ATO COde
Posted: Tue Mar 11, 2014 4:58 pm
I am trying to get my ATO setup and the code is not working from the reef angel wizard. how can i get it to trigger properly?
byte myRFMode=0;
byte myRFDuration=0;
byte myRFSpeed=0;
// Ports toggled
ReefAngel.WaterChangePorts = Port3Bit | Port7Bit| Port8Bit| Box1_Port1| Box1_Port4| Box1_Port6; // Turn off Return, UV, Skimmer, Heater, Sump Equipment, ATO
ReefAngel.FeedingModePorts = Port3Bit | Port8Bit; // Turn off Return and Skimmer
ReefAngel.LightsOnPorts = Port2Bit | Box1_Port2; //Turn on ATI lights, Fan and Fuge Light
ReefAngel.OverheatShutoffPorts = Port4Bit |Box1_Port1; // ATI Lights and Heaters
InternalMemory.OverheatTemp_write( 825 ); // Set the Overheat temperature setting
//Box1
ReefAngel.Relay.Off(Port1); // Port1 Acropower Dosing ...
ReefAngel.Relay.Off(Port2); // Port2 Fuge Light
if (hour()>=23 && hour()<7) ReefAngel.Relay.On(Port2); // Fuge Between 11pm-7am turn the relay on
ReefAngel.Relay.On(Port3); // Port3 Return Pump -- Always on
ReefAngel.Relay.Off(Port4); // Port4 Not Used
ReefAngel.Relay.Off(Port5); // Port5 Not Used
ReefAngel.Relay.Off(Port6); // Port6 Not Used
ReefAngel.Relay.On(Port7); // Port7 UV Lamp -- Always on
ReefAngel.Relay.DelayedOn( Port8,5 ); // Port8 Skimmer -- 5 min delay start
//box 2 (Box1_Portxx)
ReefAngel.StandardHeater( Box1_Port1,778,790 ); // Box1_Port1 Heater
ReefAngel.Relay.On(Box1_Port2); // Box1_Port2 Razor_LED (Sump) -- Always on
ReefAngel.Relay.Off(Box1_Port3); // Box1_Port3 Not Used
ReefAngel.Relay.On(Box1_Port4); // Box1_Port4 Sump Equipment-- Always on
ReefAngel.Relay.On(Box1_Port5); // Box1_Port5 MP40s -- Always on
// ReefAngel.Relay.Off(Box1_Port6); // Box1_Port6 ATO Top off (RODI)
ReefAngel.SingleATO(true,Box1_Port6,60,0); // ATO Low port with 60 seconds timeout
// ReefAngel.SingleATOHigh(true,Box1_Port6,300,0); // ATO Low port with 5 min timeout (200 mls per min, 3,785mls in a gallon)
ReefAngel.Relay.Off( Box1_Port7); // Box1_Port7 ALK Doser
ReefAngel.Relay.Off( Box1_Port8); // Box1_Port8 Calc Doser
// Old Code
//moonlight dimming
// if (hour()>=6 && hour()<10) ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) ); // Moonlight Between 5-10am turn the relay on
// if (hour()>=20 && hour()<=23) ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) ); // From 8pm-Midnight turn the relay on
// else ReefAngel.PWM.SetDaylight(0);
// ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge opposite of Actinic
// ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off Port #11 Moonlight
//if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
//if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay
// ReefAngel.PWM.SetDaylight( PWMSlope(20,0,23,0,100,0,180,100) );
// ReefAngel.PWM.SetDaylight( PWMSlope(6,0,10,0,9,100,240,9) );
//ReefAngel.Relay.off(Box1_Port3);
// if (hour()>=10 || hour()<20) ReefAngel.PWM.SetDaylight(0);
// ReefAngel.PWM.SetDaylight( MoonPhase()+10 );
// ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
//ReefAngel.PWM.SetDaylight(PWMSlope(6,0,23,0,0,100,240,0));
//if (hour()>=5 && hour()<20) ReefAngel.PWM.SetDaylight(0);
//ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) );
//ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) );
if (hour()>=6 && hour()<11)
myRFSetMode(ReefCrest,85,10);
else if (hour()>=11 && hour()<13)
else if (hour()>=13 && hour()<16)
myRFSetMode(Smart_NTM,85,50);
else if (hour()>=16 && hour()<19)
myRFSetMode(ReefCrest,65,10);
myRFSetMode(Lagoon,40,10);
// Hardcode PH calibrations
//ReefAngel.PHMin=544; // PH7.0
//ReefAngel.PHMax=830; // PH10.0
RunDosingPumps();
LogDosingPumps();
ReefAngel.Portal( "ecam" );
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
// Main Relay Box
// Date and Time
// Define Your dosing pumps
#define numDPumps 4
byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8,Port1Bit,Box1_Port6 };
int DPVolume[numDPumps]={ 17, 17, 7} ; // 1ml for each alk and calcium - total volume for the day
int DPRepeat[numDPumps]={ 360, 360, 360 } ; // Repeat every 4 hrs 6x a day --- in mins
// Define Calibration here
int CalTime[numDPumps]={ 600, 600, 600,600 }; // 10 minutes / 10 minutes
int CalVol[numDPumps]={ 350, 300,384,120000 }; // 350ml / 300ml... .58 / .5/.64
// Function: RunDosingPumps()
void RunDosingPumps() {
float rate;
int calcTime[numDPumps];
for (int i=0;i < numDPumps; i++) {
rate=(float)CalVol[i]/CalTime[i];
calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
// Run the pumps
ReefAngel.DosingPumpRepeat(pumpRelays[i], i*5, DPRepeat[i], calcTime[i]); // Offset between each pump is 5 minutes
// Display Time calculated in portal
ReefAngel.CustomVar[0]=calcTime[0];
ReefAngel.CustomVar[1]=calcTime[1];
ReefAngel.CustomVar[2]=calcTime[2];
ReefAngel.CustomVar[3]=calcTime[3];
// Function: LogDosingPumps()
void LogDosingPumps() {
static time_t pumpTimer[numDPumps];
static boolean pumpStatus[numDPumps];
float rate;
for (int i=0;i< numDPumps;i++) {
if (ReefAngel.Relay.Status(pumpRelays[i])) {
if (!pumpStatus[i]) {
pumpStatus[i]=true;
} else {
if (pumpStatus[i]) {
pumpStatus[i]=false;
// Report How much volume has been dosed per day.
// Could make this in minutes... excercise for the reader..
ReefAngel.CustomVar[3]=pumpTimer[0]*rate;
ReefAngel.CustomVar[4]=pumpTimer[1]*rate;
ReefAngel.CustomVar[5]=pumpTimer[2]*rate;
// Clear timer at end of day
if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
void myRFSetMode(byte m, byte s, byte d)
if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
myRFMode=m;
myRFSpeed=s;
myRFDuration=d;
ReefAngel.RF.SetMode(m,s,d);
