Wp25 quit
Posted: Tue Jan 28, 2014 12:00 pm
by chapboogie
One of my 25's quit. This one has only been in my tank Since November. My other one had been running since May. I cleaned it, even soaked it over night. Still not working. The impeller engages and sometimes a quick spin, but won't keep going.
Any suggestions? Is my pump shot? If so, is there a place to just get the pump cheap. I bought these in a group buy.
Sent from my SCH-I535 using Tapatalk
Re: Wp25 quit
Posted: Tue Jan 28, 2014 12:02 pm
Try switching the power supply with your other one. It may not be the pump itself.
Re: Wp25 quit
Posted: Tue Jan 28, 2014 12:08 pm
by chapboogie
Still not working
Re: Wp25 quit
Posted: Tue Jan 28, 2014 12:11 pm
Sorry man
Re: Wp25 quit
Posted: Tue Jan 28, 2014 1:02 pm
Be glad its not a $300 mp10. You can get replacement parts from fish street i believe
Re: Wp25 quit
Posted: Tue Jan 28, 2014 2:14 pm
by chapboogie
So after letting it dry for a few hours, I plugged it in and it worked. It seemed a bit weak. I put it in the water and a minute later it quit. Hmmmm
Re: Wp25 quit
Posted: Tue Jan 28, 2014 2:19 pm
by KRavEN
I had a similar thing happen with a WP40 that I was temporarily running with reduced voltage instead of the full 24v. Were you supplying less than 24v or using one of those dimmers to reduce the voltage?
Re: Wp25 quit
Posted: Tue Jan 28, 2014 2:30 pm
by chapboogie
I'm using the reef angel cable
Re: Wp25 quit
Posted: Tue Jan 28, 2014 9:53 pm
by chapboogie
KRavEN wrote:I had a similar thing happen with a WP40 that I was temporarily running with reduced voltage instead of the full 24v. Were you supplying less than 24v or using one of those dimmers to reduce the voltage?
Did yours come back?
Re: Wp25 quit
Posted: Tue Jan 28, 2014 9:59 pm
by KRavEN
nope, what voltage power supply were you using?
Re: Wp25 quit
by chapboogie
The one that comes with
Re: Wp25 quit
Posted: Sun Feb 23, 2014 8:32 am
by Piper
I'm a little late on this but, if you haven't already done so, try re-seating the impeller. I had one of two new 25s do that to me as well after about a week of use. After 3 or 4 times of re-seating the impeller it's bee working fine since. That was about 3 months ago.
~Charlie
