Yet another......What do I need post.
Posted: Mon Feb 03, 2014 10:20 am
by jgsplat
Hey guys,
I'm ready to submit my order for a Reef Angel Plus and modules but would like you guys to review it and make sure I'm not missing anything here.
My setup and plan is as such. I have my display tank overflowing into sump 1(20 gallon), which contains my protein skimmer and a Jebao DC1200 pump used to move the water to sump 2(40 gallon) containing my refugium, bubble trap, and another Jebao DC1200 pump to return back to the display tank.
I would like to use the Multi-Channel Water Level Expansion module and Dimming Expansion module to monitor and control the DC1200 speeds to keep the water levels at a set height.
I would like to control my two Jabeo wavemakers (WP-25 and WP-40) also with the Dimming Expansion module.
My Refugium LED light I would like to only turn on and off. Therefore I was planning on just plugging it into the relay outlet box.
Wi-Fi Module for remote access.
So here's my list:
Reef Angel +
Expansion Hub
Dimming Expansion
Wi-Fi module
Am I forgetting anything? Any other suggestions or comment? Thanks guys!
Josh
Re: Yet another......What do I need post.
Posted: Mon Feb 03, 2014 11:26 am
I think you are missing the jebao cables... One per pump.
Posted: Mon Feb 03, 2014 11:53 am
by jgsplat
Thanks Roberto!
I have several cables that have the 3 pin connector on one and an exposed wires on the other. I was going to make my own custom cable to length. Which I guess leads me to the question of what do I need to terminate the other side of my cable with that connects to your dimmer module?
Posted: Mon Feb 03, 2014 12:10 pm
nothing... The dimming module has screw terminals
Posted: Mon Feb 03, 2014 12:16 pm
by jgsplat
Perfect! That will sure make life easy. Thanks Roberto! I've also heard your local? I work in Milpitas and live in Fremont.
