RA Error - Code too big
Posted: Sun Mar 09, 2014 7:11 pm
by ecam
Why is this code saying its oversized. Its the same code ive been using for months. Thanks in advance for the help
    #include <DS1307RTC.h>fafa
    #include <RF.h>fa
        byte myRFMode=0;
        byte myRFDuration=0;
        byte myRFSpeed=0;
        // Ports toggled
      ReefAngel.WaterChangePorts = Port3Bit | Port7Bit| Port8Bit| Box1_Port1| Box1_Port4| Box1_Port6; // Turn off Return, UV, Skimmer, Heater, Sump Equipment, ATO
      ReefAngel.FeedingModePorts = Port3Bit | Port8Bit; // Turn off Return and Skimmer
      ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port5Bit| Port6Bit;  //Turn on ATI lights, Fan and Fuge Light
      ReefAngel.OverheatShutoffPorts = Port4Bit |Port5Bit | Box1_Port1; // ATI Lights and Heaters
        ReefAngel.Relay.On( Port3); //RETURN
        ReefAngel.Relay.On( Port7 );
        ReefAngel.Relay.On( Box1_Port2 );  // Razor Led
        ReefAngel.Relay.On( Box1_Port4 ); // Sump Equipment - UV, Pump
        ReefAngel.Relay.On( Box1_Port5 ); // MP40s
        ReefAngel.Relay.On( Box1_Port6 ); // JBJ
        ReefAngel.Relay.On( Box1_Port3);
           ReefAngel.Relay.Off( Port1);      //  Port1 aCROPOWER DOSING...  on all the time!!!
           ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge opposite of Actinic
      //  Port3 ...  pORT 3 return always on
           ReefAngel.StandardLights( Port4,10,0,20,0 ); //ATI Actinic
           ReefAngel.StandardLights( Port5,11,0,19,0 );  //ATI Daylight
           ReefAngel.StandardLights( Port6,10,0,21,0 );  //ATI Fanfa
      //  ReefAngel.Relay.On( Port7 );   UV
           ReefAngel.Relay.DelayedOn( Port8,5 ); //Skimmer
          //box 2
        //ReefAngel.Relay.Off( ); // Lunar Hub Not used
           ReefAngel.StandardHeater( Box1_Port1,778,790 ); //Heater   Port #9
    //    Box1_Port2 Razor_LED (Sump)...  on all the time!!!      Port #10
  //         ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off       Port #11 Moonlight
    //              if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
      //            if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay on
    //    Box1_Port4 Sump Equipment  on all the time!!!      Port #12
    //    Box1_Port5 Ecotech MP_40 Pumps  on all the time!!!      Port #13
    //    Box1_Port6 JBJ ATO ...          on all the time!!!      Port #14
           ReefAngel.Relay.Off( Box1_Port7);  // ALK Doser ...      Port #15
           ReefAngel.Relay.Off( Box1_Port8);  // Calc Doser ...     Port #16
///moonlight dimming
                if (hour()>=6 && hour()<10) ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) ); // Moonlight Between 5-10am turn the relay on
                if (hour()>=20 && hour()<=23) ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) ); // From 8pm-Midnight turn the relay on
                else ReefAngel.PWM.SetDaylight(0);
//    ReefAngel.PWM.SetDaylight( PWMSlope(20,0,23,0,100,0,180,100) );
 //   ReefAngel.PWM.SetDaylight( PWMSlope(6,0,10,0,9,100,240,9) );
              //ReefAngel.Relay.off(Box1_Port3);
//  if (hour()>=10 || hour()<20) ReefAngel.PWM.SetDaylight(0);
//    ReefAngel.PWM.SetDaylight( MoonPhase()+10 );
    // ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
//              ReefAngel.PWM.SetDaylight(PWMSlope(6,0,23,0,0,100,240,0));
  //            if (hour()>=5 && hour()<20) ReefAngel.PWM.SetDaylight(0);
    //          ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) );
      //        ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) );
          if (hour()>=6 && hour()<11)
            myRFSetMode(ReefCrest,85,10);
          else if (hour()>=11 && hour()<13)
          else if (hour()>=13 && hour()<16)
            myRFSetMode(Smart_NTM,85,15);
          else if (hour()>=16 && hour()<19)
            myRFSetMode(ReefCrest,65,10);
            myRFSetMode(Lagoon,40,10);
        // Hardcode PH calibrations
         //ReefAngel.PHMin=544; // PH7.0
         //ReefAngel.PHMax=830; // PH10.0
         RunDosingPumps();
         LogDosingPumps();
        ReefAngel.Portal( "ecam" );
        // Parameters
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
              strcat(text,"  ");
              ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
              ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
         // Main Relay Box
        // Date and Time
    // Define Your dosing pumps
    #define numDPumps 3
    byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8,Port1Bit };
    int DPVolume[numDPumps]={ 17, 17, 7} ; // 1ml for each alk and calcium - total volume for the day
    int DPRepeat[numDPumps]={ 360, 360, 360 } ; // Repeat every 4 hrs 6x a day --- in mins
    // Define Calibration here
    int CalTime[numDPumps]={ 600, 600, 600 }; // 10 minutes / 10 minutes
    int CalVol[numDPumps]={ 350, 300,384 }; // 350ml / 300ml... .58 / .5/.64
    // Function: RunDosingPumps()
    void RunDosingPumps() {
      float rate;
      int calcTime[numDPumps];
      for (int i=0;i < numDPumps; i++) {
        rate=(float)CalVol[i]/CalTime[i];
        calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
        // Run the pumps
        ReefAngel.DosingPumpRepeat(pumpRelays[i], i*5, DPRepeat[i], calcTime[i]); // Offset between each pump is 5 minutes
      // Display Time calculated in portal
      ReefAngel.CustomVar[0]=calcTime[0];
      ReefAngel.CustomVar[1]=calcTime[1];
      ReefAngel.CustomVar[2]=calcTime[2];
    // Function: LogDosingPumps()
    void LogDosingPumps() {
      static time_t pumpTimer[numDPumps];
      static boolean pumpStatus[numDPumps];
      float rate;
      for (int i=0;i< numDPumps;i++) {
        if (ReefAngel.Relay.Status(pumpRelays[i])) {
          if (!pumpStatus[i]) {
            pumpStatus[i]=true;
        } else {
          if (pumpStatus[i]) {
            pumpStatus[i]=false;
            // Report How much volume has been dosed per day.
            // Could make this in minutes... excercise for the reader..
            ReefAngel.CustomVar[3]=pumpTimer[0]*rate;
            ReefAngel.CustomVar[4]=pumpTimer[1]*rate;
            ReefAngel.CustomVar[5]=pumpTimer[2]*rate;
        // Clear timer at end of day
        if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
        void myRFSetMode(byte m, byte s, byte d)
          if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
            myRFMode=m;
            myRFSpeed=s;
            myRFDuration=d;
            ReefAngel.RF.SetMode(m,s,d);
Re: RA Error - Code too big
Posted: Mon Mar 10, 2014 11:43 am
by ecam
Bump
Posted: Mon Mar 10, 2014 11:47 am
Don't you have an RA+? Make sure your board is set properly... otherwise you should have plenty of room in there...
If you have a standard then whats the size your at? The libaries have increased so you may need to trim a bit. Also it could be the fafa and fa typos you have in there lol :)
