | [7c] . [e0] . [0e] . [94] . [0b] . [02] . [08] . [95] . [88] . [ed] . [90] . [e0] h [68] . [e7] | [7c] . [e0] . [0e] . [94] . [0b] . [02] . [08] . [95] . [86] . [ed] . [90] . [e0] h [68] . [e7] | [7c] . [e0] . [0e] . [94] . [0b] . [02] . [08] . [95] . [fc] . [01] . [8f] . [ef] . [80] . [83] . [8a] . [b1] . [8c] g [67] . [8a] . [b9] . [8b] . [b1] . [88] g [67] . [8b] . [b9] . [08] . [95] + [2b] . [b1] [20] b [62] K [4b] . [b1] O [4f] } [7d] ; [3b] . [b1] 0 [30] a [61] . [9b] . [b1] . [9f] ~ [7e] . [9b] . [b9] + [2b] . [b9] [20]
avrdude: Send: U [55] @ [40] . [12] [20]
avrdude: Send: d [64] . [00] . [80] F [46] ; [3b] . [b9] . [9b] . [b9] g [67] . [fd] . [02] . [c0] . [84] / [2f] . [01] . [c0] . [82] / [2f] . [8b] . [b9] ; [3b] . [b9] . [9b] . [b9] f [66] . [fd] . [02] . [c0] . [84] / [2f] . [01] . [c0] . [82] / [2f] . [8b] . [b9] ; [3b] . [b9] . [9b] . [b9] e [65] . [fd] . [02] . [c0] . [84] / [2f] . [01] . [c0] . [82] / [2f] . [8b] . [b9] ; [3b] . [b9] . [9b] . [b9] d [64] . [fd] . [02] . [c0] . [84] / [2f] . [01] . [c0] . [82] / [2f] . [8b] . [b9] ; [3b] . [b9] . [9b] . [b9] c [63] . [fd] . [02] . [c0] . [84] / [2f] . [01] . [c0] . [82] / [2f] . [8b] . [b9] ; [3b] . [b9] . [9b] . [b9] b [62] . [fd] . [02] . [c0] . [84] / [2f] . [01] . [c0] . [82] / [2f] . [8b] . [b9] ; [3b] . [b9] . [9b] . [b9] a [61] . [fd] . [02] . [c0] . [84] / [2f] . [01] . [c0] . [82] / [2f] . [8b] . [b9] ; [3b] . [b9] . [9b] . [b9] ` [60] . [ff] $ [24] / [2f] + [2b] . [b9] ; [3b] . [b9] . [08] . [95] K [4b] . [b1] [20]
#avrdude: Send: U [55] . [80] . [12] [20]
avrdude: Send: d [64] . [00] . [80] F [46] @ [40] b [62] ; [3b] . [b1] ? [3f] } [7d] + [2b] . [b1] [20] a [61] . [9b] . [b1] . [9f] ~ [7e] . [9b] . [b9] ; [3b] . [b9] + [2b] . [b9] . [9b] . [b9] g [67] . [fd] . [02] . [c0] . [83] / [2f] . [01] . [c0] . [84] / [2f] . [8b] . [b9] + [2b] . [b9] . [9b] . [b9] f [66] . [fd] . [02] . [c0] . [83] / [2f] . [01] . [c0] . [84] / [2f] . [8b] . [b9] + [2b] . [b9] . [9b] . [b9] e [65] . [fd] . [02] . [c0] . [83] / [2f] . [01] . [c0] . [84] / [2f] . [8b] . [b9] + [2b] . [b9] . [9b] . [b9] d [64] . [fd] . [02] . [c0] . [83] / [2f] . [01] . [c0] . [84] / [2f] . [8b] . [b9] + [2b] . [b9] . [9b] . [b9] c [63] . [fd] . [02] . [c0] . [83] / [2f] . [01] . [c0] . [84] / [2f] . [8b] . [b9] + [2b] . [b9] . [9b] . [b9] b [62] . [fd] . [02] . [c0] . [83] / [2f] . [01] . [c0] . [84] / [2f] . [8b] . [b9] + [2b] . [b9] . [9b] . [b9] a [61] . [fd] . [02] . [c0] . [83] / [2f] . [01] . [c0] . [84] / [2f] [20]
avrdude: Send: U [55] . [c0] . [12] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [8b] . [b9] + [2b] . [b9] . [9b] . [b9] ` [60] . [ff] C [43] / [2f] K [4b] . [b9] + [2b] . [b9] . [08] . [95] . [ef] . [92] . [ff] . [92] . [1f] . [93] . [cf] . [93] . [df] . [93] | [7c] . [01] . [fb] . [01] . [e0] . [81] . [ce] / [2f] . [d0] . [e0] . [ce] . [01] T [54] . [e0] . [96] . [95] . [87] . [95] Z [5a] . [95] . [e1] . [f7] h [68] / [2f] n [6e] p [70] h [68] 0 [30] . [08] . [f0] o [6f] _ [5f] . [1e] / [2f] . [1c] q [71] . [11] . [0f] . [11] . [0f] . [11] . [0f] . [10] 7 [37] . [08] . [f0] . [10] _ [5f] . [c7] . [01] . [0e] . [94] 6 [36] . [12] . [9e] . [01] # [23] p [70] 0 [30] p [70] . [c9] . [01] . [88] . [0f] . [99] . [1f] . [88] . [0f] . [99] . [1f] . [82] . [0f] . [93] . [1f] . [18] . [0f] . [c7] . [01] a [61] / [2f] . [0e] . [94] 6 [36] . [12] . [df] . [91] . [cf] . [91] . [1f] . [91] . [ff] . [90] . [ef] . [90] . [08] . [95] . [ef] . [92] . [ff] . [92] . [0f] . [93] [20]
avrdude: Send: U [55] . [00] . [13] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [1f] . [93] . [cf] . [93] . [df] . [93] . [ec] . [01] . [f6] . [2e] . [14] / [2f] . [e2] . [2e] . [a8] . [95] . [88] . [81] . [88] # [23] . [c9] . [f4] . [ce] . [01] b [62] . [e4] . [0e] . [94] . [7f] . [12] . [ce] . [01] a [61] / [2f] . [0e] . [94] . [7f] . [12] . [ce] . [01] ` [60] / [2f] . [0e] . [94] . [7f] . [12] . [ce] . [01] c [63] . [e4] . [0e] . [94] . [7f] . [12] . [ce] . [01] o [6f] - [2d] . [0e] . [94] . [7f] . [12] . [ce] . [01] n [6e] - [2d] . [0e] . [94] . [7f] . [12] . [18] . [c0] . [ce] . [01] j [6a] . [e2] . [0e] . [94] . [7f] . [12] . [ce] . [01] o [6f] - [2d] . [0e] . [94] 6 [36] . [12] . [ce] . [01] n [6e] - [2d] . [0e] . [94] 6 [36] . [12] . [ce] . [01] k [6b] . [e2] . [0e] . [94] . [7f] . [12] . [ce] . [01] a [61] / [2f] . [0e] . [94] 6 [36] . [12] . [ce] . [01] ` [60] / [2f] . [0e] . [94] 6 [36] . [12] . [ce] . [01] l [6c] . [e2] . [0e] . [94] . [7f] . [12] [20]
#avrdude: Send: U [55] @ [40] . [13] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [df] . [91] . [cf] . [91] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [08] . [95] o [6f] . [92] . [7f] . [92] . [8f] . [92] . [9f] . [92] . [af] . [92] . [bf] . [92] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] L [4c] . [01] i [69] . [83] . [04] . [17] . [18] . [f4] . [f4] . [2e] . [c0] . [2e] . [02] . [c0] . [f0] . [2e] . [c4] . [2e] . [e2] . [16] . [18] . [f4] . [d2] . [2e] . [1e] - [2d] . [02] . [c0] . [de] , [2c] . [12] / [2f] . [c4] . [01] l [6c] - [2d] A [41] / [2f] / [2f] - [2d] . [0d] - [2d] . [0e] . [94] . [fd] . [12] . [aa] $ [24] . [bb] $ [24] . [ef] , [2c] . [ff] $ [24] . [08] . [94] . [e1] . [1c] . [f1] . [1c] . [ec] . [18] . [f1] . [08] . [cd] , [2c] . [dd] $ [24] . [c1] . [1a] . [d1] . [08] > [3e] . [01] . [08] . [94] a [61] . [1c] q [71] . [1c] [20]
avrdude: Send: U [55] . [80] . [13] [20]
#avrdude: Send: U [55] . [80] . [15] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [9d] . [81] . [ae] . [81] . [bf] . [81] . [00] . [97] . [a1] . [05] . [b1] . [05] q [71] . [f0] . [0e] . [94] ' [27] . [0b] , [2c] . [81] = [3d] . [81] N [4e] . [81] _ [5f] . [81] & [26] . [0f] 7 [37] . [1f] H [48] . [1f] Y [59] . [1f] ( [28] . [83] 9 [39] . [83] J [4a] . [83] [ [5b] . [83] . [df] . [91] . [cf] . [91] . [08] . [95] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] O [4f] . [93] _ [5f] . [93] o [6f] . [93] . [7f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [ef] . [93] . [ff] . [93] . [0e] . [94] M [4d] . [18] [20] . [91] . [fc] . [02] 0 [30] . [91] . [fd] . [02] @ [40] . [91] . [fe] . [02] P [50] . [91] . [ff] . [02] b [62] . [1b] s [73] . [0b] . [84] . [0b] . [95] . [0b] i [69] U [55] r [72] @ [40] . [80] @ [40] . [90] @ [40] x [78] . [f0] . [0e] . [94] M [4d] . [18] ` [60] . [93] [20]
avrdude: Send: U [55] . [c0] . [15] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [fc] . [02] p [70] . [93] . [fd] . [02] . [80] . [93] . [fe] . [02] . [90] . [93] . [ff] . [02] . [80] . [91] \ [5c] . [02] . [8f] _ [5f] . [80] . [93] \ [5c] . [02] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [7f] . [91] o [6f] . [91] _ [5f] . [91] O [4f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [8b] . [e0] . [0e] . [94] . [ae] . [19] [20] . [e0] . [89] + [2b] . [09] . [f4] ! [21] . [e0] . [82] / [2f] . [08] . [95] . [8c] . [e0] . [0e] . [94] . [ae] . [19] [20] . [e0] . [89] + [2b] . [09] . [f4] ! [21] . [e0] . [82] / [2f] . [08] . [95] . [af] . [92] . [bf] . [92] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] i [69] . [97] . [0f] . [b6] . [f8] . [94] . [de] . [bf] . [0f] . [be] [20]
#avrdude: Send: U [55] . [00] . [16] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [cd] . [bf] | [7c] . [01] . [81] . [e9] . [93] . [e0] @ [40] . [e0] Q [51] . [ee] ` [60] . [e0] p [70] . [e0] . [0e] . [94] . [84] . [1a] . [ee] . [ef] . [ff] . [e7] . [85] . [91] . [94] . [91] . [80] P [50] . [94] @ [40] Y [59] . [f4] . [2e] . [e0] . [88] . [e1] . [90] . [e0] . [0f] . [b6] . [f8] . [94] . [a8] . [95] . [80] . [93] ` [60] . [00] . [0f] . [be] [20] . [93] ` [60] . [00] . [19] . [e1] . [c1] . [2e] . [d1] , [2c] . [ce] . [0c] . [df] . [1c] . [c6] . [01] . [0e] . [94] . [af] . [13] . [8e] . [eb] . [91] . [e0] ` [60] . [e0] p [70] . [e0] . [0e] . [94] . [e2] . [04] . [8e] . [eb] . [91] . [e0] ` [60] . [e0] p [70] . [e0] . [0e] . [94] . [e7] . [04] . [8e] . [eb] . [91] . [e0] . [0e] . [94] . [8c] . [05] . [8e] . [e4] . [9c] . [e0] . [0e] . [94] . [b6] . [0b] ` [60] . [e6] t [74] . [e5] . [80] . [e0] . [90] . [e0] . [0e] . [94] . [dd] . [0a] . [c7] . [01] J [4a] . [96] [20]
avrdude: Send: U [55] @ [40] . [16] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0e] . [94] . [d1] . [14] . [88] . [e4] . [92] . [e0] . [0e] . [94] . [da] . [10] . [f7] . [01] . [81] . [8f] . [c6] . [01] . [0e] . [94] c [63] . [14] . [c6] . [01] . [0e] . [94] . [ad] . [13] . [88] . [e4] . [92] . [e0] . [0e] . [94] . [14] . [11] n [6e] Q [51] s [73] J [4a] . [86] @ [40] . [9f] L [4c] . [89] . [f1] ^ [5e] . [01] . [08] . [94] . [a1] . [1c] . [b1] . [1c] . [0e] . [94] M [4d] . [18] . [10] . [e0] [20] . [ed] 7 [37] . [e0] @ [40] . [e0] P [50] . [e0] . [0e] . [94] . [7f] . [1c] e [65] 6 [36] q [71] . [05] . [81] . [05] . [91] . [05] . [08] . [f0] . [11] . [e0] . [87] . [e0] a [61] / [2f] . [0e] . [94] Z [5a] . [19] . [c5] . [01] j [6a] . [e7] r [72] . [e0] . [0e] . [94] . [de] . [01] . [c6] . [01] c [63] . [e0] O [4f] . [ef] - [2d] . [e0] . [02] . [e3] u [75] . [01] . [0e] . [94] . [08] . [14] . [c5] . [01] m [6d] . [e8] r [72] . [e0] . [0e] . [94] . [de] . [01] [20]
avrdude: Send: U [55] . [80] . [16] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [c6] . [01] c [63] . [e0] O [4f] . [ef] " [22] . [e3] . [0b] . [e4] . [0e] . [94] . [08] . [14] . [d3] . [cf] . [e3] . [e9] . [f2] . [e0] . [85] . [91] . [94] . [91] & [26] . [e9] 0 [30] . [e0] . [e2] . [0e] . [f3] . [1e] . [f7] . [01] . [81] . [93] . [91] . [93] . [86] . [e0] . [81] . [93] . [7f] . [01] . [8f] . [ef] . [80] . [83] ' [27] . [ee] ? [3f] . [ef] . [e2] . [0e] . [f3] . [1e] . [f7] . [01] . [80] . [83] . [12] . [92] . [7f] . [01] + [2b] . [e1] 0 [30] . [e0] . [e2] . [0e] . [f3] . [1e] . [11] . [e0] . [f7] . [01] . [10] . [83] ' [27] . [ee] ? [3f] . [ef] . [e2] . [0e] . [f3] . [1e] . [f7] . [01] . [10] . [82] / [2f] . [e7] ? [3f] . [ef] . [e2] . [0e] . [f3] . [1e] . [8b] . [e0] ` [60] . [e0] . [0e] . [94] . [1b] . [19] . [8c] . [e0] ` [60] . [e0] . [0e] . [94] . [1b] . [19] . [8b] . [e0] a [61] . [e0] . [0e] . [94] Z [5a] . [19] . [8c] . [e0] a [61] . [e0] . [0e] . [94] [20]
#avrdude: Send: U [55] . [c0] . [16] [20]
avrdude: Send: d [64] . [00] . [80] F [46] Z [5a] . [19] . [80] . [e0] a [61] . [e0] . [0e] . [94] Z [5a] . [19] . [81] . [e0] a [61] . [e0] . [0e] . [94] Z [5a] . [19] . [c7] . [01] . [c3] . [96] . [0e] . [94] . [03] . [15] . [0e] . [94] ' [27] . [0b] ` [60] . [93] . [f8] . [02] p [70] . [93] . [f9] . [02] . [80] . [93] . [fa] . [02] . [90] . [93] . [fb] . [02] ` [60] . [93] W [57] . [02] p [70] . [93] X [58] . [02] . [80] . [93] Y [59] . [02] . [90] . [93] Z [5a] . [02] . [f7] . [01] . [17] . [8a] * [2a] . [e8] 0 [30] . [e0] . [e2] . [0e] . [f3] . [1e] . [f7] . [01] . [10] . [82] & [26] . [e7] ? [3f] . [ef] . [e2] . [0e] . [f3] . [1e] . [f7] . [01] . [14] . [8a] . [15] . [8a] . [16] . [8a] " [22] . [e8] 0 [30] . [e0] . [e2] . [0e] . [f3] . [1e] . [f7] . [01] . [10] . [83] . [2e] . [e7] ? [3f] . [ef] . [e2] . [0e] . [f3] . [1e] . [c7] . [01] . [84] [ [5b] . [9f] O [4f] . [0e] . [94] o [6f] . [15] . [8b] . [e8] . [90] . [e0] [20]
avrdude: Send: U [55] . [00] . [17] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [e8] . [0e] . [f9] . [1e] . [82] . [e0] . [f7] . [01] . [81] . [93] . [7f] . [01] . [10] . [83] $ [24] . [e7] ? [3f] . [ef] . [e2] . [0e] . [f3] . [1e] . [88] . [e4] . [92] . [e0] . [0e] . [94] . [10] . [12] . [f7] . [01] . [91] . [83] . [80] . [83] . [88] . [e4] . [92] . [e0] . [0e] . [94] . [17] . [12] . [f7] . [01] . [93] . [83] . [82] . [83] . [88] . [e4] . [92] . [e0] . [0e] . [94] . [89] . [0d] . [87] . [01] . [0b] V [56] . [1f] O [4f] . [f8] . [01] . [80] . [83] . [f7] . [01] . [17] . [86] . [16] . [86] . [11] . [8a] . [10] . [8a] . [13] . [8a] . [12] . [8a] . [89] 7 [37] 8 [38] . [f0] . [88] . [e4] . [92] . [e0] ` [60] . [e0] . [0e] . [94] . [92] . [0d] . [f8] . [01] . [10] . [82] . [88] . [e4] . [92] . [e0] . [0e] . [94] % [25] . [12] # [23] . [e5] 0 [30] . [e0] . [e2] . [0e] . [f3] . [1e] . [aa] ' [27] . [97] . [fd] . [a0] . [95] . [ba] / [2f] . [f7] . [01] . [80] . [83] [20]
#avrdude: Send: U [55] @ [40] . [17] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [91] . [83] . [a2] . [83] . [b3] . [83] - [2d] . [ea] ? [3f] . [ef] . [e2] . [0e] . [f3] . [1e] . [88] . [e4] . [92] . [e0] . [0e] . [94] . [1e] . [12] . [cc] . [97] 4 [34] . [f4] . [88] . [e4] . [92] . [e0] l [6c] . [e3] p [70] . [e0] . [0e] . [94] . [f4] . [11] . [88] . [e4] . [92] . [e0] . [0e] . [94] . [1e] . [12] . [eb] . [e6] . [f0] . [e0] . [ee] . [0e] . [ff] . [1e] . [aa] ' [27] . [97] . [fd] . [a0] . [95] . [ba] / [2f] . [f7] . [01] . [80] . [83] . [91] . [83] . [a2] . [83] . [b3] . [83] % [25] . [e9] ? [3f] . [ef] . [e2] . [0e] . [f3] . [1e] . [c7] . [01] . [89] Y [59] . [9f] O [4f] . [0e] . [94] | [7c] . [15] . [83] . [e7] . [90] . [e0] . [e8] . [0e] . [f9] . [1e] . [8c] . [e2] . [91] . [e0] . [a0] . [e0] . [b0] . [e0] . [f7] . [01] . [80] . [83] . [91] . [83] . [a2] . [83] . [b3] . [83] - [2d] . [e8] ? [3f] . [ef] . [e2] . [0e] . [f3] . [1e] . [c7] . [01] . [81] Y [59] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
avrdude: Send: U [55] . [80] . [17] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [9f] O [4f] . [0e] . [94] | [7c] . [15] . [8b] . [e7] . [90] . [e0] . [e8] . [0e] . [f9] . [1e] . [80] . [ed] . [92] . [e0] . [a0] . [e0] . [b0] . [e0] . [f7] . [01] . [80] . [83] . [91] . [83] . [a2] . [83] . [b3] . [83] . [81] . [e0] . [90] . [e0] . [a0] . [e0] . [b0] . [e0] . [b2] . [93] . [a2] . [93] . [92] . [93] . [82] . [93] . [7f] . [01] , [2c] . [e0] 0 [30] . [e0] . [e2] . [0e] . [f3] . [1e] . [f7] . [01] . [11] . [92] . [11] . [92] . [11] . [92] . [10] . [92] [ [5b] . [02] . [10] . [82] i [69] . [96] . [0f] . [b6] . [f8] . [94] . [de] . [bf] . [0f] . [be] . [cd] . [bf] . [cf] . [91] . [df] . [91] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [cf] . [90] . [bf] . [90] . [af] . [90] . [08] . [95] . [0f] . [93] . [1f] . [93] . [cf] . [93] . [df] . [93] . [8c] . [01] H [48] . [96] . [0e] . [94] n [6e] . [0c] . [c8] . [01] I [49] . [96] . [0e] . [94] [20]
#avrdude: Send: U [55] . [c0] . [17] [20]
avrdude: Send: d [64] . [00] . [80] F [46] , [2c] . [12] . [c8] . [01] J [4a] . [96] . [0e] . [94] . [e8] . [14] . [c8] . [01] . [84] . [96] . [0e] . [94] . [f1] . [14] . [c8] . [01] . [85] . [96] . [0e] . [94] . [c6] . [14] . [8b] . [e5] . [91] . [e0] . [f8] . [01] . [96] . [a3] . [85] . [a3] . [c8] . [01] . [8c] . [96] . [0e] . [94] . [c6] . [14] . [81] . [e6] . [91] . [e0] . [f8] . [01] . [95] . [a7] . [84] . [a7] . [c8] . [01] . [c3] . [96] . [0e] . [94] . [fa] . [14] . [c8] . [01] . [84] [ [5b] . [9f] O [4f] . [0e] . [94] i [69] . [15] . [01] [ [5b] . [1f] O [4f] . [c0] . [e0] . [d0] . [e0] . [c8] . [01] . [8c] . [0f] . [9d] . [1f] . [0e] . [94] r [72] . [15] ( [28] . [96] . [c0] 3 [33] . [d1] . [05] . [b9] . [f7] . [80] . [91] k [6b] . [00] . [80] b [62] . [80] . [93] k [6b] . [00] . [80] . [91] h [68] . [00] . [81] ` [60] . [80] . [93] h [68] . [00] . [df] . [91] . [cf] . [91] . [1f] . [91] . [0f] . [91] . [08] . [95] [20]
avrdude: Send: U [55] . [00] . [18] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [8d] . [e5] . [92] . [e0] . [0e] . [94] . [b5] . [17] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [80] . [91] . [04] . [03] . [90] . [91] . [05] . [03] . [a0] . [91] . [06] . [03] . [b0] . [91] . [07] . [03] 0 [30] . [91] . [08] . [03] . [01] . [96] . [a1] . [1d] . [b1] . [1d] # [23] / [2f] - [2d] _ [5f] - [2d] 7 [37] [20] . [f0] - [2d] W [57] . [01] . [96] . [a1] . [1d] . [b1] . [1d] [20] . [93] . [08] . [03] . [80] . [93] . [04] . [03] . [90] . [93] . [05] . [03] . [a0] . [93] . [06] . [03] . [b0] . [93] . [07] . [03] . [80] . [91] . [00] . [03] . [90] . [91] . [01] . [03] . [a0] . [91] . [02] . [03] . [b0] . [91] . [03] . [03] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [80] . [93] . [00] . [03] . [90] . [93] . [01] . [03] . [a0] . [93] . [02] . [03] [20]
avrdude: Send: U [55] @ [40] . [18] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [b0] . [93] . [03] . [03] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [8f] . [b7] . [f8] . [94] [20] . [91] . [04] . [03] 0 [30] . [91] . [05] . [03] @ [40] . [91] . [06] . [03] P [50] . [91] . [07] . [03] . [8f] . [bf] . [b9] . [01] . [ca] . [01] . [08] . [95] . [9b] . [01] . [ac] . [01] . [7f] . [b7] . [f8] . [94] . [80] . [91] . [00] . [03] . [90] . [91] . [01] . [03] . [a0] . [91] . [02] . [03] . [b0] . [91] . [03] . [03] f [66] . [b5] . [a8] . [9b] . [05] . [c0] o [6f] ? [3f] . [19] . [f0] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [7f] . [bf] . [ba] / [2f] . [a9] / [2f] . [98] / [2f] . [88] ' [27] . [86] . [0f] . [91] . [1d] . [a1] . [1d] . [b1] . [1d] b [62] . [e0] . [88] . [0f] . [99] . [1f] . [aa] . [1f] . [bb] . [1f] j [6a] . [95] . [d1] . [f7] . [bc] . [01] [20]
#avrdude: Send: U [55] . [80] . [18] [20]
avrdude: Send: d [64] . [00] . [80] F [46] - [2d] . [c0] . [ff] . [b7] . [f8] . [94] . [80] . [91] . [00] . [03] . [90] . [91] . [01] . [03] . [a0] . [91] . [02] . [03] . [b0] . [91] . [03] . [03] . [e6] . [b5] . [a8] . [9b] . [05] . [c0] . [ef] ? [3f] . [19] . [f0] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [ff] . [bf] . [ba] / [2f] . [a9] / [2f] . [98] / [2f] . [88] ' [27] . [8e] . [0f] . [91] . [1d] . [a1] . [1d] . [b1] . [1d] . [e2] . [e0] . [88] . [0f] . [99] . [1f] . [aa] . [1f] . [bb] . [1f] . [ea] . [95] . [d1] . [f7] . [86] . [1b] . [97] . [0b] . [88] ^ [5e] . [93] @ [40] . [c8] . [f2] ! [21] P [50] 0 [30] @ [40] @ [40] @ [40] P [50] @ [40] h [68] Q [51] | [7c] O [4f] ! [21] . [15] 1 [31] . [05] A [41] . [05] Q [51] . [05] q [71] . [f6] . [08] . [95] . [01] . [97] 9 [39] . [f0] . [88] . [0f] . [99] . [1f] . [88] . [0f] . [99] . [1f] . [02] . [97] . [01] . [97] . [f1] . [f7] . [08] . [95] x [78] . [94] . [84] . [b5] [20]
avrdude: Send: U [55] . [c0] . [18] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [82] ` [60] . [84] . [bd] . [84] . [b5] . [81] ` [60] . [84] . [bd] . [85] . [b5] . [82] ` [60] . [85] . [bd] . [85] . [b5] . [81] ` [60] . [85] . [bd] . [ee] . [e6] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [e8] . [f0] . [e0] . [10] . [82] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [e0] . [e8] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [eb] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [e0] . [eb] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [ea] . [e7] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [80] . [81] . [80] h [68] . [80] . [83] . [10] . [92] . [c1] . [00] . [08] . [95] . [98] / [2f] . [8e] 0 [30] . [08] . [f0] . [9e] P [50] . [97] p [70] . [80] . [91] 4 [34] . [01] [20]
#avrdude: Send: U [55] . [00] . [19] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [82] . [95] . [88] . [0f] . [88] . [0f] . [80] | [7c] . [89] + [2b] . [80] . [93] | [7c] . [00] . [80] . [91] z [7a] . [00] . [80] d [64] . [80] . [93] z [7a] . [00] . [80] . [91] z [7a] . [00] . [86] . [fd] . [fc] . [cf] [20] . [91] x [78] . [00] @ [40] . [91] y [79] . [00] . [94] / [2f] . [80] . [e0] 0 [30] . [e0] ( [28] + [2b] 9 [39] + [2b] . [c9] . [01] . [08] . [95] . [cf] . [93] . [df] . [93] H [48] / [2f] P [50] . [e0] . [ca] . [01] . [8c] \ [5c] . [9c] O [4f] . [fc] . [01] 4 [34] . [91] @ [40] ^ [5e] \ [5c] O [4f] . [fa] . [01] . [84] . [91] . [88] # [23] i [69] . [f1] . [90] . [e0] . [88] . [0f] . [99] . [1f] . [fc] . [01] . [ee] _ [5f] . [fc] O [4f] . [a5] . [91] . [b4] . [91] . [fc] . [01] . [e4] _ [5f] . [fc] O [4f] . [c5] . [91] . [d4] . [91] f [66] # [23] Q [51] . [f4] / [2f] . [b7] . [f8] . [94] . [8c] . [91] . [93] / [2f] . [90] . [95] . [89] # [23] . [8c] . [93] [20]
avrdude: Send: U [55] @ [40] . [19] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [88] . [81] . [89] # [23] . [0b] . [c0] b [62] 0 [30] a [61] . [f4] / [2f] . [b7] . [f8] . [94] . [8c] . [91] . [93] / [2f] . [90] . [95] . [89] # [23] . [8c] . [93] . [88] . [81] . [83] + [2b] . [88] . [83] / [2f] . [bf] . [06] . [c0] . [9f] . [b7] . [f8] . [94] . [8c] . [91] . [83] + [2b] . [8c] . [93] . [9f] . [bf] . [df] . [91] . [cf] . [91] . [08] . [95] H [48] / [2f] P [50] . [e0] . [ca] . [01] . [88] [ [5b] . [9c] O [4f] . [fc] . [01] $ [24] . [91] . [ca] . [01] . [8c] \ [5c] . [9c] O [4f] . [fc] . [01] . [94] . [91] @ [40] ^ [5e] \ [5c] O [4f] . [fa] . [01] 4 [34] . [91] 3 [33] # [23] . [09] . [f4] @ [40] . [c0] " [22] # [23] Q [51] . [f1] # [23] 0 [30] q [71] . [f0] $ [24] 0 [30] ( [28] . [f4] ! [21] 0 [30] . [a1] . [f0] " [22] 0 [30] . [11] . [f5] . [14] . [c0] & [26] 0 [30] . [b1] . [f0] ' [27] 0 [30] . [c1] . [f0] $ [24] 0 [30] . [d9] . [f4] . [04] . [c0] . [80] . [91] [20]
#avrdude: Send: U [55] . [80] . [19] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [80] . [00] . [8f] w [77] . [03] . [c0] . [80] . [91] . [80] . [00] . [8f] } [7d] . [80] . [93] . [80] . [00] . [10] . [c0] . [84] . [b5] . [8f] w [77] . [02] . [c0] . [84] . [b5] . [8f] } [7d] . [84] . [bd] . [09] . [c0] . [80] . [91] . [b0] . [00] . [8f] w [77] . [03] . [c0] . [80] . [91] . [b0] . [00] . [8f] } [7d] . [80] . [93] . [b0] . [00] . [e3] / [2f] . [f0] . [e0] . [ee] . [0f] . [ff] . [1f] . [e4] _ [5f] . [fc] O [4f] . [a5] . [91] . [b4] . [91] / [2f] . [b7] . [f8] . [94] f [66] # [23] ! [21] . [f4] . [8c] . [91] . [90] . [95] . [89] # [23] . [02] . [c0] . [8c] . [91] . [89] + [2b] . [8c] . [93] / [2f] . [bf] . [08] . [95] h [68] / [2f] p [70] . [e0] . [cb] . [01] . [88] [ [5b] . [9c] O [4f] . [fc] . [01] $ [24] . [91] . [cb] . [01] . [8c] \ [5c] . [9c] O [4f] . [fc] . [01] D [44] . [91] ` [60] ^ [5e] | [7c] O [4f] . [fb] . [01] . [94] . [91] . [99] # [23] . [19] . [f4] [20]
avrdude: Send: U [55] . [c0] . [19] [20]
avrdude: Send: d [64] . [00] . [80] F [46] [20] . [e0] 0 [30] . [e0] < [3c] . [c0] " [22] # [23] Q [51] . [f1] # [23] 0 [30] q [71] . [f0] $ [24] 0 [30] ( [28] . [f4] ! [21] 0 [30] . [a1] . [f0] " [22] 0 [30] . [11] . [f5] . [14] . [c0] & [26] 0 [30] . [b1] . [f0] ' [27] 0 [30] . [c1] . [f0] $ [24] 0 [30] . [d9] . [f4] . [04] . [c0] . [80] . [91] . [80] . [00] . [8f] w [77] . [03] . [c0] . [80] . [91] . [80] . [00] . [8f] } [7d] . [80] . [93] . [80] . [00] . [10] . [c0] . [84] . [b5] . [8f] w [77] . [02] . [c0] . [84] . [b5] . [8f] } [7d] . [84] . [bd] . [09] . [c0] . [80] . [91] . [b0] . [00] . [8f] w [77] . [03] . [c0] . [80] . [91] . [b0] . [00] . [8f] } [7d] . [80] . [93] . [b0] . [00] . [89] / [2f] . [90] . [e0] . [88] . [0f] . [99] . [1f] . [8a] ^ [5e] . [9c] O [4f] . [fc] . [01] . [a5] . [91] . [b4] . [91] . [8c] . [91] [20] . [e0] 0 [30] . [e0] . [84] # [23] . [11] . [f0] ! [21] . [e0] 0 [30] . [e0] . [c9] . [01] [20]
#avrdude: Send: U [55] . [00] . [1a] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [08] . [95] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] O [4f] . [93] . [8f] . [93] . [9f] . [93] . [ef] . [93] . [ff] . [93] @ [40] . [91] . [c6] . [00] [20] . [91] I [49] . [03] 0 [30] . [91] J [4a] . [03] / [2f] _ [5f] ? [3f] O [4f] / [2f] s [73] 0 [30] p [70] . [80] . [91] K [4b] . [03] . [90] . [91] L [4c] . [03] ( [28] . [17] 9 [39] . [07] Y [59] . [f0] . [e0] . [91] I [49] . [03] . [f0] . [91] J [4a] . [03] . [e7] _ [5f] . [fc] O [4f] @ [40] . [83] 0 [30] . [93] J [4a] . [03] [20] . [93] I [49] . [03] . [ff] . [91] . [ef] . [91] . [9f] . [91] . [8f] . [91] O [4f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [e0] . [91] . [9d] . [03] . [f0] . [91] . [9e] . [03] . [e0] \ [5c] . [ff] O [4f] . [81] . [91] . [91] . [91] [20] . [81] 1 [31] . [81] [20]
avrdude: Send: U [55] @ [40] . [1a] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [82] . [1b] . [93] . [0b] . [8f] s [73] . [90] p [70] . [89] + [2b] . [11] . [f0] . [0e] . [94] . [01] . [1a] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] . [8f] . [93] . [9f] . [93] . [ef] . [93] . [ff] . [93] [20] . [91] . [8d] . [03] 0 [30] . [91] . [8e] . [03] . [80] . [91] . [8f] . [03] . [90] . [91] . [90] . [03] ( [28] . [17] 9 [39] . [07] 1 [31] . [f4] . [80] . [91] . [c1] . [00] . [8f] } [7d] . [80] . [93] . [c1] . [00] . [14] . [c0] . [e0] . [91] . [8f] . [03] . [f0] . [91] . [90] . [03] . [e3] [ [5b] . [fc] O [4f] [20] . [81] . [80] . [91] . [8f] . [03] . [90] . [91] . [90] . [03] . [01] . [96] . [8f] s [73] . [90] p [70] . [90] . [93] . [90] . [03] . [80] . [93] . [8f] . [03] [20] . [93] . [c6] . [00] . [ff] . [91] . [ef] . [91] . [9f] . [91] . [8f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] [20]
avrdude: Send: U [55] . [80] . [1a] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [af] . [92] . [bf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [cf] . [93] . [df] . [93] . [ec] . [01] z [7a] . [01] . [8b] . [01] . [dd] $ [24] @ [40] 0 [30] . [81] . [ee] X [58] . [07] . [80] . [e0] h [68] . [07] . [80] . [e0] x [78] . [07] . [11] . [f0] . [dd] $ [24] . [d3] . [94] . [91] . [e0] . [a9] . [2e] . [b1] , [2c] . [ec] . [89] . [fd] . [89] . [dd] [20] i [69] . [f0] . [c5] . [01] . [0e] . [8c] . [02] . [c0] . [88] . [0f] . [99] . [1f] . [0a] . [94] . [e2] . [f7] . [80] . [83] ` [60] . [e0] y [79] . [e0] . [8d] . [e3] . [90] . [e0] . [05] . [c0] . [10] . [82] ` [60] . [e8] t [74] . [e8] . [8e] . [e1] . [90] . [e0] . [a8] . [01] . [97] . [01] . [0e] . [94] . [7f] . [1c] ! [21] P [50] 0 [30] @ [40] @ [40] @ [40] P [50] @ [40] V [56] . [95] G [47] . [95] 7 [37] . [95] ' [27] . [95] [20]
#avrdude: Send: U [55] . [c0] . [1a] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [80] . [e1] [20] 0 [30] 8 [38] . [07] [20] . [f0] . [dd] [20] . [11] . [f0] . [dd] $ [24] . [d6] . [cf] . [e8] . [89] . [f9] . [89] 0 [30] . [83] . [ea] . [89] . [fb] . [89] [20] . [83] . [ee] . [89] . [ff] . [89] @ [40] . [81] ! [21] . [e0] 0 [30] . [e0] . [c9] . [01] . [0a] . [8c] . [02] . [c0] . [88] . [0f] . [99] . [1f] . [0a] . [94] . [e2] . [f7] H [48] + [2b] @ [40] . [83] . [ee] . [89] . [ff] . [89] @ [40] . [81] . [c9] . [01] . [0b] . [8c] . [02] . [c0] . [88] . [0f] . [99] . [1f] . [0a] . [94] . [e2] . [f7] H [48] + [2b] @ [40] . [83] . [ee] . [89] . [ff] . [89] @ [40] . [81] . [c9] . [01] . [0c] . [8c] . [02] . [c0] . [88] . [0f] . [99] . [1f] . [0a] . [94] . [e2] . [f7] H [48] + [2b] @ [40] . [83] . [ee] . [89] . [ff] . [89] . [80] . [81] . [0d] . [8c] . [02] . [c0] " [22] . [0f] 3 [33] . [1f] . [0a] . [94] . [e2] . [f7] [20] . [95] ( [28] # [23] [20] . [83] [20]
avrdude: Send: U [55] . [00] . [1b] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [df] . [91] . [cf] . [91] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [bf] . [90] . [af] . [90] . [08] . [95] . [dc] . [01] . [1c] . [96] . [ed] . [91] . [fc] . [91] . [1d] . [97] . [e0] \ [5c] . [ff] O [4f] ! [21] . [91] 1 [31] . [91] . [80] . [81] . [91] . [81] ( [28] . [1b] 9 [39] . [0b] / [2f] s [73] 0 [30] p [70] . [c9] . [01] . [08] . [95] . [dc] . [01] . [1c] . [96] . [ed] . [91] . [fc] . [91] . [1d] . [97] . [e0] \ [5c] . [ff] O [4f] [20] . [81] 1 [31] . [81] . [e0] T [54] . [f0] @ [40] . [df] . [01] . [ae] [ [5b] . [bf] O [4f] . [8d] . [91] . [9c] . [91] . [11] . [97] ( [28] . [17] 9 [39] . [07] . [19] . [f4] / [2f] . [ef] ? [3f] . [ef] . [07] . [c0] . [8d] . [91] . [9c] . [91] . [e8] . [0f] . [f9] . [1f] . [80] . [81] ( [28] / [2f] 0 [30] . [e0] . [c9] . [01] . [08] . [95] . [dc] . [01] . [1c] . [96] . [ed] . [91] . [fc] . [91] . [1d] . [97] [20]
#avrdude: Send: U [55] @ [40] . [1b] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [e0] \ [5c] . [ff] O [4f] [20] . [81] 1 [31] . [81] . [e0] T [54] . [f0] @ [40] . [df] . [01] . [ae] [ [5b] . [bf] O [4f] . [8d] . [91] . [9c] . [91] . [11] . [97] ( [28] . [17] 9 [39] . [07] . [19] . [f4] / [2f] . [ef] ? [3f] . [ef] . [10] . [c0] . [8d] . [91] . [9c] . [91] . [11] . [97] . [e8] . [0f] . [f9] . [1f] [20] . [81] . [8d] . [91] . [9c] . [91] . [11] . [97] . [01] . [96] . [8f] s [73] . [90] p [70] . [11] . [96] . [9c] . [93] . [8e] . [93] 0 [30] . [e0] . [c9] . [01] . [08] . [95] . [fc] . [01] . [86] . [85] . [97] . [85] . [dc] . [01] . [a0] \ [5c] . [bf] O [4f] . [fc] . [01] . [ee] [ [5b] . [ff] O [4f] - [2d] . [91] < [3c] . [91] . [11] . [97] . [80] . [81] . [91] . [81] ( [28] . [17] 9 [39] . [07] . [c1] . [f7] . [08] . [95] . [cf] . [93] . [df] . [93] . [ec] . [01] . [ee] . [85] . [ff] . [85] . [e0] \ [5c] . [ff] O [4f] [20] . [81] 1 [31] . [81] . [e0] T [54] [20]
avrdude: Send: U [55] . [80] . [1b] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [f0] @ [40] / [2f] _ [5f] ? [3f] O [4f] / [2f] s [73] 0 [30] p [70] . [df] . [01] . [ae] [ [5b] . [bf] O [4f] . [8d] . [91] . [9c] . [91] . [11] . [97] ( [28] . [17] 9 [39] . [07] . [d1] . [f3] . [e0] \ [5c] . [ff] O [4f] . [80] . [81] . [91] . [81] . [e0] T [54] . [f0] @ [40] . [e8] . [0f] . [f9] . [1f] ` [60] . [83] . [ee] . [85] . [ff] . [85] . [e0] \ [5c] . [ff] O [4f] 1 [31] . [83] [20] . [83] . [ee] . [89] . [ff] . [89] [20] . [81] . [81] . [e0] . [90] . [e0] . [0d] . [8c] . [02] . [c0] . [88] . [0f] . [99] . [1f] . [0a] . [94] . [e2] . [f7] ( [28] + [2b] [20] . [83] . [81] . [e0] . [90] . [e0] . [df] . [91] . [cf] . [91] . [08] . [95] . [10] . [92] . [94] . [03] . [10] . [92] . [93] . [03] . [88] . [ee] . [93] . [e0] . [a0] . [e0] . [b0] . [e0] . [80] . [93] . [95] . [03] . [90] . [93] . [96] . [03] . [a0] . [93] . [97] . [03] . [b0] . [93] . [98] . [03] . [87] . [e6] [20]
#avrdude: Send: U [55] . [c0] . [1b] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [91] . [e0] . [90] . [93] . [92] . [03] . [80] . [93] . [91] . [03] . [89] . [e0] . [93] . [e0] . [90] . [93] . [9e] . [03] . [80] . [93] . [9d] . [03] . [8d] . [e4] . [93] . [e0] . [90] . [93] . [a0] . [03] . [80] . [93] . [9f] . [03] . [85] . [ec] . [90] . [e0] . [90] . [93] . [a2] . [03] . [80] . [93] . [a1] . [03] . [84] . [ec] . [90] . [e0] . [90] . [93] . [a4] . [03] . [80] . [93] . [a3] . [03] . [80] . [ec] . [90] . [e0] . [90] . [93] . [a6] . [03] . [80] . [93] . [a5] . [03] . [81] . [ec] . [90] . [e0] . [90] . [93] . [a8] . [03] . [80] . [93] . [a7] . [03] . [86] . [ec] . [90] . [e0] . [90] . [93] . [aa] . [03] . [80] . [93] . [a9] . [03] . [84] . [e0] . [80] . [93] . [ab] . [03] . [83] . [e0] . [80] . [93] . [ac] . [03] . [87] . [e0] . [80] . [93] . [ad] . [03] . [85] . [e0] . [80] . [93] . [ae] . [03] . [81] . [e0] . [80] . [93] . [af] . [03] . [08] . [95] . [cf] . [93] [20]
avrdude: Send: U [55] . [00] . [1c] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [df] . [93] . [0e] . [94] . [be] . [18] . [0e] . [94] ^ [5e] . [02] . [c6] . [e3] . [da] . [e1] . [0e] . [94] \ [5c] . [02] [20] . [97] . [e1] . [f3] . [0e] . [94] 6 [36] . [1a] . [f9] . [cf] . [08] . [95] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [cf] . [93] . [df] . [93] | [7c] . [01] k [6b] . [01] . [8a] . [01] . [c0] . [e0] . [d0] . [e0] . [0f] . [c0] . [d6] . [01] m [6d] . [91] m [6d] . [01] . [d7] . [01] . [ed] . [91] . [fc] . [91] . [01] . [90] . [f0] . [81] . [e0] - [2d] . [c7] . [01] . [09] . [95] . [c8] . [0f] . [d9] . [1f] . [01] P [50] . [10] @ [40] . [01] . [15] . [11] . [05] q [71] . [f7] . [ce] . [01] . [df] . [91] . [cf] . [91] . [1f] . [91] . [0f] . [91] . [ff] . [90] . [ef] . [90] . [df] . [90] . [cf] . [90] . [08] . [95] b [62] . [9f] . [d0] . [01] s [73] . [9f] . [f0] . [01] . [82] . [9f] . [e0] . [0d] . [f1] . [1d] [20]
avrdude: Send: U [55] @ [40] . [1c] [20]
avrdude: Send: d [64] . [00] . [80] F [46] d [64] . [9f] . [e0] . [0d] . [f1] . [1d] . [92] . [9f] . [f0] . [0d] . [83] . [9f] . [f0] . [0d] t [74] . [9f] . [f0] . [0d] e [65] . [9f] . [f0] . [0d] . [99] ' [27] r [72] . [9f] . [b0] . [0d] . [e1] . [1d] . [f9] . [1f] c [63] . [9f] . [b0] . [0d] . [e1] . [1d] . [f9] . [1f] . [bd] . [01] . [cf] . [01] . [11] $ [24] . [08] . [95] . [aa] . [1b] . [bb] . [1b] Q [51] . [e1] . [07] . [c0] . [aa] . [1f] . [bb] . [1f] . [a6] . [17] . [b7] . [07] . [10] . [f0] . [a6] . [1b] . [b7] . [0b] . [88] . [1f] . [99] . [1f] Z [5a] . [95] . [a9] . [f7] . [80] . [95] . [90] . [95] . [bc] . [01] . [cd] . [01] . [08] . [95] . [97] . [fb] . [09] . [2e] . [07] & [26] . [0a] . [d0] w [77] . [fd] . [04] . [d0] . [e5] . [df] . [06] . [d0] . [00] [20] . [1a] . [f4] p [70] . [95] a [61] . [95] . [7f] O [4f] . [08] . [95] . [f6] . [f7] . [90] . [95] . [81] . [95] . [9f] O [4f] . [08] . [95] . [a1] . [e2] [20]
#avrdude: Send: U [55] . [80] . [1c] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [1a] . [2e] . [aa] . [1b] . [bb] . [1b] . [fd] . [01] . [0d] . [c0] . [aa] . [1f] . [bb] . [1f] . [ee] . [1f] . [ff] . [1f] . [a2] . [17] . [b3] . [07] . [e4] . [07] . [f5] . [07] [20] . [f0] . [a2] . [1b] . [b3] . [0b] . [e4] . [0b] . [f5] . [0b] f [66] . [1f] w [77] . [1f] . [88] . [1f] . [99] . [1f] . [1a] . [94] i [69] . [f7] ` [60] . [95] p [70] . [95] . [80] . [95] . [90] . [95] . [9b] . [01] . [ac] . [01] . [bd] . [01] . [cf] . [01] . [08] . [95] . [ee] . [0f] . [ff] . [1f] . [05] . [90] . [f4] . [91] . [e0] - [2d] . [09] . [94] . [f8] . [94] . [ff] . [cf] M [4d] e [65] m [6d] o [6f] r [72] y [79] [20] U [55] p [70] d [64] a [61] t [74] e [65] d [64] . [00] Y [59] o [6f] u [75] [20] c [63] a [61] n [6e] [20] n [6e] o [6f] w [77] . [00] u [75] p [70] l [6c] o [6f] a [61] d [64] [20] y [79] o [6f] u [75] r [72] . [00] I [49] N [4e] O [4f] [20] c [63] o [6f] d [64] [20]
avrdude: Send: U [55] . [c0] . [1c] [20]
avrdude: Send: d [64] . [00] F [46] F [46] e [65] . [00] , [2c] . [01] . [00] . [00] . [01] . [00] . [00] . [00] . [00] 4 [34] . [05] . [03] . [05] . [b2] . [04] . [bb] . [04] . [d0] . [04] . [e1] . [04] . [1f] . [1c] . [1f] . [1e] . [1f] . [1e] . [1f] . [1f] . [1e] . [1f] . [1e] . [1f] . [00] . [00] . [00] . [00] . [0e] . [1c] . [00] . [00] . [00] . [00] . [e6] . [15] . [00] . [00] . [00] . [00] . [dd] . [15] . [00] . [00] . [00] . [00] v [76] . [1b] . [0f] . [1c] . [0a] . [1b] ; [3b] . [1b] . [1b] . [1b] d [64] . [1b] . [00] [20]
# | 100% 5.55s
avrdude: 14790 bytes of flash written
avrdude: Send: Q [51] [20]
avrdude done. Thank you.
Re: New User Questions
Posted: Wed Jan 29, 2014 7:34 pm
Yes, it does look like the internal memory file is being uploaded correctly.
Can you post the internal memory code?
/dev/tty.usbserial is for MacOSX and COM is for Windows.
Posted: Wed Jan 29, 2014 7:42 pm
by howaboutme
Ok..So I found this post from not too far ago:
http://forum.reefangel.com/viewtopic.php?f=15&t=4085
I downloaded the ino file there and uploaded it to the head unit. It seems to have worked and now says "Memory Updated You can now upload your INO code". From there, I uploaded my code and it all works.
For your record, this is the BAD code:
ReefAngel.Init();
InternalMemory.MHOnHour_write(15);
InternalMemory.MHOnMinute_write(30);
InternalMemory.MHOffHour_write(21);
InternalMemory.MHDelay_write(7);
InternalMemory.StdLightsOnHour_write(14);
InternalMemory.StdLightsOffHour_write(21);
InternalMemory.StdLightsOffMinute_write(30);
InternalMemory.DP1Timer_write(4);
InternalMemory.DP2Timer_write(4);
InternalMemory.LEDPWMActinic_write(20);
InternalMemory.LEDPWMDaylight_write(20);
InternalMemory.WM1Timer_write(10);
InternalMemory.WM2Timer_write(15);
InternalMemory.HeaterTempOn_write(766);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(774);
InternalMemory.ChillerTempOff_write(770);
InternalMemory.PHMax_write(830);
InternalMemory.PHMin_write(540);
InternalMemory.ORPMax_write(285);
InternalMemory.ORPMin_write(1400);
InternalMemory.RFMode_write(Constant);
InternalMemory.RFSpeed_write(50);
InternalMemory.RFDuration_write(8);
InternalMemory.PWMSlopeEndD_write(100);
InternalMemory.PWMSlopeEndA_write(100);
InternalMemory.PWMSlopeStart0_write(15);
InternalMemory.PWMSlopeEnd0_write(100);
InternalMemory.PWMSlopeDuration0_write(60);
InternalMemory.PWMSlopeStart1_write(15);
InternalMemory.PWMSlopeEnd1_write(100);
InternalMemory.PWMSlopeDuration1_write(60);
InternalMemory.PWMSlopeStart2_write(15);
InternalMemory.PWMSlopeEnd2_write(100);
InternalMemory.PWMSlopeDuration2_write(60);
InternalMemory.PWMSlopeStart3_write(15);
InternalMemory.PWMSlopeEnd3_write(100);
InternalMemory.PWMSlopeDuration3_write(60);
InternalMemory.PWMSlopeStart4_write(15);
InternalMemory.PWMSlopeEnd4_write(100);
InternalMemory.PWMSlopeDuration4_write(60);
InternalMemory.PWMSlopeStart5_write(15);
InternalMemory.PWMSlopeEnd5_write(100);
InternalMemory.PWMSlopeDuration5_write(60);
InternalMemory.ATOExtendedTimeout_write(120);
InternalMemory.ORPMin_write(2050);
InternalMemory.ORPMax_write(450);
InternalMemory.ActinicOffset_write(30);
InternalMemory.CO2ControlOn_write(770);
InternalMemory.CO2ControlOff_write(760);
InternalMemory.PHControlOn_write(800);
InternalMemory.PHControlOff_write(810);
InternalMemory.AISlopeStartW_write(0);
InternalMemory.AISlopeEndW_write(100);
InternalMemory.AISlopeDurationW_write(60);
InternalMemory.AISlopeStartB_write(0);
InternalMemory.AISlopeEndB_write(100);
InternalMemory.AISlopeDurationB_write(60);
InternalMemory.AISlopeStartRB_write(0);
InternalMemory.AISlopeEndRB_write(100);
InternalMemory.AISlopeDurationRB_write(60);
InternalMemory.RadionSlopeStartW_write(0);
InternalMemory.RadionSlopeEndW_write(100);
InternalMemory.RadionSlopeDurationW_write(60);
InternalMemory.RadionSlopeStartRB_write(0);
InternalMemory.RadionSlopeEndRB_write(100);
InternalMemory.RadionSlopeDurationRB_write(60);
InternalMemory.RadionSlopeStartR_write(0);
InternalMemory.RadionSlopeEndR_write(100);
InternalMemory.RadionSlopeDurationR_write(60);
InternalMemory.RadionSlopeStartG_write(0);
InternalMemory.RadionSlopeEndG_write(100);
InternalMemory.RadionSlopeDurationG_write(60);
InternalMemory.RadionSlopeStartB_write(0);
InternalMemory.RadionSlopeEndB_write(100);
InternalMemory.RadionSlopeDurationB_write(60);
InternalMemory.RadionSlopeStartI_write(0);
InternalMemory.RadionSlopeEndI_write(100);
InternalMemory.RadionSlopeDurationI_write(60);
InternalMemory.DelayedStart_write(7);
InternalMemory.PHExpMax_write(2500);
InternalMemory.PHExpMin_write(500);
InternalMemory.WaterLevelMax_write(3575);
InternalMemory.WaterLevelMin_write(2875);
InternalMemory.SalTempComp_write(750);
InternalMemory.WaterLevelLow_write(60);
InternalMemory.WaterLevelHigh_write(65);
InternalMemory.DP3Timer_write(4);
InternalMemory.DP3RepeatInterval_write(60);
InternalMemory.DCPumpMode_write(0);
InternalMemory.DCPumpSpeed_write(50);
InternalMemory.DCPumpDuration_write(50);
InternalMemory.WaterLevel1Max_write(1900);
InternalMemory.WaterLevel1Min_write(590);
InternalMemory.WaterLevel2Max_write(1900);
InternalMemory.WaterLevel2Min_write(590);
InternalMemory.WaterLevel3Max_write(1900);
InternalMemory.WaterLevel3Min_write(590);
InternalMemory.WaterLevel4Max_write(1900);
InternalMemory.WaterLevel4Min_write(590);
InternalMemory.IMCheck_write(0xCF06A31E);
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+20, MENU_START_ROW*3, "Memory Updated");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*6, "You can now");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*7, "upload your");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+33, MENU_START_ROW*8, "INO code") ;
wdt_reset();
Am I to assume all is ok so far or is there a more up to date initialinternalmemory file?
Posted: Wed Jan 29, 2014 7:58 pm
by howaboutme
Ok..continuing my exploration...
I noticed a couple of things when I uploaded the code I made using the wizard. When I toggle the head unit, the heater settings did not match the settings set via the wizard. The overheat set also did not match what was set. I did actually check the code and the code was generated correctly. I changed it via the head unit but that doesn't seem right to do since the wizard should have done it for me.
Also, I get an error for T1, T2 and T3. I have the temp probe plugged in the center (assuming that's T2). Shouldn't that read something? I did put it in a cup of water and still error. The ph probe seems to be fine as it's just reading the solution from the cap.
Thanks all (especially Roberto) for being patient in reading and answering my questions.
