how to add additional wavemakers
Posted: Wed Apr 27, 2011 9:21 am
by tngo
Hello All,
Just got a RA and am tinkering with it a bit. So far it is a very neat device, and has done what I have needed it to. The RAgen and the tutorials are a very good starting point to get what you need from the controller.
One question I have come across is how best to add additional wavemakers to the controller. As of right now there are only 2 and I would like to add a couple more. I don't see any options in the RAgen, so would assume that I would have to add some lines of code into the libraries. Just wondering how best to approach this problem.
Tim
Re: how to add additional wavemakers
Posted: Wed Apr 27, 2011 7:13 pm
tngo wrote: Just got a RA and am tinkering with it a bit. So far it is a very neat device, and has done what I have needed it to. The RAgen and the tutorials are a very good starting point to get what you need from the controller.
Thanks. Glad it's helpful for a good starting point. That's the goal of it....to provide a good starting point that will help with most of the basics. The "extra stuff" requires a little more work.
tngo wrote: One question I have come across is how best to add additional wavemakers to the controller. As of right now there are only 2 and I would like to add a couple more. I don't see any options in the RAgen, so would assume that I would have to add some lines of code into the libraries. Just wondering how best to approach this problem.
First off, I will say that it is not recommended to make changes to the libraries. This makes it harder when/if you upgrade the libraries to newer versions. You have to re-add in all of your changes and if there have been any major changes to the libraries it can take a little while to get things back running properly again. We have run into these situations before where people made changes and then upgraded and things didn't work right. I spent a few hours trying to help somebody only to find out that they had made changes and forgot to mention it. :)
Now that has been said, in order to accomplish what you are wanting to do with additional wavemakers on their own intervals, modifying the libraries is necessary at this current time. The drawback is you have to manually code the intervals for the additional wavemakers and cannot use the setup menu on the controller to change the intervals.
I'm going to give an example based off of adding 2 more wavemakers to the setup. I'm going to assume wavemakers 3 & 4 are attached to ports 6 and 7 (wavemaker 1 & 2 are on ports 4 & 5 respectively by default unless they are changed).
The first change we must make is to the ReefAngel.h file. We need to add in 2 additional timers to the timer group. To do this, you need to open up the ReefAngel.h file in the libraries/ReefAngel/ folder. Look for this line:
ReefAngel_TimerClass Timer[6];
You need to change that line to be this
ReefAngel_TimerClass Timer[8];  // Added 2 additional timers
Once this change has been made, save the file. This is all the changes that you need to make to the libraries.
Now, we need to add in the code to your PDE file to activate the 2 new wavemakers.
In the setup() section of your PDE file, you need to add this:
  // existing code goes here
  // Set the intervals for the 2 additional wavemakers, value can be from 0 - 21600 seconds
  ReefAngel.Timer[6].SetInterval(1800);  // Wavemaker 3 with 1800s interval
  ReefAngel.Timer[6].Start();  // Start Wavemaker 3 timer
  ReefAngel.Relay.On(Port6);  // Turn on Wavemaker 3
  ReefAngel.Timer[7].SetInterval(2700);  // Wavemaker 4 with 2700s interval
  ReefAngel.Timer[7].Start();  // Start Wavemaker 4 timer
  ReefAngel.Relay.On(Port7);  // Turn on Wavemaker 4
  // Relay.On() function calls
Moving down to the loop() section, we will add this:
  // code for ports
  ReefAngel.Wavemaker(Port6, 6);  // Wavemaker 3 attached to Port6 using Timer6
  ReefAngel.Wavemaker(Port7, 7);  // Wavemaker 4 attached to Port7 using Timer7
  // exising code for any web banner stuff
Then you should just save the PDE file and you are ready to go. If you ever needed to change the interval, you would just modify it in the setup() section and re-upload it to the controller. :geek:
Curt
Posted: Thu Apr 28, 2011 9:06 am
May I suggest another approach?
Why not create 2 new instances of Timer and have Relay.Toggle() every time the timer expires?
I think the libraries modification is not recommended as Curt said.
This approach will not give you the menu driven setup of the wavemaker that Curt has in his RAGen, but it is a solution.
Posted: Thu Apr 28, 2011 12:12 pm
by tngo
Thanks for the example Curt, I will have to give it a spin later today. Will also try what Roberto suggested and see which works best.
Thanks for the help guys, again great work on the controller and support!
Tim
Posted: Thu Apr 28, 2011 1:16 pm
rimai wrote:May I suggest another approach?
Yep, this actually is the best solution. My brain wasn't fully functioning with all the possible solutions last night. And I'm always thinking in library mode because I maintain it. :)
Here's the solution that Roberto is talking about:
//  ... other code
ReefAngel_TimerClass wmtimers[2];
// setup
  // Wavemaker 3 timer
  wmtimers[0].SetInterval(1800);
  wmtimers[0].Start();
  // Wavemaker 4 timer
  wmtimers[1].SetInterval(2700);
  wmtimers[1].Start();
  // check for wavemaker 3 toggling
  if ( wmtimers[0].IsTriggered() )
  // check for wavemaker 4 toggling
  if ( wmtimers[1].IsTriggered() )
    ReefAngel.Relay.Toggle(Port7);
This would be the PDE solution for the problem. This actually is the best way to handle it so there is no modification to the libraries. This code is exactly what the library code does too.
I'd actually recommend this over my solution for simplicity.
Posted: Fri Apr 29, 2011 5:25 pm
by tngo
Works like a charm.
Thanks guys.
Tim
