More than ONE PWM expansion?
Posted: Mon Feb 03, 2014 2:56 pm
by Cariba
Easy question, but I can't seem to find the answer...can I use more than one dimming expansion module...on one RA controller? (I'd like TWO) & (I have the expansion hub)...I would like to run/control 2 different tank's DIY LEDs and require about 10 channels of control for proper adjustment(s).
Re: More than ONE PWM expansion?
Posted: Mon Feb 03, 2014 3:05 pm
Although you could, it would require custom code as our libraries only support 1 module.
Posted: Mon Feb 03, 2014 3:10 pm
by Cariba
I see, thanks for the QUICK reply....I guess I will have to see if I can get a request in for that....?
what about 2 modules in regards to the client suite....? It would need to also be revised?
Posted: Mon Feb 03, 2014 3:19 pm
The hardware is capable and is all set to go as it is.
With the current libraries, you can control all 6 channels of one module.
The 2nd module would need custom code.
