wifi quit working
Posted: Mon Mar 10, 2014 6:32 am
by heatdissipation
I was connected for three days with no problems, now i cant seem to connect, I have to be doing something wrong here, but my frustration level is skyrocketing.
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM5
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM5
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM5
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 1052 10 config
< 25 1052 10 user
< 26 88548 3 wifly-GSX-441-r1057
< 27 1052 10 <cr>
< 144 Free, Boot=26, Backup=2
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s knapp
< set w s knapp
< AOK
< <4.41>
> set w p riddick1
< set w p riddick1
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=knapp
< Chan=10
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.41>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=192.168.1.141:2000
< NM=255.255.255.0
< GW=192.168.1.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router IGD
Port 2000 is now being forwarded to 192.168.1.141
I still have the blue blinking light, says it could not connect to my network, but it did for days with no changes made......
Re: wifi quit working
Posted: Mon Mar 10, 2014 8:34 am
Something is causing authentication failure.
Do you have the router setup for WPA2-PSK with AES encryption?
Posted: Mon Mar 10, 2014 9:33 am
by heatdissipation
It turned out to be a case of mistaken identity. K and k look the same but produce different results. Capitalization is important. Ugh. I got it working now.
