Ok, replaced the board just now. No problems whatsoever until...see below. Roberto, help! It took less than 15 minutes.
Here is how it looks w/ the unit open
Here, I took the screen off and snapped it onto the + board. Post cut the picture off and doesn't show the new board on the right...
There are 4 screws at the corners that the board is attached to.
Here is the new board screwed back onto the head unit.
Here is everything put back together.
Here is my problem. The screen is blank! I detached it and reattached it again and restarted the head unit and still this. Roberto!!??? What's the problem?
Everything else seems to be working fine. I obviously have to use my android app or the portal to do anything.
Side note, Roberto. The ph probe seems to be working better. I have NOT calibrated it but it is already showing numbers that are more like what it should be. I will calibrate this weekend (or whenever I get fluid) and PM you about this.
