Easy question, but I can't seem to find the answer...can I use more than one dimming expansion module...on one RA controller? (I'd like TWO) & (I have the expansion hub)...I would like to run/control 2 different tank's DIY LEDs and require about 10 channels of control for proper adjustment(s).
More than ONE PWM expansion?
Re: More than ONE PWM expansion?
Although you could, it would require custom code as our libraries only support 1 module.
Cariba
I see, thanks for the QUICK reply....I guess I will have to see if I can get a request in for that....?
what about 2 modules in regards to the client suite....? It would need to also be revised?
The hardware is capable and is all set to go as it is.
With the current libraries, you can control all 6 channels of one module.
The 2nd module would need custom code.
