Wifi Module Tanked?
Posted: Wed Feb 19, 2014 11:08 pm
Yeah bad pun I know, gotta find some light where there is none.
So this wifi module gave me some troubles about 6 months back, and it cleared up. It is my 2nd one since June. It never would work quite like the manual is written for or like the first one did, I figured the version 4 firmware just changed a few things, like the default for join is a 7 and the default should be a like a 1, and the wlan authentications numbers changed, I could never get it to join automatically and would have to say join (SSID) command and then it would be good.
So anyway, today it stopped working and I figured I would just have to reset it and throw it a join command and all would be good, no...
Here is the end of latest output from the module as I was trying for about the tenth time.
<4.00> set w a 4
AOK
<4.00> get w
SSID=sophie
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=******
EAP_Id=userid
EAP_User=peap-user
<4.00> set PIN9=5
USER-reset
PIN9=6
get w
ERR: 2few Args
<4.00> get w
SSID=testing
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=a01b02c03d
EAP_Id=userid
EAP_User=peap-user
<4.00> PIN9=7
PIN9=8
PIN9=9
Factory-reset
get w
SSID=roving1
Chan=0
ExtAnt=0
Join=0
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=rubygirl
EAP_Id=userid
EAP_User=peap-user
<4.00>
So in the middle setting it up and my typing a set command it just reset, and then shows the SSID is "testing" and then it just did a factory reset and shows the SSID as "roving-1". Sometimes it would get further than others, but everytime it started with the pin9=1 (errors?) feedback it would reset or factory reset.
<4.00> set w a 4
AOK
<4.00> get w
SSID=sophie
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=******
EAP_Id=userid
EAP_User=peap-user
<4.00> set PIN9=5
USER-reset
PIN9=6
get w
ERR: 2few Args
<4.00> get w
SSID=testing
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
EAP_Id=userid
EAP_User=peap-user
<4.00> PIN9=7
PIN9=8
PIN9=9
Factory-reset
get w
SSID=roving1
Chan=0
ExtAnt=0
Join=0
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=rubygirl
EAP_Id=userid
EAP_User=peap-user
<4.00>
