Water Level Sensor controlling DC Return Pump
Posted: Fri Feb 07, 2014 3:14 pm
by jgsplat
Can I please see some coded examples of anyone who uses the water level expansion module to adjust your DC return pumps control line via the dimming module?
Roberto I know you do this. Can you post some code please?
Josh
Re: Water Level Sensor controlling DC Return Pump
Posted: Fri Feb 07, 2014 3:25 pm
This is what I started with....
http://forum.reefangel.com/viewtopic.php?p=28750#p28750
Eventually I migrated that code into my controller and used the dimming expansion to change the pump speed.
Here is the code:
Variables to declare
#define Level         50
#define MinPWM        50
long nummillis=5000;
byte PWMValue=0;
boolean override=false;
Code inside loop():
  PWMValue=InternalMemory.PWMSlopeEnd0_read();
  if (ReefAngel.WaterLevel.GetLevel(1)<Level-2)
    override=true;
    PWMValue+=2;
  if (ReefAngel.WaterLevel.GetLevel(1)>Level+2)
    override=true;
    PWMValue-=2;
  if (millis()-lastmillis>nummillis && override)
    override=false;
  if (!override) PWMValue=InternalMemory.PWMSlopeEnd0_read();
  if (ReefAngel.WaterLevel.GetLevel(1)>Level+10) PWMValue=MinPWM;
  PWMValue=constrain(PWMValue,MinPWM,100);
    ReefAngel.PWM.SetChannel(ReturnPWM,45);
    ReefAngel.PWM.SetChannel(ReturnPWM,PWMValue);
I also have a mechanical float switch in series with the jebao cable that cuts off the dimming signal to the pump in case of blockage in the drain pipe.
When there is a blockage in the drain pipe, the level rises too fast for the sensor to instruct the pump to turn off.
Posted: Fri Feb 07, 2014 3:59 pm
by jgsplat
Great! Thanks Roberto!
