Actinic port not working
Posted: Sun Feb 16, 2014 6:53 am
by jjdezek
I got two wp40s and I noticed they weren't on so I started messing with them (unplugged and plugged back in) and managed to get one working but the other one wouldn't come on. When I switch them from the actinic ports the one port doesn't come on. Any ideas?
Re: Actinic port not working
Posted: Sun Feb 16, 2014 9:46 am
What % do you see in the screen?
What code are you using?
Looking at your chart, there is something wrong that you are doing....
http://forum.reefangel.com/status/webch ... ilter=pwma
The PWM should not be over 100%
Posted: Sun Feb 16, 2014 11:50 am
by jjdezek
Not sure what changed, I reloaded my codes when I added the dosing pump Thursday. I will post my code later when I get home.
Posted: Sun Feb 16, 2014 4:28 pm
by jjdezek
Got it figured out. Used an old code, must of had something different set up in it. Used most recent code and added dosing pump code and it's working now.
