Relay expansion code
Posted: Sat Mar 08, 2014 5:23 pm
by bmhair03
How do I add the exp. relay code to my PDE. I just need all 8 to always be on for now. Thanks
// Autogenerated file by RAGen (v1.2.2.171), (04/02/2012 19:38)
// RA_040212_1938.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define SaveRelayState
#define WDT
#define SIMPLE_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
#define FONT_8x8
#define NUMBERS_16x16
#define RelayExp
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports
// within the code.
// You can change the labels if you would like, just as long as they are
// changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
//End of PWM Expansion Code Header
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding Mode";
prog_char menu1_label[] PROGMEM = "Water Change Mode";
prog_char menu2_label[] PROGMEM = "Force Cloud";
prog_char menu5_label[] PROGMEM = "About Me";
prog_char menu6_label[] PROGMEM = "pH Calibration";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label,
menu5_label, menu6_label};
boolean ForceCloud=false;
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Display"" ""PH");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+21,"LED:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor,
24, y+31, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+21,"SUMP:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], T3TempColor,
x+24, y+31, 10);
x = 15;
y=MENU_START_ROW*7;
y += 4;
ConvertNumToString(text, PWMChannel[LEDPWM0], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "L0:");
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x+18, y, text);
x += 60;
ConvertNumToString(text, PWMChannel[LEDPWM1], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(APColor, DefaultBGColor, x, y, "L1:");
ReefAngel.LCD.DrawText(APColor, DefaultBGColor, x+18, y, text);
x -= 60;
y += MENU_START_ROW;
ConvertNumToString(text, PWMChannel[LEDPWM2], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "L2:");
x += 60;
ConvertNumToString(text, PWMChannel[LEDPWM3], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(APColor, DefaultBGColor, x, y, "L3:");
x -= 60;
ConvertNumToString(text, PWMChannel[LEDPWM4], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "L4:");
x += 60;
ConvertNumToString(text, PWMChannel[LEDPWM5], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(APColor, DefaultBGColor, x, y, "L5:");
//y += 39*2;
// x = 13;
ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
// #ifdef RelayExp
// draw 1st expansion relay
// TempRelay = ReefAngel.Relay.RelayDataE[0];
// TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
// TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
// ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
// #endif RelayExp
// ReefAngel.LCD.DrawGraph(5, 5);
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry4()
ReefAngel.ATOClear();
void MenuEntry5()
ReefAngel.OverheatClear();
void MenuEntry6()
ReefAngel.DisplayVersion();
void MenuEntry7()
ReefAngel.SetupCalibratePH();
ReefAngel.PHMax=690;
ReefAngel.PHMin=270;
ReefAngel.FeedingModePorts = Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
// ReefAngel.Relay.On(Port9);
// ReefAngel.Relay.On(Port(10);
// ReefAngel.Relay.On(Port(11);
// ReefAngel.Relay.On(Port(12);
// ReefAngel.Relay.On(Port(13);
//ReefAngel.Relay.On(Port(14);
// ReefAngel.Relay.On(Port(15);
// ReefAngel.Relay.On(Port(16);
//ReefAngel.Relay.On(Port2);
// InternalMemory.PHMax_write(570);
// InternalMemory.PHMin_write(240);
ReefAngel.StandardLights(Port2,11,00,20,00);
ReefAngel.SingleATOLow(Port8);
ReefAngel.StandardLights(Port3,11,00,19,50);
ReefAngel.StandardLights(Port4,11,00,20,00);
//ReefAngel.StandardFan(Port8);
//ReefAngel.PWM.SetActinic(PWMSlope(10,0,20,00,10,100,60,ReefAngel.PWM.GetActinicValue()));
//ReefAngel.PWM.SetDaylight(PWMSlope(10,30,19,30,10,65,60,ReefAngel.PWM.GetDaylightValue()));
PWMChannel[LEDPWM0]=PWMSlope(11,0,20,0,13,90,60,PWMChannel[LEDPWM0]);
PWMChannel[LEDPWM1]=PWMSlope(11,0,19,50,13,75,50,PWMChannel[LEDPWM1]);
//PWMChannel[LEDPWM2]=MoonPhase();
if (hour()>=20 || hour()<1)
PWMChannel[LEDPWM2]=0;
PWMChannel[LEDPWM3]=PWMSlope(11,0,20,00,13,90,60,PWMChannel[LEDPWM3]);
PWMChannel[LEDPWM4]=PWMSlope(11,0,19,50,13,75,50,PWMChannel[LEDPWM4]);
CheckCloud();
//PWMChannel[LEDPWM5]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM5]);
ReefAngel.PWM.SetChannel(LEDPWM0,PWMChannel[LEDPWM0]);
ReefAngel.PWM.SetChannel(LEDPWM1,PWMChannel[LEDPWM1]);
ReefAngel.PWM.SetChannel(LEDPWM2,PWMChannel[LEDPWM2]);
ReefAngel.PWM.SetChannel(LEDPWM3,PWMChannel[LEDPWM3]);
ReefAngel.PWM.SetChannel(LEDPWM4,PWMChannel[LEDPWM4]);
//PWMExpansion(LEDPWM5,int(2.55*PWMChannel[LEDPWM5]));
ReefAngel.Portal("bmhair03", "nascar03");
void CheckCloud()
// Frequency in days based on the day of the month - number 2 means every 2
// days, for example (day 2,4,6 etc)
// For testing purposes, you can use 1 and cause the cloud to occur
// everyday
#define Clouds_Every_X_Days 1
// For testing purposes, you can use 100 and cause the cloud to have 100%
// chance of happening
#define Cloud_Chance_per_Day 50
// Minimum number of minutes for cloud duration. Don't use max duration of
// less than 6
#define Min_Cloud_Duration 3
// Maximum number of minutes for the cloud duration. Don't use max duration
// of more than 255
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 5
// In this example, start could after 12:00pm
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(19,00)
// For testing purposes, you can use 100 and cause the lightning to have
// 100% chance of happening
#define Lightning_Change_per_Cloud 75
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for
// actinics
#define Actinic_Channels B001001
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is
// triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for
// daylights
#define Daylight_Channels B010010
// Note: Make sure to choose correct values that will work within your
// PWMSLope settings.
// For example, in our case, we could have a max of 5 clouds per day and
// they could last for 50 minutes.
// Which could mean 250 minutes of clouds. We need to make sure the
// PWMSlope can accomodate 250 minutes of effects or
// unforseen results could happen.
// Also, make sure that you can fit double those minutes between
// Start_Cloud_After and End_Cloud_Before.
// In our example, we have 510 minutes between Start_Cloud_After and
// End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
// fit in that 510 minutes window.
//#define printdebug // Uncomment this for debug print on Serial Monitor
// window
#define forcecloudcalculation // Uncomment this to force the cloud
// calculation to happen in the boot process.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// if picked number is greater than Cloud_Chance_per_Day, we will not have
// clouds today
// If we have cloud today
if (cloudchance)
// pick a random number for number of clouds between Min_Clouds_per_Day and
// Max_Clouds_per_Day
// the range is calculated between Start_Cloud_After and the even
// distribuition of clouds on this day.
lightningchance=random(100);
// if picked number is greater than Lightning_Change_per_Cloud, we will not
// have lightning today
// Now that we have all the parameters for the cloud, let's create the
// effect
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
if (NumMins(hour(),minute())>=cloudstart &&
NumMins(hour(),minute())<(cloudstart+cloudduration))
// let's go through all channels to pick which ones will be dimmed
for (int a=0;a<6;a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within
// 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
if (lightningchance &&
(NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<5)
for (int b=0;b<6;b++)
// if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel=100;
else PWMChannel=0;
//delay(10);
// else
// PWMChannel=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
if (lightningchance)
int x=0;
else x=57;
else x=75;
cstart*=60;
cend*=60;
if (n>=cstart && n<=(cstart+clength)) return
map(n,cstart,cstart+clength,PWMStart,PWMEnd);
if (n>=(cend-clength) && n<=cend) return
map(n,cend-clength,cend,PWMEnd,PWMStart);
if (n>cend) return PWMStart;
Re: Relay expansion code
Posted: Sat Mar 08, 2014 5:48 pm
by Sacohen
The expansion relay code is designed to be uploaded as a test only.
It's not supposed to be left in the unit.
The easiest way to do what you want is to use the wizard and set all the ports on the expansion module to be always on, the copy the generated code into your code.
It should look like this...
I see your problem now.
As you can see from the Wizard code the expansion is identified as Box 1 and then the ports 1-8, rather than 9-16 like you have them.
Posted: Sat Mar 08, 2014 6:09 pm
by bmhair03
Thanks ill give that a try.
Posted: Sat Mar 08, 2014 8:52 pm
by bmhair03
ok i made this one it compiled fine but after trying to upload it I get a no internal memory found error on the RA now i cant even upload old pde. Help!?
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
#define RelayExp
// within the code.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
0,0,0,0,0,0};
byte x = 6;
byte y = 2;
byte t;
x = 12;
char text[7];
x = 10;
x += (16*4) + 8;
24, y+31, 10);
x+24, y+31, 10);
x = 15;
y=MENU_START_ROW*7;
y += 4;
strcat(text," ");
x += 60;
strcat(text," ");
x -= 60;
strcat(text," ");
x += 60;
strcat(text," ");
x -= 60;
strcat(text," ");
x += 60;
strcat(text," ");
// y += 39*2;
// x = 13;
// #ifdef RelayExp
// #endif RelayExp
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
ReefAngel.Relay.On(Box1_Port3);
ReefAngel.Relay.On(Box1_Port4);
ReefAngel.Relay.On(Box1_Port5);
ReefAngel.Relay.On(Box1_Port8);
CheckCloud();
void CheckCloud()
// everyday
// less than 6
// of more than 255
// actinics
// triggered
// daylights
// window
#else
#endif
// clouds today
if (cloudchance)
// effect
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
if (cloudchance)
// 3minutes.
else PWMChannel=0;
//delay(10);
// else
// PWMChannel=20;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
cstart*=60;
cend*=60;
Posted: Sat Mar 08, 2014 9:39 pm
by bmhair03
Cant program anything now!!!?? NO code will upload I tried the test codes also help No internal memory found does not sound good ?
Posted: Sat Mar 08, 2014 9:45 pm
by bmhair03
I now have 2 RA's that say no internal memory found after trying to upload code /?? one is a plus the other gen 1.\
Posted: Sat Mar 08, 2014 11:12 pm
Make sure you have 1.1.0 libs and upload the initalinternalmemory
Posted: Sun Mar 09, 2014 8:04 am
by bmhair03
I guess its time to re read manual :). Thanks
