Wifi blue green flashing light
I tried to update the firmware it failed now the green and blue light blink and it shows when trying to configure wifi the ip address as 0.0.0:2000 any ideas
Re: Wifi blue green flashing light
The manufacturer messed up once again.
They made the firmware not backward compatible.
You will need to setup the settings from scratch to make it work.
The solution is in this thread:
http://forum.reefangel.com/viewtopic.ph ... 4&start=10
that fixed it thanks
