Where's my MAC address?
Posted: Thu Feb 20, 2014 11:35 pm
by monte455
New owner and I am trying to connect the wifi attachment to my networ. I use mac address filtering to secure my networ instead of passwords, so I need to find the mac address of the wifi attachment to enter it into my allowable list. Very much appreciate the help
Re: Where's my MAC address?
Posted: Fri Feb 21, 2014 9:53 am
You would need some sort of serial terminal such as putty or tera term.
The command is:
get mac
If you need more info, page 38 of the manual: http://ww1.microchip.com/downloads/en/D ... 02230A.pdf
The other solution is to let the wifi attachment connect without MAC address restriction and go to connected devices to see which MAC address it shows.
Posted: Fri Feb 21, 2014 6:04 pm
by monte455
Well I got it set, used the Graphical WiFi Utility from Dave Molton on RA's site Then after re-reading the set up information I can see where I might have went wronge. Now I'm off to find out how to set up remote (away from home networ access) :D
