Relay Box Issues
Posted: Mon Mar 03, 2014 10:22 am
by howaboutme
This is a continuation of a question I posted in a larger thread:
http://forum.reefangel.com/viewtopic.ph ... 8&start=90
I want to start fresh to hopefully solve this problem.
Here are questions and responses that pertain to the issue so far:
howaboutme wrote:Can I have some help on what may be going on w/ my setup?
Outlet #6 (used for a ph) in the relay box is suppose to turn off during both water change and feeding modes and has been working correctly but all of a sudden, today, it did not turn off for either. I'm not sure when it went astray but today was the first time I've noticed. I think it worked just a few days ago (at least in feeding mode).
I re generated the code w/ the wizard just now to make sure it was correct and it did not fix it. Is my relax faulty or is something wrong w/ the code? I am using internal memory but the code looks correct as it has the correct ports for both water change and feeding.
Code is:
    ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.ActinicLights( Port4 );
rimai wrote:Use the controllertester code in the examples folder to test each port.
Hmm..interesting thing happened. I tested it this morning and that port worked for both the w/c and the feeding modes. Has anyone heard of situations like this? I have done no manipulation to the controller.
I will try the controllertester code when I get a chance to make sure. Thank you.
roberto..this is in regard to the post about relay #6 not shutting off during feed/wc mode..i did the controllertest code..flipped through it but wasn't sure what to look for. the outlet was on when i flipped to #6. is that what you're testing? thanks.
rimai wrote:You can scroll through each port turning it on and off by moving the joystick. Look at the screen to see which port is turned on.
howaboutme wrote:Yeah, I did that and everything seems to be okay for the test. #6 just won't turn off even though the code is correct. This is the 2nd time this happened. First time, the problem solved itself somehow w/o me doing anything.
rimai wrote:Are you sure you are not overriding the relay port?
No, I am not sure. But I don't think so. I do nothing to the controller before I hit either the feeding or wc mode. I even re-uploaded the code last night to the controller and #6 still didn't recognize the mode. I am thinking tonight I will try to move the ph that's on #6 to an open outlet to test again.
How would I override the relay port? Since I am new I cannot rule that out inadvertently.
I have done some additional testing. I placed the powerhead that was on #6 to an unused relay and everything worked fine for water change and feeding modes. I also used the android app to manually turn off #6, it did not work (it worked for #5, for example). It looks like #6 does not recognize any overrides.
Here is the latest code (it includes relay #1 being used temporarily in place of #6 but I didn't turn relay #6 off because I assume I'll be doing more testing).
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.Portal( "howaboutme" );
Any new thoughts, Roberto or anyone else? Thanks in advance.
Re: Relay Box Issues
Posted: Mon Mar 03, 2014 10:25 am
I think Port6 is not working.
Posted: Mon Mar 03, 2014 10:34 am
by howaboutme
Ok, just needed some confirmation that it wasn't software related. So the only alternative is a replacement?
Posted: Mon Mar 03, 2014 10:46 am
Just plug the relay box only to the wall.
Does the relay stay on without the controller?
Posted: Mon Mar 03, 2014 10:54 am
by howaboutme
It does not stay on.
Sent from my Galaxy Nexus using Tapatalk
Posted: Mon Mar 03, 2014 11:12 am
I think you got a bad cable then.
Is the svga cable the original one?
Posted: Mon Mar 03, 2014 11:26 am
by howaboutme
Yes, it's the original one. How can I get a replacement? Is this a standard svga cable that's readily available? Thank you.
Posted: Mon Mar 03, 2014 11:29 am
It is just a svga cable, but you must be careful to get a good quality one that has all wires inside.
Some manufacturers cut corners by reducing the number of wires and connecting them together.
We also have in the webstore.
If you would like to send it back for me to test, PM me.
